주요 콘텐츠로 건너뛰기
TI-84 Plus calculator support.
20 질문 전체 보기
My calculator turns on but unresponsive to the keyboard.
My Ti-84 turns on but when i press the keyboard its unresponsive. The cursor just keeps flashing and the none of the buttons work.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
had you tried removing the backup battery and 4 x AAA battery?
leave it for some time. I had one unit having this issue too....
I notice there are several hardware revision and what firmware are you using?
댓글 달기
답변 1개
선택된 해법
Augustine has a good suggestion, try removing the AAA batteries and the backup battery, then try replacing them. If any of them are corroded, they may have permanently damaged the buttons.
If that doesn’t help, here’s a guide on getting to the keys that may help. Once you’ve gotten to the main board, check for any loose or dirty connections.
If you find the buttons are beyond repair, you can buy a cheap, used calculator and swap out the motherboard.
TI-84 Plus Silver Edition Backup Battery 이미지
안내서
TI-84 Plus Silver Edition Backup Battery Replacement
난이도:
쉬움
3 - 5 minutes
TI-84 Plus Silver Edition Motherboard and Screen 이미지
안내서
TI-84 Plus Silver Edition Motherboard and Screen Replacement
난이도:
조정
5 - 15 minutes
TI-84 Plus Silver Edition Keyboard Mat 이미지
안내서
TI-84 Plus Silver Edition Keyboard Mat Replacement
난이도:
조정
10 - 20 minutes
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
jerin7931 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 19
전체 시간: 9,197
