주요 콘텐츠로 건너뛰기
스크린 크기 5.3” 스크린 해상도 1280x720 Pixels 배터리 용량 2,700 mAh 카메라 해상도13MP 프로세서 Qualcomm Snapdragon™ MSM8917 1.4GHz Quad-Core 메모리 2GB RAM 저장 용량 32GB ROM (최대 사용 가능 23.21GB) 통신사 T-Mobile 또는 MetroPCS 다른 기능 Android 7 (Nougat) 운영 체제, 5MP 전면 카메라와 제스처 샷 & 셀피 빛, 4G LTE 연결성, 모바일 핫스팟, Rear Key/리어 키 지문 센서. 모델 TP260 및 MP260
Why is my water damaged not showing my screen?
I was taking a bath when I heard a knock on the door so I dropped my phone in the water within a second I grabbed it dried it off it still worked so I kept it in the cloth I dried it in and continued my bath then turned it on and called somebody I kept going on my phone but it was acting up so I restarted it now from last night I couldn’t turn on the phone….
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @jenna2089 ,
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available from electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to a video which shows how to dis-assemble the phone, which may be of some help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Jenna Herbun 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 380
