주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
Bluetooth not available, even after replacing Airport card
I had this issue where my bluetooth would sometimes just disconnect, so I figured the solution might be to replace the airport card. I did this and it worked fine for a little bit, but now the problem is back. There’s some software fixes I tried, like deleting the Bluetooth.plist files and resetting the NVRAM, basically anything I could find on Apple’s forums and on here. Is there anything else I should look into fixing?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Messing with the software won’t fix this! Hopefully you can undo the alterations.
To fix this properly you’ll need to replace the MacBook Pro 13" Retina (Late 2012-Early 2013) I/O Board Data Cable you may still need a new I/O board if it is corroded from a liquid spill.
Replace an I/O Board Cable compatible with the Late 2012 to Early 2013 MacBook Pro 13" Retina laptop. Fix the connection between the I/O Board and the Logic Board. 이미지
제품
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Alright, thanks for the suggestion. I'll try it out and accept the answer if it solved the issue! And don't worry, I didn't make any drastic changes software-wise, just reset a few things that can easily be reverted.
Quick question, I found this guide MacBook Pro 13" Retina Display Late 2012 I/O Board Replacement. From the pictures, it seems like the data cable is accessible without removing the heatsink assembly. Is this correct? That would make the operation a bit easier. EDIT: Never mind, found the repair guide for the data cable only MacBook Pro 13" Retina Display Late 2012 I/O 보드 데이터 케이블 교체
댓글 달기
답변을 추가하세요
Yorrick Bakker 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 108
