주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
배터리 업그레이드 및 디스플레이 수리 지침을 포함한 PSP Go의 완벽한 수리 매뉴얼입니다.
PSP Go - No Power, No Charging
Day before yesterday every time I plug in the charger orange light turns on for little while then it turn it self off, now since yesterday my PSP Go doesn't charge, NO orange light and I can't turn it on.
Any word of advice how can I determine what's causing this problem (USB cable, AC adapter, or PSP itself)?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 달기
답변 4개
선택된 해법
hold square triangle start select and home and turn it on good luck:)
이 답변이 도움이 되었나요?
점수 7
댓글 4개:
great thanks really helped ..
I cant believe this worked, after around 9 years of not being able to use my psp go, this helped. PSP GO is like new and i can continue my gaming
this trick worked on my psp go that only charged with compatible cables. i tried 2 different original cables and no luck on charging or connecting to pc on usb mode. after the trick works wonders
댓글 달기
Wolfin2010, check your AC adapter with a multimeter/voltmeter just to make sure it works. Also check your cable and make sure it is not frayed and in good working order. Check the plug on your PSP and make sure it does not have any corrosion or other damage. If all that checks out, I would try a new battery. PSP Go 배터리 교체 after that it is time to reevaluate. If you are really handy, check on here for the fuse location of your go and check your fuses to make sure they are all okay. Hope this will at least get you started. Good Luck
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Hi I already replaced my battery but am having issues again. Any ideas?
댓글 달기
Having same problem with my PSP1001 going to try resetting first if that don't work then I will test the charging pin to see if its not making good contact.9 out of 10 times its one of these…..
이 답변이 도움이 되었나요?
점수 0
댓글 달기
2019, PSP go hasnt worked since I was a kid (about 10 years ago when I took a trip overseas) and tried this AND IT WORKED. I cant even believe it I'm so excited. Give me your EXACT address so I can come kiss you my good sir
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Wolfin2010 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 30
지난 30일: 171
전체 시간: 36,353
