주요 콘텐츠로 건너뛰기
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
20 질문 전체 보기
Joy Stick Barely Works. Connection is bad. Advice?
Howdy iFixit! I bought this PSP from the thrift store because it was only $30. (Expensive Thrift Stores here haha). It works really well in most cases except for the joy stick. It hardly responds to movement, and the curser/player when you're using it moves around on its own. If you apply pressure to the PSP in that area, it sort of starts working. From what I've researched, the contact from the joystick to the logic board has separated some, so it doesn't really contact the board that well. That's what I've diagnosed, too.
The problem is, however, that I don't really know how to fix it. Anyone else had this problem before? I think it all happens when the PSP is dropped. :P
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
TommyJames, this guide might help you out. Step 7 and on tells you what to do when the buttons are not working etc....
UPDATE
also, you might check this question. If cleaning it does not work you might have to replace the stick assembly. the part is available here and there are plenty of videos on on youtube.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
+ Very good accurate answer worthy of others referencing to it here on iFixit in the future.
Thank you so much oldturkey! I'm gonna try this probably over the weekend. With your help I'm sure to get the PSP working again! :)
I tried working on the PSP yesterday. It seemed to have been working really well at first, and then it just went back to not working. So, I think I've got to fidget with it for a while. Thanks so much for your advice!
댓글 달기
답변을 추가하세요
TommyJames337 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 2,599
