주요 콘텐츠로 건너뛰기
The Sony Ericsson Xperia X10 Mini E10i runs on a custom version of Android and features 3G access. Released in 2010.
20 질문 전체 보기
Water Damage
My Sony Ericsson xperia x10 fell into water and just went black. It still charges but now i need to see if it works.Should i send it to Sony Ericsson or how can i get it fixed?
Anna.Zimbabwe
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
Anna is it an X10 or a x10 Mini E10?
toilet no good. dirty phone. buy new telephone.
댓글 달기
답변 3개
선택된 해법
Anna I would suggest that you first clean your device. Use this as your guide. After that, re-evaluate your phone. you can try a restore by downloading PC SUIT from here
install it, start the Software
Press Tools
Press Phone repair
Press Continue
Wait for PC Suit to download the file
Follow the prompts and select Model X10
Connect your phone while holding the back button and plug the USB cord in. Let the drivers install wan wait while it completes.
Again this may or may not work. I am really more leaning toward you needing a new LCD due to the water damage. But follow the steps anyway. You can download the compete service manual from here. Hope this helps and gets you started in the right direction. Good Luck
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Sorry, I posted at the same time
Wow great minds think alike ;-)
댓글 달기
Hey dear, the same thing happened to my experia arc. Gosh its brande new.. it fell into the toilet lol.
ok well, bo panic. all you should do is dry it with a vacuum. Or place in the sunshine for few hrs without touching it or turning it on constently please. turning on a cell when its still dry frys the cell. You can also place it infront of the fan for few hrs. When you see its completely dry only than put in the battery and sim and turn it on. Remember they drying process should be done with having the battery and sim out of it in first.
It will really help. If not, than you have to seperate all the partd and dry eah part individually. and fix it and turn it on..
이 답변이 도움이 되었나요?
점수 0
댓글 달기
pc suit
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
What does that mean? Is it an answer or a question?
댓글 달기
답변을 추가하세요
Anna 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 5,081
