주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Honda CR-V는 1995년부터 혼다에서 제조하는 소형 크로스오버 차량입니다. 혼다 시빅의 플랫폼을 SUV 차체에 적용했기 때문에, 'Comfortable Runabout Vehicle(편안하고 자유로운 주행을 위한 차량)'의 약자인 "CR-V"라고 불립니다.
Engine with broken base, totaled?
Hi everyone, I got in a single car collision and caused a lot of damage to the front of my car. My attention keeps getting drawn to this crack/split around the engine. I’m not a car man myself, is this the engine itself or a cover/base? Does this broken piece mean the car is totaled/whole engine needs to be replaced? Would appreciate any information on this, thank you.
이미지
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 5개:
Hi,
Post some close up images of the damage to the engine, in your question.
Here's how to do it on ifixit 기존 질문에 이미지 추가하기.
Also what is the year and engine size of the vehicle?
Regarding the vehicle being "totaled", it may depend on what your car insurance assessor decides, assuming that the car is insured that is
Thank you @jayeff added some photos.
Honda CR-V 2016. Not sure what the size of the engine is but its the base model of the car.
@jayeff Most insurance companies total out for frame damage, which I'm seeing.
@nick
I don't know what the "cash" value of the model (5 years old?) would be (might depend on location I suppose) but if the repairs cost more than the value most insurers will total it and pay out.
Might also depend on the policy conditions since it was a "single vehicle" accident what the policy holder may get from them in return for it being totaled.
Cheers
@jayeff Usually it's a percentage, like how I work with repairs - so for example if I'm looking at a HP SV panel and I find the things go for $175 average, I may total it out unless I could remove it and put a part that isn't overpriced in.
However, some like this may be instantly totaled.
댓글 달기
답변 2개
What we can say here is limited. You need to take this to a body shop, or at least a shop who can inspect it and be sure the damage is repairable. The engine looks fine but check the exhaust manifold. It looks fine as you just avoided having to replace it but better to check then find out later.
First thing you need to worry about is the crumple zones, and crash bar under the bumper. If those are pushed into the point you need to cut and weld, the car is usually a total loss at that point due to the cost to patch it in, unless it’s a recent MY. The cost of the parts and labor usually do it, as you need to put it on an alignment machine to get it correct - and even then, there will always be alignment issues so if you sell it, the buyer will be able to tell. I don’t see anything concerning, but it looks like the foam in the bumper, bumper, radiator and A/C condenser took a lot of the damage. As a matter of caution, give replacing both a serious thought.
이미지
It does look like the brackets for the crash bar took a nasty part of the crash, so you need to make sure the subframe around it isn’t damaged as well. If it isn’t, you can usually replace them on the Hondas. You will want to replace both, and inspect the crash bar and replace it if needed - usually if those get bent in, the crash bar took a fair bit of damage.
이미지
This is also concerning, as it looks like a good portion of the front-end crumple zone may be damaged as well. You really, really need to take this to a body shop for a professional look.
The hood and bumper are cosmetic - you can get those all day at a junkyard, but you may need to get a can of clearcoat and Perfect Match touchup paint, or get the parts painted at a body shop. Check the headlight, but do not be surprised if the crashed side needs a new headlight.
If anything like parking sensors got ruined, replace them all at once because it can screw up the system if you have one that’s damaged in a crash, and an intact one.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Johnjohn40092 John quite the damage. Hope everybody is okay. So as for the “crack. That is your timing gear cover. Cost for that around $100USD aftermarket. That is not a catastrophic damage and can be repaired. Question now is why did this happen? Check your engine mounts and see if those are okay. That engine looks slightly pushed back to the right rear. It is possible that this is due to the strain of getting hit on that right hand side. As for what else is damage, yes it is a lot but looking at your fender and the right side wheels etc. it appears there is not much structural damage but a lot of plastic damage. Until that is removed you really can’t see the extend. The front crossmember and the rest of the bulkhead seem to be unaffected. Again, let the pro’s check that out. Sub-frame and other structural parts are readily available and body shops do a pretty amazing job in getting things straight.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
If it's anything like Volvo (who is also big on crash safety like Honda and Toyota), the engine mounts could very well be part of the crumple zone and are *designed* to break but also be replaceable as a bad mount isn't always due to an accident. At a minimum, you're replacing the mounts and crash bar unless you can recover the crash bar there - which is doubtful.
The reason I mentioned my concerns is the damage on the crash bar structure, plus the moved engine. Depending on how the crumple zone is engineered, it's part of the unibody. You'd need to check the subframe and in a lot of cases with unibody structures you need to weld on a new crumple zone by cutting off the old one.
댓글 달기
답변을 추가하세요
Johnjohn40092 John 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 32
전체 시간: 1,776
