주요 콘텐츠로 건너뛰기
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 질문 전체 보기
Is it safe to put 32 gb in asus b85m-e?
Is it safe to put 32 gb in asus b85m-e ? Won't it burn up my pc ?
I want to put 32 gb ram ddr4 in asus b85m-e , but i don't know if it's safe .
I'm scared that my pc will broke or burn up.
Specs:
Gtx 1660 Super
Asus B85M-E
Intel Core i5 3.20 Ghz
HDD 2,5 TB
SDD 500 GB
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
According to this after an easy Google your motherboard supports 32gb of memory.
https://icecat.biz/p/asus/b85m-e-csm/mot...
이 답변이 도움이 되었나요?
점수 2
댓글 달기
According to the technical specs from Asus, this board does support up to 32GB of memory, however I did notice that it does not support DDR4. Only DDR3.
These two standards are not physically compatible since the number of pins as well as the size of the slots on the board differ slightly.
이 답변이 도움이 되었나요?
점수 2
댓글 9개:
So I can't put ddr4 in this motherboard? Is 32 GB RAM DDR3 Good for gaming ? Especially for Warzone 2.
@kozeriukas Not based on the information from Asus. DDR3 is an older standard and it's not ideal for current gaming since it's not rated for speeds as high as DDR4 (or DDR5) support, but there are definitely other factors that would be more relevant to gaming performance.
What graphics card are you using? That and your CPU will probably have a greater impact on gaming performance, although faster RAM is generally better overall it wouldn't be the first thing I would suggest as an upgrade in most cases for gaming.
I will also mention the minimum specs for Warzone 2 can be found at Activision's website
@flannelist
Don't forget the chipset either, although there's not much you can do about it.
It's the interface between the CPU and the ram, GPU (if separate), HDD etc,
So a lot of the time you're limited by the motherboard so to speak as it is the chipset that determines what can be connected to it in the way of higher spec components to improve performance
So what is the cheapest way I can do to increase my pc performance?
Because I think I need to buy a new motherboard to put 32 GB DDR4 Rams and I don't want to do that because it's too expensive for me at this situation :D
@flannelist
My Gpu is Gtx 1660 Super
But I don't know why I'm getting 40-50 fps even if I'm playing on very low settings. And I can't find the answer.
댓글 4개 더보기
댓글 달기
답변을 추가하세요
kozeriukas lt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 343
