주요 콘텐츠로 건너뛰기
1.8 또는 2 GHz G5 프로세서
20 질문 전체 보기
Power Supply Replacement Question 17" to 20"
Is it possible to swap in internal "guts" of a iMac 17" power supply into a 20" non-working power supply?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
The Power Supply's are different sizes, a 17" might work in a 20", but definitely not the other way around. when you sad "internal guts" I hope you don't mean actually opening the Power supply..
if incase the big warning that says "DO NOT OPEN, DANGER OF ELECTRICAL SHOCK!" wasn't good enought for ya.. let me say.. DO NOT Open a power supply.. the capacitors store power even when its unplugged.. and we're not looking for "darwin award" nominees here.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Thanks - I will not attempt to open. I was also wondering about the bracket that holds the hard drive for a 20" iMac g5. This seems like a tricky part to obatin. Any idea on where I can find this?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
andrew 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 9
전체 시간: 2,904
