Can an expansion card be cleaned with water?
My USB-A expansion port has gathered some dust - can I safely rinse it with water after taking it out?
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
좋은 질문입니까?
Hey there,
Water is not recommended for any electronic repair. iFixit does have a pretty nice guide for Cleaning the Ports on a Device, and I would highly recommend giving it a read.
Thank you
이 답변이 도움이 되었나요?
Mostly agree. In this case, cleaning the expansion ports on a Framework laptop, there is a simpler and safer approach.
Nit: Deionized or distilled water is often used for electronics repair. Definitely don't use tap water, though - due to various mineral impurities that are safe to drink (even good for your health) but not so safe to smear on electronics, it can accelerate corrosion and will leave behind sediment when it dries up. Also, electronics should be completely discharged before bringing them near water, and completely dried out before powering them on again. Drying them out properly can take hours, since water loves to hide in tiny nooks and crevices and under surface-mount components.
tl;dr There are some cases where water is appropriate to use when cleaning electronics, but there are *many* important precautions to take. It's often more trouble than it's worth.
지난 24시간: 3
지난 7일: 8
지난 30일: 25
전체 시간: 112
