주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/32/64/128 GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
Bluetooth lost range after battery replacement
I just changed out my battery using a kit I bought here at iFixit. It was a bit of a struggle but I got it done. However, now when I connect it to my Bluetooth speaker it starts breaking up if it moves more than like a foot away. I think the wifi is affected too but it's hard to tell (my wifi isn't great normally). I'm a little worried I might have broken something. Should I go back in and replace the antenna or are there other troubleshooting things I should do first before I open the phone again?
Note: I have performed several hard resets but the problem seems to come back in different ways. I think it is a problem with the range of the antenna.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
You’ve bumped off or damaged the WiFi and Bluetooth antenna, which is that s shaped cable right above the battery.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I opened it up again and that is exactly what happened. It got caught under the battery and snapped when I was putting the battery in. Always look twice before shoving something in everyone!
댓글 달기
답변을 추가하세요
Pat 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 27
전체 시간: 202
