주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel 5 Battery Replacement
필요한 것
  1. Google Pixel 5 Battery Replacement, Heat the bottom edge of the screen: 1 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the bottom edge of the screen for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Google Pixel 5 Battery Replacement, Screen removal information: 2 단계, 이미지 3개 중 1개 Google Pixel 5 Battery Replacement, Screen removal information: 2 단계, 이미지 3개 중 2개 Google Pixel 5 Battery Replacement, Screen removal information: 2 단계, 이미지 3개 중 3개
    • While you're waiting for the adhesive to loosen, take note of the following:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
  3. Google Pixel 5 Battery Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 1개 Google Pixel 5 Battery Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 2개 Google Pixel 5 Battery Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the bottom edge of the screen—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  4. Google Pixel 5 Battery Replacement: 4 단계, 이미지 3개 중 1개 Google Pixel 5 Battery Replacement: 4 단계, 이미지 3개 중 2개 Google Pixel 5 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen and its bezel frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  5. Google Pixel 5 Battery Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 1개 Google Pixel 5 Battery Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 2개 Google Pixel 5 Battery Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 3개
    • Apply a suction cup to the screen, as close to the heated edge as possible.
    • If your screen is badly cracked, follow this guide to tape over the cracked screen. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert the opening pick into the gap.
  6. Google Pixel 5 Battery Replacement, Slice the bottom adhesive: 6 단계, 이미지 3개 중 1개 Google Pixel 5 Battery Replacement, Slice the bottom adhesive: 6 단계, 이미지 3개 중 2개 Google Pixel 5 Battery Replacement, Slice the bottom adhesive: 6 단계, 이미지 3개 중 3개
    • Slide the opening pick back and forth along the bottom of the screen to slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  7. Google Pixel 5 Battery Replacement, Heat the left edge of the screen: 7 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the left edge of the screen for one minute.
  8. Google Pixel 5 Battery Replacement: 8 단계, 이미지 3개 중 1개 Google Pixel 5 Battery Replacement: 8 단계, 이미지 3개 중 2개 Google Pixel 5 Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Insert another opening pick into the bottom left corner of the screen.
    • Slide the opening pick around the left corner.
    • Do not insert the pick more than 1/4 inch (6 mm) or you may damage the screen's flex cable located in the middle of the left edge.
    • Continue to slide the pick up towards the front camera to slice the adhesive on the left edge of the screen.
    • Leave the pick inserted to prevent the adhesive from re-sealing.
  9. Google Pixel 5 Battery Replacement: 9 단계, 이미지 3개 중 1개 Google Pixel 5 Battery Replacement: 9 단계, 이미지 3개 중 2개 Google Pixel 5 Battery Replacement: 9 단계, 이미지 3개 중 3개
    • Insert another opening pick into the top left corner of the screen.
    • Slide the pick around the front camera and across the top edge of the phone.
    • If the adhesive is difficult to slice, apply heat to the area for one minute and try again.
    • Slide the pick to the top right corner of the phone and leave the pick inserted.
  10. Google Pixel 5 Battery Replacement: 10 단계, 이미지 3개 중 1개 Google Pixel 5 Battery Replacement: 10 단계, 이미지 3개 중 2개 Google Pixel 5 Battery Replacement: 10 단계, 이미지 3개 중 3개
    • Insert an opening pick into the bottom right corner of the screen.
    • Slide the pick up to the top right corner to slice the last edge of adhesive.
    • You may need to run an opening pick around the edges again to ensure all the adhesive is cut. It is applied the thickest on the four corners.
  11. Google Pixel 5 Battery Replacement, Open up the screen: 11 단계, 이미지 2개 중 1개 Google Pixel 5 Battery Replacement, Open up the screen: 11 단계, 이미지 2개 중 2개
    • Use the opening pick from the top left corner to lift up the left edge of the screen a few millimeters. This will keep the clips from snapping back down into the case.
    • Lift up on the right side of the screen and open up the phone like a book.
    • Do not open the screen more than 90 degrees to prevent damaging the screen flex cable.
  12. Google Pixel 5 Battery Replacement, Disconnect the screen: 12 단계, 이미지 2개 중 1개 Google Pixel 5 Battery Replacement, Disconnect the screen: 12 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to grip the screen connector cover securing the screen flex cable.
    • Push the clip in towards the connector to unlatch it.
  13. Google Pixel 5 Battery Replacement: 13 단계, 이미지 2개 중 1개 Google Pixel 5 Battery Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the screen connector cover.
    • Make sure to keep this component to reinstall it during reassembly.
  14. Google Pixel 5 Battery Replacement: 14 단계, 이미지 2개 중 1개 Google Pixel 5 Battery Replacement: 14 단계, 이미지 2개 중 2개
    • Use the tip of the spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage
  15. Google Pixel 5 Battery Replacement, Screen information: 15 단계, 이미지 1개 중 1개
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  16. Google Pixel 5 Battery Replacement, Remove the screen: 16 단계, 이미지 2개 중 1개 Google Pixel 5 Battery Replacement, Remove the screen: 16 단계, 이미지 2개 중 2개
    • Remove the screen.
    • Use tweezers to pick off the remaining adhesive on the case.
    • If you use isopropyl alcohol to clean the adhesive off the display, be sure to not let it splash onto any unintended components, as this can weaken their adhesive bond.
    • If you replaced the screen, check the screen's front-facing camera hole and remove any protective liners covering it.
    • If your replacement screen's display cable is held down by tape, remove the tape before installation.
    • If you are using a custom-cut adhesive, follow this guide to correctly apply new screen adhesive.
    • If you are using Tesa tape to reattach the screen, follow this guide.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
  17. Google Pixel 5 Battery Replacement, Remove the graphite tape: 17 단계, 이미지 3개 중 1개 Google Pixel 5 Battery Replacement, Remove the graphite tape: 17 단계, 이미지 3개 중 2개 Google Pixel 5 Battery Replacement, Remove the graphite tape: 17 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to lift up the graphite tape until you are able to grip it with your fingers.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Peel off the graphite tape.
  18. Google Pixel 5 Battery Replacement: 18 단계, 이미지 2개 중 1개 Google Pixel 5 Battery Replacement: 18 단계, 이미지 2개 중 2개
    • Use tweezers to peel off the graphite pad covering the charging plate cover.
    • If you are able to keep the graphite pad in good condition, you may reapply it during reassembly.
  19. Google Pixel 5 Battery Replacement, Remove the charging plate cover: 19 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Use a T3 Torx driver to remove the two 4.6 mm-long screws securing the charging plate cover to the midframe.
  20. Google Pixel 5 Battery Replacement: 20 단계, 이미지 2개 중 1개 Google Pixel 5 Battery Replacement: 20 단계, 이미지 2개 중 2개
    • Use tweezers to remove the charging plate cover.
  21. Google Pixel 5 Battery Replacement: 21 단계, 이미지 1개 중 1개
    • Use a T3 Torx driver to remove the eight 4.6 mm-long screws securing the midframe.
  22. Google Pixel 5 Battery Replacement, Remove the midframe: 22 단계, 이미지 3개 중 1개 Google Pixel 5 Battery Replacement, Remove the midframe: 22 단계, 이미지 3개 중 2개 Google Pixel 5 Battery Replacement, Remove the midframe: 22 단계, 이미지 3개 중 3개
    • Use tweezers to lift up the right side of the midframe.
    • Remove the midframe.
    • The spacer at the top of the phone is likely to fall out when you remove the midframe. Remember to save this spacer for reassembly. See pictures in the motherboard replacement guide.
  23. Google Pixel 5 Battery Replacement, Disconnect the battery: 23 단계, 이미지 2개 중 1개 Google Pixel 5 Battery Replacement, Disconnect the battery: 23 단계, 이미지 2개 중 2개
    • Use the pointed end of the spudger to pry the battery connector straight up and disconnect it from the motherboard.
  24. Google Pixel 5 Battery Replacement, Remove adhesive pull tabs: 24 단계, 이미지 3개 중 1개 Google Pixel 5 Battery Replacement, Remove adhesive pull tabs: 24 단계, 이미지 3개 중 2개 Google Pixel 5 Battery Replacement, Remove adhesive pull tabs: 24 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use blunt nose tweezers to grip the black adhesive pull tab located on the top right edge of the battery. Lift the pull tab with the tweezers until you are able to grip it with your fingers.
    • Pull on the pull tab with a slow, steady force at a shallow angle to prevent the pull tab from snapping in the middle.
    • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
    • If the adhesive becomes hard to pull, you can roll it around a spudger and continue pulling.
    • If the pull tab breaks prematurely, use tweezers to retrieve the remaining length of adhesive and continue pulling.
    • If you are unable to retrieve it, move on to the next step.
  25. Google Pixel 5 Battery Replacement: 25 단계, 이미지 3개 중 1개 Google Pixel 5 Battery Replacement: 25 단계, 이미지 3개 중 2개 Google Pixel 5 Battery Replacement: 25 단계, 이미지 3개 중 3개
    • Use the same process to remove the pull tab located at the bottom left edge of the battery.
    • If this tab breaks prematurely and you are not able to retrieve it with tweezers, move on to the next step.
  26. Google Pixel 5 Battery Replacement, Loosen the adhesive: 26 단계, 이미지 2개 중 1개 Google Pixel 5 Battery Replacement, Loosen the adhesive: 26 단계, 이미지 2개 중 2개
    • If any of the adhesive strips broke off underneath the battery and could not be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol into the opening of the affected tab.
  27. Google Pixel 5 Battery Replacement: 27 단계, 이미지 2개 중 1개 Google Pixel 5 Battery Replacement: 27 단계, 이미지 2개 중 2개
    • Tilt the phone so that the alcohol flows towards the remaining adhesive.
    • Wait one minute for the adhesive to soften, then proceed to the next step.
  28. Google Pixel 5 Battery Replacement, Remove the battery: 28 단계, 이미지 2개 중 1개 Google Pixel 5 Battery Replacement, Remove the battery: 28 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Insert an opening pick into the gap long the left side of the battery.
    • Use the opening pick to slice the remaining adhesive at the top and bottom of the battery.
    • Avoid scraping the two flex cables under the battery with your opening pick.
    • This may be difficult as the adhesive is strategically located between the cables and the battery tray. A possible solution is to cut a plastic card to fit between the flex cables and battery tray edge.
    • Do not bend the battery.
    • Avoid the earpiece contact pins located near the top left corner of the battery as you pry up with your opening pick.
    • If you cannot pry the battery up, add a few more drops of isopropyl alcohol to the adhesive. A plastic card can also be helpful during this process.
  29. Google Pixel 5 Battery Replacement: 29 단계, 이미지 2개 중 1개 Google Pixel 5 Battery Replacement: 29 단계, 이미지 2개 중 2개
    • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove your old battery.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
다른 99명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Robert Boyd
회원 가입일: 02/01/21
32,077 평판
안내서 94개를 작성함
51가이드 댓글
While this is an excellent guide, like the others here, I find the ending statement of "To reassemble your device, follow the above steps in reverse order." very much a throw you in the deep end type of scenario. Figuring out how to place the adhesives that come with the kit was very much a trial and error thing. They are not quite intuitive and I was unable to find any answers anywhere. In my first attempt, the two strips for the battery, are a mess. You never get a visual of how or where they are since you remove them by pulling tabs in Step 21.
Here's the deal with them. Two protective layers, a clear oversized layer on one side, and blue cut to the exact shape on the other. Both sides are sticky. Once you figure out the placement, apply the adhesives by peeling the clear protective layer first. Line it up and firmly press. When ready to adhere to the other side, the blue layer is removed by 2 tabs that are part of the layer. Pull 1 tab and carefully peel it away and it should come away in 1 or 2 pieces.
Jesse - 답글
Very frustrating that a year and a half later the tutorial has not been fixed to include the information you've given, or any more information at all.
It's clear that this tutorial is not complete when multiple replies have had issues with vibration, screens, and other functions, along with pieces that got left out upon reassembly. I had better hopes for ifixit since they offer a complete kit and boast they have tutorials. I thought the experience would be higher quality.
lupa -
To put it back together I recommend watching Google Pixel 5 Battery Replacement from 5:46 onwards. This video as an accompaniment in general to this guide I found super helpful as it's an actual video of this repair.
Seeing someone actually perform this exact repair in realtime is very helpful as well as some techniques not mentioned in this guide.
I performed a screen and battery replacement with the help of this video so I really recommend watching it.
Marcel McKenzie -
Clear instructions and photos. I would agree the 'do in reverse order' instruction is too vague. Thanks to Jesse for the clarifying information on the adhesives and to Marcel for the video link - both of these additional instructions helped immensely. New phone battery installed and phone is in working order!
Kristi Hvidbjerg -
I followed this guide and successfully changed the battery. Unfortunately, vibration seems to be not working anymore. What could I have done wrong? Did I damage something?
Julian - 답글
댓글 쓰기
조회 통계:
지난 24시간: 60
지난 7일: 1,005
지난 30일: 6,281
전체 시간: 182,094
