주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel Tablet Enclosure Replacement
필요한 것
  1. Google Pixel Tablet Enclosure Replacement, Prepare your tablet for disassembly: 1 단계, 이미지 2개 중 1개 Google Pixel Tablet Enclosure Replacement, Prepare your tablet for disassembly: 1 단계, 이미지 2개 중 2개
    • Allow your battery to fully drain before starting this repair. A charged battery may catch fire if damaged.
    • Unplug any cables from your tablet and fully power it down.
    • Hold the power and volume up buttons at the same time to bring up the power off menu.
  2. Google Pixel Tablet Enclosure Replacement: 2 단계, 이미지 1개 중 1개
    • If your screen is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
  3. Google Pixel Tablet Enclosure Replacement, Secure the Anti-Clamp: 3 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Secure the Anti-Clamp: 3 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Secure the Anti-Clamp: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backward to unlock the Anti-Clamp's arms.
    • Slide the arms over the top left corner, with one suction cup on the back cover and one on the screen.
    • Place an object under your tablet so it rests level between the Anti-Clamp's arms.
    • Squeeze the cups together to create suction.
  4. Google Pixel Tablet Enclosure Replacement, Use the Anti-Clamp to create a gap: 4 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Use the Anti-Clamp to create a gap: 4 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Use the Anti-Clamp to create a gap: 4 단계, 이미지 3개 중 3개
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise two full turns, or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
  5. Google Pixel Tablet Enclosure Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 3개
    • Use a hair dryer or heat gun to heat the top left corner of the screen until a gap forms between the glass and the frame.
    • Be careful not to overheat the tablet—the screen and battery are susceptible to heat damage.
    • Insert an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
  6. Google Pixel Tablet Enclosure Replacement, Heat the top left corner: 6 단계, 이미지 1개 중 1개
    • If you've already inserted an opening pick using the Anti-Clamp, skip down two steps.
    • Rotate your tablet so the front camera is closest to you.
    • Apply a heated iOpener to the top left corner of the screen (now your bottom right, since the tablet is flipped around) for three minutes.
    • You can also use a hair dryer, heat gun, or hot plate, but be careful not to overheat the screen or battery—only heat the tablet so it's warm to the touch.
  7. Google Pixel Tablet Enclosure Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 3개
    • Apply a suction handle to the top left corner of the screen, as close to the top edge as possible.
    • Pull up on the suction handle with a strong, steady force until a gap forms between the glass and the frame.
    • Insert the tip of an opening pick into the gap.
    • Remove the suction handle.
  8. Google Pixel Tablet Enclosure Replacement, Adhesive information: 8 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Adhesive information: 8 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Adhesive information: 8 단계, 이미지 3개 중 3개
    • The screen is secured with adhesive all around the perimeter. Note the following areas as you separate the adhesive:
    • The top, bottom, and left edges have the thickest adhesive.
    • The right edge has slightly thinner adhesive.
    • At the top, near the front camera, the adhesive is very thin and delicate cables connect the screen to the frame.
  9. Google Pixel Tablet Enclosure Replacement, Reposition your opening pick: 9 단계, 이미지 2개 중 1개 Google Pixel Tablet Enclosure Replacement, Reposition your opening pick: 9 단계, 이미지 2개 중 2개
    • Don't insert your pick deeper than 7 mm, or about halfway between the tip of the pick and the iFixit logo.
    • Slide your opening pick to the top left corner of the tablet.
    • Leave this pick inserted to prevent the adhesive from resealing.
  10. Google Pixel Tablet Enclosure Replacement, Heat the left edge: 10 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the left edge of the screen for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate, but be careful not to overheat the screen or battery.
  11. Google Pixel Tablet Enclosure Replacement, Separate the left edge adhesive: 11 단계, 이미지 2개 중 1개 Google Pixel Tablet Enclosure Replacement, Separate the left edge adhesive: 11 단계, 이미지 2개 중 2개
    • Insert a second opening pick in the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the left edge adhesive.
  12. Google Pixel Tablet Enclosure Replacement, Heat the bottom edge: 12 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  13. Google Pixel Tablet Enclosure Replacement, Separate the bottom edge adhesive: 13 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Separate the bottom edge adhesive: 13 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Separate the bottom edge adhesive: 13 단계, 이미지 3개 중 3개
    • Insert a third opening pick in the bottom left corner.
    • Slide your pick to the bottom right corner of the screen to separate the bottom edge adhesive.
    • If your pick becomes stuck, repeatedly twist it as you slide to help separate the adhesive.
  14. Google Pixel Tablet Enclosure Replacement, Heat the right edge: 14 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the right edge of the screen for two minutes.
  15. Google Pixel Tablet Enclosure Replacement, Separate the right edge adhesive: 15 단계, 이미지 2개 중 1개 Google Pixel Tablet Enclosure Replacement, Separate the right edge adhesive: 15 단계, 이미지 2개 중 2개
    • Don't insert your pick deeper than 5 mm along the right edge.
    • For a visual reference, you can measure 5 mm from the tip and mark your pick with a permanent marker.
    • Insert a fourth opening pick in the bottom right corner.
    • Slide your pick to the top right corner to separate the right edge adhesive.
  16. Google Pixel Tablet Enclosure Replacement, Heat the top edge: 16 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  17. Google Pixel Tablet Enclosure Replacement, Top edge information: 17 단계, 이미지 1개 중 1개
    • The front camera and sensor are along the middle of the top edge. Be very careful not to insert your opening pick deeper than 3 mm (1/8 in) here.
    • For a visual reference, you can measure 3 mm from the tip and mark your pick with a permanent marker.
    • To mark where to avoid slicing too deep, it can be helpful to put a 6.3 cm (2.5 in) long strip of masking tape on the top edge, centered over the front camera.
  18. Google Pixel Tablet Enclosure Replacement, Separate the top edge adhesive: 18 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Separate the top edge adhesive: 18 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Separate the top edge adhesive: 18 단계, 이미지 3개 중 3개
    • Insert a fifth opening pick in the top right corner of the screen.
    • Slide your pick toward the front camera. Stop when your pick is 3 cm (1.25 in) from the front camera.
    • Pull your pick out to a depth of 3 mm (1/8 inch) and slide it past the front camera.
    • When your pick is 3 cm past the front camera, insert it up to 6 mm deep, or about halfway between the tip and the iFixit logo, and slide it to the first pick you left in the top left corner.
  19. Google Pixel Tablet Enclosure Replacement, Tilt the screen open: 19 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Tilt the screen open: 19 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Tilt the screen open: 19 단계, 이미지 3개 중 3개
    • Don't tilt the screen open beyond 90 degrees. The front camera and sensor cables are very short and may tear.
    • Grab and lift the bottom corners of the screen.
    • If the screen feels stuck, check around the perimeter for any missed sections of adhesive and slice them with an opening pick.
    • Tilt the screen open just enough to access the cables connecting the screen to the frame.
    • During reassembly, remove the adhesive liners from the perimeter of the screen before firmly pressing it into place in the frame.
  20. Google Pixel Tablet Enclosure Replacement, Remove the screen cable tape: 20 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Remove the screen cable tape: 20 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Remove the screen cable tape: 20 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • For the next three steps, hold the screen tilted open with one hand while you work with your other hand.
    • If you have difficulty holding up the screen, place the tablet's dock on the frame to prop up the screen or ask someone to hold it up while you work.
    • Use tweezers to peel and remove the black tape off of the screen cable connector.
    • During reassembly:
    • Install new tape if the old piece is damaged and you have a replacement from your repair kit.
    • Now is a good time to test your tablet before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
  21. Google Pixel Tablet Enclosure Replacement, Disconnect the screen: 21 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Disconnect the screen: 21 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Disconnect the screen: 21 단계, 이미지 3개 중 3개
    • Use the point of a spudger or a clean fingernail to flip up the small locking flap on the inside edge (same side as the cable) of the screen cable ZIF connector.
    • Use tweezers or your fingers to pull the screen cable straight out of its socket.
  22. Google Pixel Tablet Enclosure Replacement, Disconnect the front camera: 22 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Disconnect the front camera: 22 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Disconnect the front camera: 22 단계, 이미지 3개 중 3개
    • Use an opening pick to flip up the small locking flap on the outside edge (opposite the cable) of the front camera ZIF connector.
    • Use tweezers to pull the cable straight out of its socket.
    • During reassembly, be careful not to tear this cable, since it doesn't have much room to bend. Guide the connector into its socket with tweezers and lock the ZIF connector flap at the same time.
  23. Google Pixel Tablet Enclosure Replacement, Disconnect the front sensor: 23 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Disconnect the front sensor: 23 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Disconnect the front sensor: 23 단계, 이미지 3개 중 3개
    • Use the point of your spudger or a clean fingernail to flip up the small locking flap on the inside edge of the front sensor connector.
  24. Google Pixel Tablet Enclosure Replacement, Remove the screen: 24 단계, 이미지 1개 중 1개
    • Remove the screen.
  25. Google Pixel Tablet Enclosure Replacement, Prepare your frame for reassembly: 25 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Prepare your frame for reassembly: 25 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Prepare your frame for reassembly: 25 단계, 이미지 3개 중 3개
    • Follow the next two steps to clean your frame and prepare it for reassembly.
    • Use the flat end of your spudger or a clean fingernail to scrape up an edge of the leftover frame adhesive until you can grip it.
    • Use tweezers or your fingers to peel off large pieces of adhesive from the frame.
    • Repeat this process around the entire perimeter of the frame until there are no large pieces are left.
    • If you're reusing your screen, remove the old adhesive from it as well as the frame.
  26. Google Pixel Tablet Enclosure Replacement: 26 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement: 26 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement: 26 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • Fill a pipette or syringe with highly-concentrated isopropyl alcohol (over 90%) and apply a few drops to the edge of the frame.
    • Wrap a microfiber or lint free cloth around the flat end of your spudger and scrub the frame until it's clean. Use more isopropyl alcohol as you go.
    • If you're reusing your screen, clean its perimeter as well as the frame.
  27. Google Pixel Tablet Enclosure Replacement, Remove the cable cover: 27 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Remove the cable cover: 27 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Remove the cable cover: 27 단계, 이미지 3개 중 3개
    • While the Pixel Tablet uses Torx Plus screws, standard Torx bits work in a pinch. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the two 2.6 mm screws securing the battery, USB-C, and speakers connectors cover.
    • If you're using standard Torx bits, a T3 Torx will work best for these screws. If it feels too loose, you may need a T4 Torx bit.
    • Remove the cover.
  28. Google Pixel Tablet Enclosure Replacement, Disconnect the battery: 28 단계, 이미지 2개 중 1개 Google Pixel Tablet Enclosure Replacement, Disconnect the battery: 28 단계, 이미지 2개 중 2개
    • Use the flat end of your spudger to pry up and disconnect the battery press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side.
  29. Google Pixel Tablet Enclosure Replacement, Reassembly information: 29 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Reassembly information: 29 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Reassembly information: 29 단계, 이미지 3개 중 3개
    • Connecting the screen cable with the battery connected risks shorting the connector and poses a fire hazard.
    • Follow this step during reassembly to safely reconnect the screen and battery.
    • Prop up the bottom edge of the tablet on a box or similar object. Tilt the screen open and lean it against something so that it's angled up to 90 degrees.
    • Reconnect the small front sensor cable ZIF connector.
    • Reconnect the large screen cable ZIF connector.
    • Reconnect the battery press connector.
    • Use your Torx Plus 3IP driver to install the two 2.6 mm screws and fasten the connector cover.
    • Continue reassembly with these cables connected.
  30. Google Pixel Tablet Enclosure Replacement, Disconnect the USB-C port: 30 단계, 이미지 2개 중 1개 Google Pixel Tablet Enclosure Replacement, Disconnect the USB-C port: 30 단계, 이미지 2개 중 2개
    • Use the flat end of your spudger to pry up and disconnect the USB-C port press connector.
  31. Google Pixel Tablet Enclosure Replacement, Remove the USB-C cable tape: 31 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Remove the USB-C cable tape: 31 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Remove the USB-C cable tape: 31 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Be careful not to damage the battery with your tool during this step.
    • Use blunt nose tweezers or your fingers to peel up and remove the three strips of tape securing the USB-C port cable to the battery.
    • During reassembly, reuse these strips of tape if they're in good condition. If not, cut and apply a few thin strips of electrical tape to re-secure the cable to the battery.
  32. Google Pixel Tablet Enclosure Replacement, Unfasten the USB-C port: 32 단계, 이미지 1개 중 1개
    • Use your Torx Plus 3IP driver to remove the four 3.2 mm screws securing the USB-C port.
  33. Google Pixel Tablet Enclosure Replacement, Remove the USB-C port: 33 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Remove the USB-C port: 33 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Remove the USB-C port: 33 단계, 이미지 3개 중 3개
    • Pull the USB-C port out of its recess in the frame and remove it.
  34. Google Pixel Tablet Enclosure Replacement, Disconnect the left speakers: 34 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Disconnect the left speakers: 34 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Disconnect the left speakers: 34 단계, 이미지 3개 중 3개
    • Use the point of your spudger to lift up and disconnect the blue and white speaker cable connector from the right side of the logic board.
    • Pry straight up on the neck of the cables, as close to the head of the connector as possible.
    • Disconnect the red and black speaker cable connector.
  35. Google Pixel Tablet Enclosure Replacement, Free the left speaker cables: 35 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Free the left speaker cables: 35 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Free the left speaker cables: 35 단계, 이미지 3개 중 3개
    • Pull the blue and white speaker cables out from their clips along the top and right edges of the battery tray.
    • Pull the red and black speaker cables out from their clips along the top of the battery tray.
  36. Google Pixel Tablet Enclosure Replacement, Disconnect the right speakers and antenna cables: 36 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Disconnect the right speakers and antenna cables: 36 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Disconnect the right speakers and antenna cables: 36 단계, 이미지 3개 중 3개
    • Use the point of your spudger to pry up and disconnect the blue and white speaker cable connector from the left side of the logic board.
    • Disconnect the black and white speaker cable connector.
    • Disconnect the left antenna connector from the logic board by prying the metal neck of the cable straight up.
  37. Google Pixel Tablet Enclosure Replacement, Free the left cables: 37 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Free the left cables: 37 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Free the left cables: 37 단계, 이미지 3개 중 3개
    • Pull the speaker cables and antenna cable out from the clips securing them along the battery tray.
  38. Google Pixel Tablet Enclosure Replacement, Unfasten the battery tray: 38 단계, 이미지 2개 중 1개 Google Pixel Tablet Enclosure Replacement, Unfasten the battery tray: 38 단계, 이미지 2개 중 2개
    • Use a Torx Plus 2IP driver to remove the six 2.8 mm screws securing the battery tray.
  39. Google Pixel Tablet Enclosure Replacement, Remove the stretch-release adhesive: 39 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Remove the stretch-release adhesive: 39 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Remove the stretch-release adhesive: 39 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Six strips of stretch-release adhesive run underneath the battery tray, securing it to the frame.
    • Use tweezers to peel back the six white pull-tabs on the battery tray's stretch-release adhesive strips.
    • Don't try to remove the battery cells from the black tray.
  40. Google Pixel Tablet Enclosure Replacement: 40 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement: 40 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement: 40 단계, 이미지 3개 중 3개
    • Grab an adhesive strip's pull tab and slowly pull it out from underneath the battery tray.
    • Pull the adhesive strip at as low of an angle as you can. Try to avoid dragging it across components inside the frame.
    • Pull the adhesive strip until it's freed from under the battery tray. Give the strip plenty of time to stretch.
    • Repeat for all six adhesive strips.
    • Use your spudger to depress the piece of foam near the lower right strip as you pull.
    • If any strips broke off and you can't retrieve them:
    • Use a pipette or syringe to dispense a few drops of highly-concentrated isopropyl alcohol (over 90%) under the sections of the battery tray where the strips broke. Tilt the tablet to let the isopropyl alcohol flow underneath.
    • Wait two minutes, then use a spudger to pry up the battery tray.
  41. Google Pixel Tablet Enclosure Replacement, Remove the battery: 41 단계, 이미지 2개 중 1개 Google Pixel Tablet Enclosure Replacement, Remove the battery: 41 단계, 이미지 2개 중 2개
    • Remove the battery, still attached to its tray, from the frame.
    • Don't reuse a deformed or damaged battery, as doing so is a safety hazard.
    • During reassembly, if you're installing a new battery, remove the liners from the six adhesive strips on the underside of the battery tray and press it firmly into place. Use the six screw posts to help align the tray to the frame.
  42. Google Pixel Tablet Enclosure Replacement, Remove the speaker cable tape: 42 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Remove the speaker cable tape: 42 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Remove the speaker cable tape: 42 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers or your fingers to peel up and remove the tape securing the black and white speaker cable to the enclosure.
    • During reassembly, reuse this tape if it's in good condition. If not, cut and apply a thin strip of electrical tape to re-secure the cable to the enclosure.
  43. Google Pixel Tablet Enclosure Replacement, Unfasten the speakers: 43 단계, 이미지 2개 중 1개 Google Pixel Tablet Enclosure Replacement, Unfasten the speakers: 43 단계, 이미지 2개 중 2개
    • Use a Torx Plus 2IP driver to remove the sixteen 2.7 mm screws securing the four speakers.
    • If you're using standard Torx bits, a T3 Torx will work best for these screws. If it feels tight, you may need a T2 Torx bit.
  44. Google Pixel Tablet Enclosure Replacement, Remove the speakers: 44 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Remove the speakers: 44 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Remove the speakers: 44 단계, 이미지 3개 중 3개
    • Remove the speakers.
  45. Google Pixel Tablet Enclosure Replacement, Disconnect the left antenna cable: 45 단계, 이미지 2개 중 1개 Google Pixel Tablet Enclosure Replacement, Disconnect the left antenna cable: 45 단계, 이미지 2개 중 2개
    • Use your spudger to disconnect the left antenna connector by prying the metal neck of the cable straight up.
  46. Google Pixel Tablet Enclosure Replacement, Disconnect the lower antenna cables: 46 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Disconnect the lower antenna cables: 46 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Disconnect the lower antenna cables: 46 단계, 이미지 3개 중 3개
    • Disconnect the lower two antenna cables.
  47. Google Pixel Tablet Enclosure Replacement, Disconnect the left ZIF connector: 47 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Disconnect the left ZIF connector: 47 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Disconnect the left ZIF connector: 47 단계, 이미지 3개 중 3개
    • Flip up the small locking flap on the outside edge of the left ZIF connector and pull the cable straight out of its socket.
  48. Google Pixel Tablet Enclosure Replacement, Disconnect the right ZIF connector: 48 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Disconnect the right ZIF connector: 48 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Disconnect the right ZIF connector: 48 단계, 이미지 3개 중 3개
    • Use the point of your spudger or a clean fingernail to flip up the small locking flap on the outside edge of the right ZIF connector.
  49. Google Pixel Tablet Enclosure Replacement, Disconnect the daughterboard: 49 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Disconnect the daughterboard: 49 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Disconnect the daughterboard: 49 단계, 이미지 3개 중 3개
    • Use the point of your spudger or a clean fingernail to flip up the wide locking flap on the outside edge of the interconnect cable ZIF connector.
    • Use blunt nose tweezers to pull the cable straight out of its socket.
    • The cable is adhered to the enclosure. If you have trouble disconnecting it, peel the cable from the frame near the connector.
  50. Google Pixel Tablet Enclosure Replacement, Unfasten the logic board: 50 단계, 이미지 2개 중 1개 Google Pixel Tablet Enclosure Replacement, Unfasten the logic board: 50 단계, 이미지 2개 중 2개
    • Use your Torx Plus 3IP driver to remove the six screws securing the logic board:
    • Four 2.2 mm screws
    • Two 3.2 mm screws
  51. Google Pixel Tablet Enclosure Replacement, Remove the logic board: 51 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Remove the logic board: 51 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Remove the logic board: 51 단계, 이미지 3개 중 3개
    • Tilt the bottom of the logic board up and away from the frame to separate the thermal paste.
    • Slide the logic board toward the bottom of the tablet to clear the ZIF cables along the top of the frame.
    • Remove the logic board.
    • Be careful not to lose the black washer on the bottom edge of the logic board. If it falls off, make sure to put it back before installing the logic board screws.
    • During reassembly, hold the ZIF cables up as you slide the logic board into place.
  52. Google Pixel Tablet Enclosure Replacement, Clean the frame: 52 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Clean the frame: 52 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Clean the frame: 52 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • If you're reusing your frame, follow this step to clean the thermal paste from it. If not, skip down one step.
    • Use the flat end of your spudger to gently scrape away large pieces of thermal paste.
    • If you're reusing your enclosure, be careful not to tear the graphite film.
    • Use a pipette or syringe to apply a couple drops of highly-concentrated isopropyl alcohol (over 90%) to the thermal paste residue.
    • Use a microfiber or lint-free cloth to wipe the frame clean.
  53. Google Pixel Tablet Enclosure Replacement, Clean the logic board: 53 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Clean the logic board: 53 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Clean the logic board: 53 단계, 이미지 3개 중 3개
    • Gently scrape away large pieces of thermal paste from the logic board.
    • Apply a couple drops of isopropyl alcohol to the thermal paste residue.
    • Wipe the logic board clean.
    • During reassembly, follow this guide to apply new thermal paste to the logic board.
  54. Google Pixel Tablet Enclosure Replacement, Disconnect the rear camera: 54 단계, 이미지 3개 중 1개 Google Pixel Tablet Enclosure Replacement, Disconnect the rear camera: 54 단계, 이미지 3개 중 2개 Google Pixel Tablet Enclosure Replacement, Disconnect the rear camera: 54 단계, 이미지 3개 중 3개
    • Use the point of your spudger or a clean fingernail to flip up the small locking flap on the outside edge of the rear camera ZIF connector.
  55. Google Pixel Tablet Enclosure Replacement, Unfasten the rear camera bracket: 55 단계, 이미지 2개 중 1개 Google Pixel Tablet Enclosure Replacement, Unfasten the rear camera bracket: 55 단계, 이미지 2개 중 2개
    • Use your Torx Plus 3IP driver to remove the two 2.2 mm screws securing the rear camera bracket.
  56. Google Pixel Tablet Enclosure Replacement, Remove the rear camera: 56 단계, 이미지 2개 중 1개 Google Pixel Tablet Enclosure Replacement, Remove the rear camera: 56 단계, 이미지 2개 중 2개
    • Remove the rear camera.
  57. Google Pixel Tablet Enclosure Replacement: 57 단계, 이미지 1개 중 1개
    • Only the frame remains.
결론
작성자
2다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
96,949 평판
안내서 470개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 16,009개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 27
전체 시간: 1,479
