주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel Tablet Screen Replacement
필요한 것
    1. Google Pixel Tablet Screen Replacement, Prepare your tablet for disassembly: 1 단계, 이미지 2개 중 1개 Google Pixel Tablet Screen Replacement, Prepare your tablet for disassembly: 1 단계, 이미지 2개 중 2개
      • Allow your battery to fully drain before starting this repair. A charged battery may catch fire if damaged.
      • Unplug any cables from your tablet and fully power it down.
      • Hold the power and volume up buttons at the same time to bring up the power off menu.
      댓글 쓰기
    2. Google Pixel Tablet Screen Replacement: 2 단계, 이미지 1개 중 1개
      • If your screen is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      댓글 쓰기
    1. Google Pixel Tablet Screen Replacement, Secure the Anti-Clamp: 3 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Secure the Anti-Clamp: 3 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Secure the Anti-Clamp: 3 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backward to unlock the Anti-Clamp's arms.
      • Slide the arms over the top left corner, with one suction cup on the back cover and one on the screen.
      • Place an object under your tablet so it rests level between the Anti-Clamp's arms.
      • Squeeze the cups together to create suction.
      댓글 쓰기
    2. Google Pixel Tablet Screen Replacement, Use the Anti-Clamp to create a gap: 4 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Use the Anti-Clamp to create a gap: 4 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Use the Anti-Clamp to create a gap: 4 단계, 이미지 3개 중 3개
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise two full turns, or until the suction cups begin to stretch.
      • As the cups stretch, make sure they stay vertically aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
      댓글 쓰기
    3. Google Pixel Tablet Screen Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 3개
      • Use a hair dryer or heat gun to heat the top left corner of the screen until a gap forms between the glass and the frame.
      • Be careful not to overheat the tablet—the screen and battery are susceptible to heat damage.
      • Insert an opening pick into the gap.
      • Remove the Anti-Clamp using the pull tabs on the suction cups.
      댓글 쓰기
    4. Google Pixel Tablet Screen Replacement, Heat the top left corner: 6 단계, 이미지 1개 중 1개
      • If you've already inserted an opening pick using the Anti-Clamp, skip down two steps.
      • Rotate your tablet so the front camera is closest to you.
      • Apply a heated iOpener to the top left corner of the screen (now your bottom right, since the tablet is flipped around) for three minutes.
      • You can also use a hair dryer, heat gun, or hot plate, but be careful not to overheat the screen or battery—only heat the tablet so it's warm to the touch.
      댓글 쓰기
    5. Google Pixel Tablet Screen Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 3개
      • Apply a suction handle to the top left corner of the screen, as close to the top edge as possible.
      • Pull up on the suction handle with a strong, steady force until a gap forms between the glass and the frame.
      • Insert the tip of an opening pick into the gap.
      • Remove the suction handle.
      댓글 쓰기
    6. Google Pixel Tablet Screen Replacement, Adhesive information: 8 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Adhesive information: 8 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Adhesive information: 8 단계, 이미지 3개 중 3개
      • The screen is secured with adhesive all around the perimeter. Note the following areas as you separate the adhesive:
      • The top, bottom, and left edges have the thickest adhesive.
      • The right edge has slightly thinner adhesive.
      • At the top, near the front camera, the adhesive is very thin and delicate cables connect the screen to the frame.
      댓글 쓰기
    7. Google Pixel Tablet Screen Replacement, Reposition your opening pick: 9 단계, 이미지 2개 중 1개 Google Pixel Tablet Screen Replacement, Reposition your opening pick: 9 단계, 이미지 2개 중 2개
      • Don't insert your pick deeper than 7 mm, or about halfway between the tip of the pick and the iFixit logo.
      • Slide your opening pick to the top left corner of the tablet.
      • Leave this pick inserted to prevent the adhesive from resealing.
      댓글 쓰기
    8. Google Pixel Tablet Screen Replacement, Heat the left edge: 10 단계, 이미지 1개 중 1개
      • Apply a heated iOpener to the left edge of the screen for two minutes.
      • You can also use a hair dryer, heat gun, or hot plate, but be careful not to overheat the screen or battery.
      댓글 쓰기
    9. Google Pixel Tablet Screen Replacement, Separate the left edge adhesive: 11 단계, 이미지 2개 중 1개 Google Pixel Tablet Screen Replacement, Separate the left edge adhesive: 11 단계, 이미지 2개 중 2개
      • Insert a second opening pick in the top left corner of the screen.
      • Slide your pick to the bottom left corner of the screen to separate the left edge adhesive.
      댓글 쓰기
    10. Google Pixel Tablet Screen Replacement, Heat the bottom edge: 12 단계, 이미지 1개 중 1개
      • Apply a heated iOpener to the bottom edge of the screen for two minutes.
      댓글 쓰기
    11. Google Pixel Tablet Screen Replacement, Separate the bottom edge adhesive: 13 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Separate the bottom edge adhesive: 13 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Separate the bottom edge adhesive: 13 단계, 이미지 3개 중 3개
      • Insert a third opening pick in the bottom left corner.
      • Slide your pick to the bottom right corner of the screen to separate the bottom edge adhesive.
      • If your pick becomes stuck, repeatedly twist it as you slide to help separate the adhesive.
      댓글 쓰기
    12. Google Pixel Tablet Screen Replacement, Heat the right edge: 14 단계, 이미지 1개 중 1개
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      댓글 쓰기
    13. Google Pixel Tablet Screen Replacement, Separate the right edge adhesive: 15 단계, 이미지 2개 중 1개 Google Pixel Tablet Screen Replacement, Separate the right edge adhesive: 15 단계, 이미지 2개 중 2개
      • Don't insert your pick deeper than 5 mm along the right edge.
      • For a visual reference, you can measure 5 mm from the tip and mark your pick with a permanent marker.
      • Insert a fourth opening pick in the bottom right corner.
      • Slide your pick to the top right corner to separate the right edge adhesive.
      댓글 쓰기
    14. Google Pixel Tablet Screen Replacement, Heat the top edge: 16 단계, 이미지 1개 중 1개
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      댓글 쓰기
    15. Google Pixel Tablet Screen Replacement, Top edge information: 17 단계, 이미지 1개 중 1개
      • The front camera and sensor are along the middle of the top edge. Be very careful not to insert your opening pick deeper than 3 mm (1/8 in) here.
      • For a visual reference, you can measure 3 mm from the tip and mark your pick with a permanent marker.
      • To mark where to avoid slicing too deep, it can be helpful to put a 6.3 cm (2.5 in) long strip of masking tape on the top edge, centered over the front camera.
      댓글 쓰기
    16. Google Pixel Tablet Screen Replacement, Separate the top edge adhesive: 18 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Separate the top edge adhesive: 18 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Separate the top edge adhesive: 18 단계, 이미지 3개 중 3개
      • Insert a fifth opening pick in the top right corner of the screen.
      • Slide your pick toward the front camera. Stop when your pick is 3 cm (1.25 in) from the front camera.
      • Pull your pick out to a depth of 3 mm (1/8 inch) and slide it past the front camera.
      • When your pick is 3 cm past the front camera, insert it up to 6 mm deep, or about halfway between the tip and the iFixit logo, and slide it to the first pick you left in the top left corner.
      댓글 쓰기
    17. Google Pixel Tablet Screen Replacement, Tilt the screen open: 19 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Tilt the screen open: 19 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Tilt the screen open: 19 단계, 이미지 3개 중 3개
      • Don't tilt the screen open beyond 90 degrees. The front camera and sensor cables are very short and may tear.
      • Grab and lift the bottom corners of the screen.
      • If the screen feels stuck, check around the perimeter for any missed sections of adhesive and slice them with an opening pick.
      • Tilt the screen open just enough to access the cables connecting the screen to the frame.
      • During reassembly, remove the adhesive liners from the perimeter of the screen before firmly pressing it into place in the frame.
      댓글 쓰기
    18. Google Pixel Tablet Screen Replacement, Remove the screen cable tape: 20 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Remove the screen cable tape: 20 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Remove the screen cable tape: 20 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • For the next three steps, hold the screen tilted open with one hand while you work with your other hand.
      • If you have difficulty holding up the screen, place the tablet's dock on the frame to prop up the screen or ask someone to hold it up while you work.
      • Use tweezers to peel and remove the black tape off of the screen cable connector.
      • During reassembly:
      • Install new tape if the old piece is damaged and you have a replacement from your repair kit.
      • Now is a good time to test your tablet before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
      댓글 쓰기
    19. Google Pixel Tablet Screen Replacement, Disconnect the screen: 21 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Disconnect the screen: 21 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Disconnect the screen: 21 단계, 이미지 3개 중 3개
      • Use the point of a spudger or a clean fingernail to flip up the small locking flap on the inside edge (same side as the cable) of the screen cable ZIF connector.
      • Use tweezers or your fingers to pull the screen cable straight out of its socket.
      댓글 쓰기
    20. Google Pixel Tablet Screen Replacement, Disconnect the front camera: 22 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Disconnect the front camera: 22 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Disconnect the front camera: 22 단계, 이미지 3개 중 3개
      • Use an opening pick to flip up the small locking flap on the outside edge (opposite the cable) of the front camera ZIF connector.
      • Use tweezers to pull the cable straight out of its socket.
      • During reassembly, be careful not to tear this cable, since it doesn't have much room to bend. Guide the connector into its socket with tweezers and lock the ZIF connector flap at the same time.
      댓글 쓰기
    21. Google Pixel Tablet Screen Replacement, Disconnect the front sensor: 23 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Disconnect the front sensor: 23 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Disconnect the front sensor: 23 단계, 이미지 3개 중 3개
      • Use the point of your spudger or a clean fingernail to flip up the small locking flap on the inside edge of the front sensor connector.
      댓글 쓰기
    22. Google Pixel Tablet Screen Replacement, Remove the screen: 24 단계, 이미지 1개 중 1개
      • Remove the screen.
      댓글 쓰기
    23. Google Pixel Tablet Screen Replacement, Prepare your frame for reassembly: 25 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Prepare your frame for reassembly: 25 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Prepare your frame for reassembly: 25 단계, 이미지 3개 중 3개
      • Follow the next two steps to clean your frame and prepare it for reassembly.
      • Use the flat end of your spudger or a clean fingernail to scrape up an edge of the leftover frame adhesive until you can grip it.
      • Use tweezers or your fingers to peel off large pieces of adhesive from the frame.
      • Repeat this process around the entire perimeter of the frame until there are no large pieces are left.
      • If you're reusing your screen, remove the old adhesive from it as well as the frame.
      댓글 쓰기
    24. Google Pixel Tablet Screen Replacement: 26 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement: 26 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement: 26 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Microfiber Cleaning Cloths
      $3.99
      • Fill a pipette or syringe with highly-concentrated isopropyl alcohol (over 90%) and apply a few drops to the edge of the frame.
      • Wrap a microfiber or lint free cloth around the flat end of your spudger and scrub the frame until it's clean. Use more isopropyl alcohol as you go.
      • If you're reusing your screen, clean its perimeter as well as the frame.
      댓글 쓰기
    1. Google Pixel Tablet Screen Replacement, Remove the cable cover: 27 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Remove the cable cover: 27 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Remove the cable cover: 27 단계, 이미지 3개 중 3개
      • While the Pixel Tablet uses Torx Plus screws, standard Torx bits work in a pinch. Make sure to apply constant, downward force to prevent stripping.
      • Use a Torx Plus 3IP driver to remove the two 2.6 mm screws securing the battery, USB-C, and speakers connectors cover.
      • If you're using standard Torx bits, a T3 Torx will work best for these screws. If it feels too loose, you may need a T4 Torx bit.
      • Remove the cover.
      댓글 쓰기
    2. Google Pixel Tablet Screen Replacement, Disconnect the battery: 28 단계, 이미지 2개 중 1개 Google Pixel Tablet Screen Replacement, Disconnect the battery: 28 단계, 이미지 2개 중 2개
      • Use the flat end of your spudger to pry up and disconnect the battery press connector.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side.
      댓글 쓰기
    3. Google Pixel Tablet Screen Replacement, Reassembly information: 29 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Reassembly information: 29 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Reassembly information: 29 단계, 이미지 3개 중 3개
      • Connecting the screen cable with the battery connected risks shorting the connector and poses a fire hazard.
      • Follow this step during reassembly to safely reconnect the screen and battery.
      • Prop up the bottom edge of the tablet on a box or similar object. Tilt the screen open and lean it against something so that it's angled up to 90 degrees.
      • Reconnect the small front sensor cable ZIF connector.
      • Reconnect the large screen cable ZIF connector.
      • Reconnect the battery press connector.
      • Use your Torx Plus 3IP driver to install the two 2.6 mm screws and fasten the connector cover.
      • Continue reassembly with these cables connected.
      댓글 쓰기
    1. Google Pixel Tablet Screen Replacement, Remove the screen cable tape: 30 단계, 이미지 2개 중 1개 Google Pixel Tablet Screen Replacement, Remove the screen cable tape: 30 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use tweezers to peel up and remove the screen cable tape from the screen ZIF connector.
      댓글 쓰기
    2. Google Pixel Tablet Screen Replacement, Remove the screen cable: 31 단계, 이미지 3개 중 1개 Google Pixel Tablet Screen Replacement, Remove the screen cable: 31 단계, 이미지 3개 중 2개 Google Pixel Tablet Screen Replacement, Remove the screen cable: 31 단계, 이미지 3개 중 3개
      • Use the point of your spudger or a clean fingernail to flip up the locking flap on the inside edge of the screen ZIF connector.
      댓글 쓰기
    3. Google Pixel Tablet Screen Replacement: 32 단계, 이미지 1개 중 1개
      • The screen is all that remains.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
105,984 평판
안내서 472개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 36,508개를 작성함
11가이드 댓글
Success... but at what cost!
Repair took 3 hours, and I would rate difficulty as high, maybe even very high. My kids cracked the screen with spiderweb style cracks which made this guide 10x harder. The picks would not slide cleanly across edges, they would get jammed into the shards of fractured screen, even though I had tape over it. In the end I had to take out the screen in a million pieces. I used the flathead screwdriver tip to scrape the adhesive off with my wife standing by with the vacuum to catch the glass dust and such.
Next time I'm selling my cracked tablet on ebay and using the proceeds to buy a new one. Probably similar cost but an order of magnitude less hassle. Still, thanks iFixit for this guide.
Bryan Gillespie - 답글 공유
I agree with the review above. Difficult to repair with the ribbons. Buy open box and don’t worry about replacing the screen which is about 70% the cost of a replacement.
danny w - 답글 공유
What to do if the Screen is too shattered to apply suction?
Filipe Bispo - 답글 공유
tape it like the guide says
Scott Wilhelm - 답글 공유
I gave it a try despite significant cracking. It worked but took several hours. I did have the first corner with no cracking and the suction and pick thing worked so I had high hopes but once I got to the cracked areas ( the rest is the edges) it all went downhill and became a slog.
I think my takeaway is that if I had done it when the crack first started and hadn't spiderwebed around it would have been pretty easy. Thus I should replace the second a crack shows up... Or live with it
PS on steps. There was no clear step to replace the camera cable so I had a bit of rework to do that once I realized that wasn't done. It would also help to have more clarity on how to actually adhere the screen... There are such detailed directions and then your are just left to figure it out at the end. One last comment is having reassembly directions as footnotes to steps throughout instead of just having them be their own steps at the end is a bit strange
John G - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 123
지난 30일: 446
전체 시간: 13,686
