주요 콘텐츠로 건너뛰기
How to replace the battery in your iPhone 5s
필요한 것
동영상 개요
  1. How to replace the battery in your iPhone 5s, Removing the Pentalobe screws: 1 단계, 이미지 1/1
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.9 mm Pentalobe screws from either side of Lightning connector.
  2. How to replace the battery in your iPhone 5s, Taping the display glass: 2 단계, 이미지 1/3 How to replace the battery in your iPhone 5s, Taping the display glass: 2 단계, 이미지 2/3 How to replace the battery in your iPhone 5s, Taping the display glass: 2 단계, 이미지 3/3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  3. How to replace the battery in your iPhone 5s, Display separation prevention: 3 단계, 이미지 1/3 How to replace the battery in your iPhone 5s, Display separation prevention: 3 단계, 이미지 2/3 How to replace the battery in your iPhone 5s, Display separation prevention: 3 단계, 이미지 3/3
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
  4. How to replace the battery in your iPhone 5s, Anti-Clamp instructions: 4 단계, 이미지 1/3 How to replace the battery in your iPhone 5s, Anti-Clamp instructions: 4 단계, 이미지 2/3 How to replace the battery in your iPhone 5s, Anti-Clamp instructions: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Clamp
    $24.95
    구매
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use the included tape pad to create a grippier surface.
  5. How to replace the battery in your iPhone 5s: 5 단계, 이미지 1/3 How to replace the battery in your iPhone 5s: 5 단계, 이미지 2/3 How to replace the battery in your iPhone 5s: 5 단계, 이미지 3/3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. How to replace the battery in your iPhone 5s, Manual Opening Procedure: 6 단계, 이미지 1/1
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
  7. How to replace the battery in your iPhone 5s, Start lifting the front panel assembly: 7 단계, 이미지 1/1
    • The front panel is attached with clips, and there are several ribbon cables connecting it to the rest of the phone. Your goal here is to release the clips and open the phone only enough to disconnect the cables. Go slowly and carefully to avoid damage.
    • Make sure the suction cup is firmly attached to the front panel assembly near the home button.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the home button end of the front panel from the rear case.
    • With a plastic opening tool, gently pry the edges of the rear case down, away from the front panel assembly, while you pull up with the suction cup.
    • Take your time and apply firm, constant force. The front panel assembly is a much tighter fit than on most other devices.
  8. How to replace the battery in your iPhone 5s: 8 단계, 이미지 1/2 How to replace the battery in your iPhone 5s: 8 단계, 이미지 2/2
    • Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them.
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the screen.
  9. How to replace the battery in your iPhone 5s, Removing the Touch ID cable bracket: 9 단계, 이미지 1/3 How to replace the battery in your iPhone 5s, Removing the Touch ID cable bracket: 9 단계, 이미지 2/3 How to replace the battery in your iPhone 5s, Removing the Touch ID cable bracket: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Open the phone just enough to reveal the metal bracket covering the home button cable.
    • Do not open the phone too far or you risk damaging the home button cable, or the socket it plugs into. Keep the cable loose—if it is stretched taut, that's too far.
    • Only the phone's original home button assembly will be capable of using the Touch ID functionality. If you rip the cable, installing a new home button will only restore ordinary home button functions, not the Touch ID features.
    • Use the tip of a spudger to push the bracket free and remove it with tweezers.
    • The next two steps apply to reassembly. Skip them and continue to Step 12 until reassembly.
  10. How to replace the battery in your iPhone 5s: 10 단계, 이미지 1/2 How to replace the battery in your iPhone 5s: 10 단계, 이미지 2/2
    • During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector.
    • Slide the top of the bracket over the Touch ID cable connector from left to right.
  11. How to replace the battery in your iPhone 5s: 11 단계, 이미지 1/2 How to replace the battery in your iPhone 5s: 11 단계, 이미지 2/2
    • During reassembly, use the flat end of a spudger to snap the front portion of the Touch ID cable bracket down over the cable connector.
    • If the bracket does not snap down flush, you may need to remove the bracket and slide it over the cable connector again for a better fit.
  12. How to replace the battery in your iPhone 5s, Disconnecting the home button cable connector: 12 단계, 이미지 1/2 How to replace the battery in your iPhone 5s, Disconnecting the home button cable connector: 12 단계, 이미지 2/2
    • Use the tip of a spudger to pry the home button cable connector up out of its socket.
    • Be sure you're separating the cable connector from its socket, and not prying the entire socket up. The socket is on its own glued-down cable that can be pried up if you aren't careful.
  13. How to replace the battery in your iPhone 5s, Opening up the phone: 13 단계, 이미지 1/3 How to replace the battery in your iPhone 5s, Opening up the phone: 13 단계, 이미지 2/3 How to replace the battery in your iPhone 5s, Opening up the phone: 13 단계, 이미지 3/3
    • Once the connector has been released, pull the home button end of the assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  14. How to replace the battery in your iPhone 5s: 14 단계, 이미지 1/1
    • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
  15. How to replace the battery in your iPhone 5s: 15 단계, 이미지 1/1
    • Remove the metal battery connector bracket from the iPhone.
  16. How to replace the battery in your iPhone 5s: 16 단계, 이미지 1/2 How to replace the battery in your iPhone 5s: 16 단계, 이미지 2/2
    • Use the flat end of a spudger to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
  17. How to replace the battery in your iPhone 5s: 17 단계, 이미지 1/1
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • One 1.7 mm Phillips #000 screw
    • One 1.2 mm Phillips #000 screw
    • One 1.3 mm Phillips #000 screw
    • One more 1.7 mm Phillips #000 screw
    • This 1.7 mm screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing.
    • It is especially important to keep track of your screws in this step for reassembly. Accidentally using the 1.3 mm screw or one of the 1.7 mm screws in the bottom right hole will result in significant damage to the logic board causing the phone to no longer boot properly.
    • Be careful not to over-tighten the screws, and don't force them. If they don't fit easily when you are securing them, they may be the wrong size.
  18. How to replace the battery in your iPhone 5s: 18 단계, 이미지 1/1
    • Remove the front panel assembly cable bracket from the logic board.
  19. How to replace the battery in your iPhone 5s: 19 단계, 이미지 1/2 How to replace the battery in your iPhone 5s: 19 단계, 이미지 2/2
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable.
  20. How to replace the battery in your iPhone 5s: 20 단계, 이미지 1/2 How to replace the battery in your iPhone 5s: 20 단계, 이미지 2/2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the LCD cable connector.
    • When reassembling your phone, the LCD cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
  21. How to replace the battery in your iPhone 5s: 21 단계, 이미지 1/2 How to replace the battery in your iPhone 5s: 21 단계, 이미지 2/2
    • Finally, disconnect the digitizer cable connector.
  22. How to replace the battery in your iPhone 5s: 22 단계, 이미지 1/1
    • Remove the front panel assembly from the rear case.
  23. How to replace the battery in your iPhone 5s, Battery: 23 단계, 이미지 1/3 How to replace the battery in your iPhone 5s, Battery: 23 단계, 이미지 2/3 How to replace the battery in your iPhone 5s, Battery: 23 단계, 이미지 3/3
    • Run the tip of a spudger between the battery and the headphone jack to unfold the battery adhesive tab.
    • Important: Apply heat to the bottom of the iPhone case using an iOpener or similar heating pad to soften up the battery adhesive strips and make them more flexible, otherwise they will probably break when you pull on them.
  24. How to replace the battery in your iPhone 5s: 24 단계, 이미지 1/3 How to replace the battery in your iPhone 5s: 24 단계, 이미지 2/3 How to replace the battery in your iPhone 5s: 24 단계, 이미지 3/3
    • Pull the battery adhesive tab away from the phone.
    • Cut the black battery adhesive tab between the two white adhesive strips, separating them.
  25. How to replace the battery in your iPhone 5s: 25 단계, 이미지 1/3 How to replace the battery in your iPhone 5s: 25 단계, 이미지 2/3 How to replace the battery in your iPhone 5s: 25 단계, 이미지 3/3
    • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
    • Slowly pull one of the battery adhesive strips away from the battery, toward the bottom of the iPhone. Pull the white portion of the strip when possible, the black tab may fall off.
    • Pull steadily, maintaining constant tension on the strip as it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
    • Be careful not to snag it on any of the other internal iPhone components.
    • The strip will stretch to many times its original length. Continue pulling, re-grabbing the strip near the battery if necessary, until the entire strip comes free.
  26. How to replace the battery in your iPhone 5s: 26 단계, 이미지 1/2 How to replace the battery in your iPhone 5s: 26 단계, 이미지 2/2
    • Repeat for the second strip.
    • If you removed both strips successfully, skip the next two steps.
    • If either of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strip, and then proceed to the next step.
  27. How to replace the battery in your iPhone 5s: 27 단계, 이미지 1/1
    • If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
    • Alternatively, use a syringe to apply some high concentration isopropyl alcohol (90% or greater) underneath the edges of the battery.
    • After several minutes, the alcohol will significantly weaken the adhesive, making the battery easier to remove.
  28. How to replace the battery in your iPhone 5s: 28 단계, 이미지 1/1
    • Flip the iPhone back over and insert a plastic card between the case side of the battery and the rear case.
    • Do not pry against the logic board or you may damage the phone.
    • Avoid prying at the top left near the volume controls, or you may damage the volume button ribbon cable.
    • Keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals or catch fire. Do not use any sharp tools to pry at the battery.
    • Press the card in farther to break up the adhesive behind the battery.
    • Alternatively, a piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set.
    • Thread the floss or string behind the upper battery corners, bring the ends together, wrap them around a folded cloth, and pull evenly.
  29. How to replace the battery in your iPhone 5s: 29 단계, 이미지 1/3 How to replace the battery in your iPhone 5s: 29 단계, 이미지 2/3 How to replace the battery in your iPhone 5s: 29 단계, 이미지 3/3
    • Pull the battery out of the rear case.
    • If your replacement battery came in a plastic sleeve, remove the sleeve before installation by pulling it away from the ribbon cable.
    • If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
결론
다른 2077명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,970 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,299개 작성하였습니다
댓글 224개
If the adhesive breaks without releasing, and you need to use a spudger or similiar to remove the battery, be VERY careful not to damage the Upper Component Cable.
https://d3nevzfk7ii3be.cloudfront.net/ig...
Dave - 답글
This should've been included in the repair guide, as the adhesive tabs seemed designed to break. My phone is now in worse shape than it was and I'm facing what seems to be an extremely difficult repair, which I will probably not undertake.
winternick -
A couple of additional pointers might be helpful...
1: I did not get all of the adhesive out from under the battery. As a result, I bent the heck out of the battery & ordered a new one, not trusting a bent one. A mention of whether it would be safe would be nice.
2: I found it impossible to get the clip from step 7 back on. I left it off. If there's a trick to this, it would be nice to have that extra instruction with the reassembly instructions, rather than "reverse order."
3: While this is always a good idea, in the process of trying to get something done, it's easy to forget that you need to remember which screws go back where, especially the 3 different-sized screws from step 10. What an evil thing Apple did there! I laid the bracket upside-down on a piece of tape, and oriented the screws around it so I'd know where they go back upon reassembly a week later. A suggestion of doing something like this might be helpful.
4: I love my iFixit toolkits! But including a pair of tweezers in it would be helpful.
datamaestro - 답글
2. I found this piece "snapped" into place reasonably easily, but I was careful to get the orientation correct & make sure the edge against the battery pull was "in under" (for lack of a better term) and not trying to squash the battery pull down.
Hope this helps.
Dave -
1. With regards to the bent battery, you were right to replace it. LiOn Batteries are very dangerous when the cells inside are compromised. Even though the good ones have circuit breakers built in to prevent fire, they can fail. A LiOn battery - even a small one in an iPhone - can go "high order" and cause a fire that is next to impossible to extinguish. A brief search on YouTube for Lithium Ion Battery fires will quickly convince even the skeptical.
2. The way I keep track of screws... Get a complete set of all colors of Sharpie pens. When disassembling, I touch the screw head with the same color pen as the circle in the iFixit Guide. Then when reassembling I know where the green, orange, red, & blue screws go!
Pete H -
댓글 쓰기
조회 통계:
24 시간 전: 66
7일 전: 489
30일 전: 2,395
전체 시간: 1,417,935
