소개
Follow this guide to replace the battery on your Microsoft Surface Pro 7.
If your battery is swollen, take appropriate precautions.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to apply adequate heat and be extremely careful while slicing through the adhesive. Wear safety glasses in case the glass shatters.
Optional motherboard removal: This battery guide shows how to remove the motherboard, which prevents it from being damaged as you pry out the battery. If you choose not to remove the motherboard, you can skip steps 30-48. If you leave the motherboard in:
- Be careful not to pry against the motherboard when
- Tilt the device when you apply adhesive remover so that it won’t pool under the motherboard
필요한 것
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the Surface’s display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Heat an iOpener and apply it to the right edge of the Surface's screen for two minutes.
Take note of the screen adhesive layout before continuing:
These areas only contain adhesive and are safe to cut.
The display board and flex cables sit here close to the edge. Cut carefully and do not insert the pick more than 1/8 inch (3 mm).
Fragile antenna cables lie under this part of the screen. Carefully follow the procedure in step 13 to avoid damaging them. The adhesive is also the thickest here.
Insert an opening pick into the speaker opening on the screen and slide the pick between the glass and speaker grille.
Rotate the pick toward the bottom of the Surface to slide it underneath the lower edge of the speaker cutout.
Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
Leave this opening pick in the right edge to prevent the adhesive from resealing.
Reheat your iOpener and apply it to the bottom edge of the Surface's screen for two minutes.
Insert the point of a pick under the display where you just stopped cutting. Do not insert the pick deeper than the edge of the bezel.
Carefully roll the pick to the right, pressing the long edge of the pick into the screen adhesive underneath the bezel, cutting the adhesive as you go. Do not slide the pick along the edge of the Surface.
Repeat this motion of inserting the point of the pick where you just cut, and rolling to the right all along the top edge of the Surface, until the pick is 2.5 inches (64 mm) from the right edge of the Surface.
Very slowly lift the screen assembly away from the Surface case. If you encounter any resistance, stop and check that all the adhesive is separated.
Use an opening pick to cut through any remaining adhesive.
Use the pointed tip of a spudger to carefully push on each side of the battery connector.
Alternating from one side to the other, gently “walk” the connector out of its socket.
Use a pair of tweezers to peel back the silver tape covering the left display cable connector.
Insert the flat end of a spudger underneath the tape and pry up on the connector to disconnect it from the motherboard.
Use a T3 Torx screwdriver to remove the four 2.4 mm screws securing the EMI shield.
Use an opening tool to pry up on the edge of the EMI shield covering the microSD card reader connector and remove it from the motherboard.
Use the flat end of a spudger to lift the flap that secures the Surface Connect port connector.
Use a T5 Torx screwdriver to remove the following two screws from the right speaker:
One 6.0 mm screw
One 3.8 mm screw
Use the flat end of a spudger to pry up and disconnect all three camera connectors from the motherboard.
이 단계에 사용된 도구:Tweezers$4.99
Use a pair of tweezers to disconnect the antenna cable covering the front-facing camera ribbon cables.
Move the antenna cable out of the way.
Use the flat end of a spudger to flip up the white plastic locking flap of the ZIF connector at the top-left corner of the motherboard.
Use your fingers or a pair of tweezers to pull the cable out.
Use a T3 Torx screwdriver to remove the following three screws securing the motherboard:
Two 2.4 mm screws
One 2.3 mm flanged screw
Prop the top edge of the Surface up a couple inches so the whole Surface slopes toward the bottom edge.
Apply adhesive remover or high-concentration (90% or higher) isopropyl alcohol underneath the the battery along the top edge.
Let the adhesive remover sit and soak into the adhesive for 2–3 minutes before continuing.
이 단계에 사용된 도구:Plastic Cards$2.99
Slide a plastic card under the right side of the top edge of the battery.
Slide the card side to side under the upper right battery cell to slice through the adhesive underneath.
Slide a plastic card under the right side of the bottom edge of the battery.
Slide the card side to side under the bottom right battery cell to slice through the adhesive underneath.
Repeat the previous two steps for the left side of the battery to release the two left cells from their adhesive.
For optimal performance, calibrate your newly installed battery after completing this guide.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 한 개
I have 17 surface pros that I need this done to. Can you recommend a repair facility?
