주요 콘텐츠로 건너뛰기
Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement
Alex Diaz-Kokaisl
Alex Diaz-Kokaisl3 다른 기여자
최종 수정일 March 1, 2025
1 - 3 시간
조정
Follow this guide to replace the screen and battery assembly on your Samsung Galaxy S23 Ultra.
This guide is written for the screen and battery assembly. The assembly consists of the screen, battery, and frame together in one part. Be sure you have the right part before you begin the repair.
Note: Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
필요한 것
수리 키트
이 키트는 이 안내서를 완료하는데 필요한 모든 부품과 도구를 포함하고 있습니다.
부품
도구
더보기...
  1. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Heat the right edge: 2 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Adhesive information: 3 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Adhesive information: 3 단계, 이미지 2개 중 2개
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  4. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 3개
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  5. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the right adhesive: 5 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the right adhesive: 5 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the right adhesive: 5 단계, 이미지 3개 중 3개
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  6. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Heat the bottom edge: 6 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  7. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: 7 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: 7 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: 7 단계, 이미지 3개 중 3개
    • Insert a second opening pick at the bottom right corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
    • Be careful while working around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
  8. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the bottom adhesive: 8 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the bottom adhesive: 8 단계, 이미지 2개 중 2개
    • Slide your opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  9. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Heat the left edge: 9 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  10. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: 10 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: 10 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: 10 단계, 이미지 3개 중 3개
    • Insert a third opening pick at the bottom left corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
  11. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the left adhesive: 11 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the left adhesive: 11 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the left adhesive: 11 단계, 이미지 3개 중 3개
    • Slide your opening pick along the left edge to separate the adhesive, stopping when you reach the power button.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in the left edge to prevent the adhesive from resealing.
  12. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Heat the top edge: 12 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  13. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: 13 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: 13 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: 13 단계, 이미지 3개 중 3개
    • Insert an opening pick in the gap at the top right edge.
    • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  14. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the top adhesive: 14 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the top adhesive: 14 단계, 이미지 2개 중 2개
    • Slide the pick to the top left corner to separate the adhesive.
    • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
    • Leave the pick in to prevent the adhesive from resealing.
  15. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: 15 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the corner adhesive: 15 단계, 이미지 2개 중 2개
    • Insert an opening pick in the gap at the top left edge.
    • Only insert the pick up to 4 mm, as you may damage the cameras.
    • Angle the pick upward to match the curved edge and rotate it around the top left corner.
  16. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the remaining adhesive: 16 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the remaining adhesive: 16 단계, 이미지 2개 중 2개
    • Slide the pick toward the bottom camera to separate through the remaining adhesive, stopping before you reach the power button.
  17. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the back cover: 17 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the back cover: 17 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the back cover: 17 단계, 이미지 3개 중 3개
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  18. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the NFC antenna and charging coil: 18 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the NFC antenna and charging coil: 18 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the NFC antenna and charging coil: 18 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger to pry up and disconnect the NFC antenna press connector from the motherboard.
    • Repeat for the wireless charging coil press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  19. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the coil adhesive: 19 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the coil adhesive: 19 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Separate the coil adhesive: 19 단계, 이미지 3개 중 3개
    • The wireless charging coil is lightly adhered to the battery.
    • Insert an opening pick between the right edge of the wireless charging coil and the battery.
    • Slide the pick along the right edge to separate the adhesive.
  20. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: 20 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: 20 단계, 이미지 2개 중 2개
    • Insert an opening pick between the top edge of the wireless charging coil and the frame.
    • Slide the pick toward the right edge to separate the remaining adhesive.
  21. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unfasten the NFC antenna and charging coil: 21 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the five 3.5 mm-long screws securing the NFC antenna and charging coil.
  22. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unfasten the loudspeaker: 22 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the six 3.5 mm screws securing the loudspeaker.
  23. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unclip the loudspeaker: 23 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unclip the loudspeaker: 23 단계, 이미지 2개 중 2개
    • Insert the pointed end of your spudger between the upper right corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
  24. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the charging coil and loudspeaker assembly: 24 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the charging coil and loudspeaker assembly: 24 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the charging coil and loudspeaker assembly: 24 단계, 이미지 3개 중 3개
    • Grab and remove the NFC, wireless charging coil, and loudspeaker from the frame.
  25. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the battery: 25 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the battery: 25 단계, 이미지 2개 중 2개
    • Use your spudger to pry up and disconnect the battery press connector.
  26. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the interconnect cables: 26 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the interconnect cables: 26 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the interconnect cables: 26 단계, 이미지 3개 중 3개
    • Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the motherboard.
    • Repeat for the primary interconnect cable.
  27. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: 27 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: 27 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: 27 단계, 이미지 3개 중 3개
    • Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the charging board.
  28. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the interconnect cables: 28 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the interconnect cables: 28 단계, 이미지 2개 중 2개
    • Grab and remove the interconnect cables from the frame.
  29. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unfasten the charging board: 29 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three 3.5 mm-long screws securing the charging board.
  30. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the charging board: 30 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the charging board: 30 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the charging board: 30 단계, 이미지 3개 중 3개
    • Insert the point of your spudger under the top right of the charging board.
    • Pry the charging board up from its recess until you can grab it with your fingers.
    • Pull the charging board toward the top of the device to remove it from its recess.
    • During reassembly, reinsert the charging board at a downward angle to guide the USB-C port into its recess.
  31. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the earpiece speaker: 31 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the earpiece speaker: 31 단계, 이미지 2개 중 2개
    • Use the point of your spudger to pry up and disconnect the earpiece speaker press connector.
  32. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unfasten the motherboard cover: 32 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the five 3.5 mm-long screws securing the motherboard cover.
  33. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the motherboard cover: 33 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the motherboard cover: 33 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the motherboard cover: 33 단계, 이미지 3개 중 3개
    • Insert the point of your spudger between the bottom right corner of the motherboard cover and the frame.
    • Pry up on the cover to unclip it from the frame.
    • Remove the motherboard cover.
    • During reassembly, press down on the cover to secure its clips to the frame.
  34. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the front-facing camera: 34 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the front-facing camera: 34 단계, 이미지 2개 중 2개
    • Use the point of your spudger to pry up and disconnect the front-facing camera press connector.
  35. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the fingerprint reader: 35 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the fingerprint reader: 35 단계, 이미지 2개 중 2개
    • Use your spudger to pry up and disconnect the fingerprint reader press connector.
  36. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the screen: 36 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the screen: 36 단계, 이미지 2개 중 2개
    • Use the point of your spudger to pry up and disconnect the screen press connector from the motherboard.
  37. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: 37 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: 37 단계, 이미지 2개 중 2개
    • Use the point of your spudger to pry up and disconnect the screen press connector from the display cutout near the bottom of the phone.
  38. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the screen cable: 38 단계, 이미지 1개 중 1개
    • Grab and remove the screen cable from the frame.
  39. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the right 5G mmWave antenna: 39 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the right 5G mmWave antenna: 39 단계, 이미지 2개 중 2개
    • Use the point of your spudger to pry up and disconnect the right 5G mmWave antenna press connector.
  40. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the stylus: 40 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the stylus: 40 단계, 이미지 2개 중 2개
    • Use the point of your spudger to pry up and disconnect the stylus press connector.
  41. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the left 5G mmWave antenna: 41 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Disconnect the left 5G mmWave antenna: 41 단계, 이미지 2개 중 2개
    • Use the point of your spudger to pry up and disconnect the left 5G mmWave antenna press connector.
  42. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unfasten the motherboard: 42 단계, 이미지 1개 중 1개
    • Use your Phillips screwdriver to remove the single 4 mm-long screw securing the motherboard.
  43. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the motherboard: 43 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the motherboard: 43 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the motherboard: 43 단계, 이미지 3개 중 3개
    • Insert the point of your spudger between the top left of the motherboard and the frame.
    • Pry the motherboard up until you can grab it with your fingers.
    • Grab the motherboard and remove it from the frame.
    • Be careful not to snag any loose cables.
    • During reassembly, make sure the cables are above the motherboard when reinserting it.
  44. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Heat the front-facing camera: 44 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the top of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
  45. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Pry the front-facing camera: 45 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Pry the front-facing camera: 45 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Pry the front-facing camera: 45 단계, 이미지 3개 중 3개
    • The adhesive securing the camera is very strong. Work slowly and apply more heat if the camera feels stuck. Avoid separating the circuit board from camera housing, such as this.
    • Use the flat end of your spudger to pry the front-facing camera from its recess.
    • If the camera doesn't loosen, use your SIM card eject tool to scrape away the epoxy surrounding the camera.
  46. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Prepare the new frame: 46 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Prepare the new frame: 46 단계, 이미지 2개 중 2개
    • During reassembly, prepare your new frame for the front-facing camera:
    • Remove the black adhesive liner from the front-facing camera recess.
    • Peel and remove the foam liner from the new frame.
    • This liner isn't necessary for the repair.
  47. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Apply new adhesive: 47 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Apply new adhesive: 47 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Apply new adhesive: 47 단계, 이미지 3개 중 3개
    • Before installing the front-facing camera in your new frame, apply new adhesives onto the frame and the camera:
    • Remove the two large clear rectangular liners from the adhesive sheet and place the adhesives on the sides of the camera recess.
    • Remove the liner from the main adhesive piece and place it in the center of the camera recess with its pull tab facing the bottom of the frame.
    • Remove any adhesive residue from the front-facing camera module.
    • Remove the liner from the thin piece of adhesive and place it on the top edge of the camera.
  48. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Install the front-facing camera: 48 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Install the front-facing camera: 48 단계, 이미지 2개 중 2개
    • Install the front-facing camera:
    • Remove all four blue adhesive liners from the camera and the frame.
    • Insert the front-facing camera into its recess in the frame and apply pressure to secure it.
  49. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Unfasten the left 5G mmWave antenna: 49 단계, 이미지 1개 중 1개
    • Use a Phillips driver to remove the two 2.4 mm‑long screws securing the left 5G mmWave antenna.
  50. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the left 5G mmWave antenna: 50 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the left 5G mmWave antenna: 50 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the left 5G mmWave antenna: 50 단계, 이미지 3개 중 3개
    • Grab the left 5G mmWave antenna connector and lift up to separate the bracket from the frame.
    • Remove the antenna.
  51. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, mmWave antenna reassembly: 51 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, mmWave antenna reassembly: 51 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, mmWave antenna reassembly: 51 단계, 이미지 3개 중 3개
    • Before reinstalling the lower 5G mmWave antenna, replace the bracket with a new one. If you don't have a new bracket, skip this step.
    • Remove the antenna and connector from the old bracket.
    • Remove the L-shaped adhesive liner from your new bracket.
    • Place the antenna in the bracket's recess with the connector fed underneath the longer screw mount.
    • Remove the thin adhesive liner on the outside of the bracket before installing it in the frame.
  52. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the right 5G mmWave antenna: 52 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the right 5G mmWave antenna: 52 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Remove the right 5G mmWave antenna: 52 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger between the frame and the right 5G mmWave antenna connector.
    • Pry up with the spudger to separate the adhesive.
  53. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: 53 단계, 이미지 2개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement: 53 단계, 이미지 2개 중 2개
    • Grab and remove the right 5G mmWave antenna from the frame.
  54. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Upper 5G mmWave antenna reassembly information: 54 단계, 이미지 3개 중 1개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Upper 5G mmWave antenna reassembly information: 54 단계, 이미지 3개 중 2개 Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Upper 5G mmWave antenna reassembly information: 54 단계, 이미지 3개 중 3개
    • Replace the adhesive on the upper 5G mmWave antenna before reinstalling it. If you don't have replacement adhesive, reuse your old one or use custom-cut adhesive.
    • Remove the existing adhesive from the antenna with blunt nose tweezers or your fingers.
    • Remove the clear liner from your new adhesive.
    • Apply the new adhesive to the bottom of the antenna, with its round end farthest from the connector.
    • Remove the green liner from the adhesive before reinstalling the antenna in the frame.
  55. Samsung Galaxy S23 Ultra Screen and Battery Assembly Replacement, Only the screen and battery assembly remains: 55 단계, 이미지 1개 중 1개
    • You're now left with the screen and battery assembly.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
163,333 평판
안내서 769개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,560개를 작성함
댓글 2개
Can you share a propper way to change the screen
Muzakkir - 답글
Hola, compre une caisse completo para remplazar la pantalla, pero en el lugar de la pantalla tengo los revestimientos adhesivos azules de la cámara, como lo quito? por favor una ayuda
Efrain Luna - 답글
댓글 쓰기
조회 통계:
지난 24시간: 29
지난 7일: 242
지난 30일: 1,068
전체 시간: 18,966
