주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPad 6 Wi-Fi LCD Replacement
필요한 것
    1. iPad 6 Wi-Fi LCD Replacement, Heat the left edge: 1 단계, 이미지 1개 중 1개
      • Heat an iOpener and apply it to the left edge of the device for two minutes.
      댓글 쓰기
    2. iPad 6 Wi-Fi LCD Replacement, Screen removal information: 2 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement, Screen removal information: 2 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement, Screen removal information: 2 단계, 이미지 3개 중 3개
      • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
      • Front camera
      • Antennas
      • Display cables
      댓글 쓰기
    3. iPad 6 Wi-Fi LCD Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      댓글 쓰기
    4. iPad 6 Wi-Fi LCD Replacement: 4 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement: 4 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement: 4 단계, 이미지 3개 중 3개
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      댓글 쓰기
    5. iPad 6 Wi-Fi LCD Replacement: 5 단계, 이미지 2개 중 1개 iPad 6 Wi-Fi LCD Replacement: 5 단계, 이미지 2개 중 2개
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      댓글 쓰기
    6. iPad 6 Wi-Fi LCD Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 3개
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
      • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
      • Insert an opening pick into the gap between the digitizer and the frame.
      댓글 쓰기
    7. iPad 6 Wi-Fi LCD Replacement, Separate the left adhesive: 7 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement, Separate the left adhesive: 7 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement, Separate the left adhesive: 7 단계, 이미지 3개 중 3개
      • Insert a second opening pick into the gap you just created.
      • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
      • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
      • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
      댓글 쓰기
    8. iPad 6 Wi-Fi LCD Replacement: 8 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement: 8 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement: 8 단계, 이미지 3개 중 3개
      • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
      댓글 쓰기
    9. iPad 6 Wi-Fi LCD Replacement: 9 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement: 9 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement: 9 단계, 이미지 3개 중 3개
      • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
      • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
      댓글 쓰기
    10. iPad 6 Wi-Fi LCD Replacement, Heat the top edge: 10 단계, 이미지 1개 중 1개
      • Heat an iOpener and apply it to the top edge of the device for two minutes.
      댓글 쓰기
    11. iPad 6 Wi-Fi LCD Replacement, Separate the top left adhesive: 11 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement, Separate the top left adhesive: 11 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement, Separate the top left adhesive: 11 단계, 이미지 3개 중 3개
      • Rotate the pick around the top-left corner of the device to separate the adhesive.
      댓글 쓰기
    12. iPad 6 Wi-Fi LCD Replacement, Separate the top adhesive: 12 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement, Separate the top adhesive: 12 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement, Separate the top adhesive: 12 단계, 이미지 3개 중 3개
      • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
      • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
      댓글 쓰기
    13. iPad 6 Wi-Fi LCD Replacement: 13 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement: 13 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement: 13 단계, 이미지 3개 중 3개
      • Pull the pick out until only the tip is between the digitizer and the frame.
      • Slide the pick above the front camera to separate the adhesive.
      • Leave the pick near the right side of the front camera before continuing.
      댓글 쓰기
    14. iPad 6 Wi-Fi LCD Replacement: 14 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement: 14 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement: 14 단계, 이미지 3개 중 3개
      • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
      • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
      댓글 쓰기
    15. iPad 6 Wi-Fi LCD Replacement, Heat the right edge: 15 단계, 이미지 1개 중 1개
      • Heat an iOpener and apply it to the right edge of the device for two minutes.
      댓글 쓰기
    16. iPad 6 Wi-Fi LCD Replacement, Separate the top right adhesive: 16 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement, Separate the top right adhesive: 16 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement, Separate the top right adhesive: 16 단계, 이미지 3개 중 3개
      • Rotate the pick around the top-right corner of the device to separate the adhesive.
      댓글 쓰기
    17. iPad 6 Wi-Fi LCD Replacement, Separate the right adhesive: 17 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement, Separate the right adhesive: 17 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement, Separate the right adhesive: 17 단계, 이미지 3개 중 3개
      • Insert a new opening pick and slide it to the middle of the iPad's right edge.
      • Stop sliding once you reach five inches from the bottom of the iPad to avoid damaging the display cables.
      댓글 쓰기
    18. iPad 6 Wi-Fi LCD Replacement, Heat the bottom edge: 18 단계, 이미지 1개 중 1개
      • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
      댓글 쓰기
    19. iPad 6 Wi-Fi LCD Replacement, Separate the bottom left adhesive: 19 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement, Separate the bottom left adhesive: 19 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement, Separate the bottom left adhesive: 19 단계, 이미지 3개 중 3개
      • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
      • Don't fully rotate the pick around the corner, as you may damage the antenna.
      • Leave the pick in the bottom-left corner before moving to the next step.
      댓글 쓰기
    20. iPad 6 Wi-Fi LCD Replacement, Separate the bottom adhesive: 20 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement, Separate the bottom adhesive: 20 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement, Separate the bottom adhesive: 20 단계, 이미지 3개 중 3개
      • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
      • Slide the pick over the antenna, stopping just before the home button.
      • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
      • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
      • Leave the pick to the left of the home button before continuing.
      댓글 쓰기
    21. iPad 6 Wi-Fi LCD Replacement: 21 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement: 21 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement: 21 단계, 이미지 3개 중 3개
      • Insert an opening pick into the gap you just created.
      • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
      • Only insert the pick up to 1 mm to avoid damaging the right antenna.
      댓글 쓰기
    22. iPad 6 Wi-Fi LCD Replacement: 22 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement: 22 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement: 22 단계, 이미지 3개 중 3개
      • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
      • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
      • Leave the pick to the right of the home button before continuing.
      댓글 쓰기
    23. iPad 6 Wi-Fi LCD Replacement, Heat the right edge: 23 단계, 이미지 1개 중 1개
      댓글 쓰기
    24. iPad 6 Wi-Fi LCD Replacement: 24 단계, 이미지 2개 중 1개 iPad 6 Wi-Fi LCD Replacement: 24 단계, 이미지 2개 중 2개
      • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
      • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
      • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
      댓글 쓰기
    25. iPad 6 Wi-Fi LCD Replacement: 25 단계, 이미지 2개 중 1개 iPad 6 Wi-Fi LCD Replacement: 25 단계, 이미지 2개 중 2개
      • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
      댓글 쓰기
    26. iPad 6 Wi-Fi LCD Replacement, Separate the right adhesive: 26 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement, Separate the right adhesive: 26 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement, Separate the right adhesive: 26 단계, 이미지 3개 중 3개
      • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
      댓글 쓰기
    27. iPad 6 Wi-Fi LCD Replacement: 27 단계, 이미지 2개 중 1개 iPad 6 Wi-Fi LCD Replacement: 27 단계, 이미지 2개 중 2개
      • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
      • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
      • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
      댓글 쓰기
    1. iPad 6 Wi-Fi LCD Replacement, LCD: 28 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement, LCD: 28 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement, LCD: 28 단계, 이미지 3개 중 3개
      • Remove any tape obscuring the LCD screws.
      댓글 쓰기
    2. iPad 6 Wi-Fi LCD Replacement: 29 단계, 이미지 1개 중 1개
      • Remove the four Phillips #00 4.3 mm screws securing the LCD.
      댓글 쓰기
    3. iPad 6 Wi-Fi LCD Replacement: 30 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement: 30 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement: 30 단계, 이미지 3개 중 3개
      • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
      • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers. There may be glue around the screw holes that needs to be cut with a knife.
      • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
      • Be gentle and keep an eye on the LCD cables as you flip the display over.
      • Lay the LCD on its face to allow access to the display cables.
      • Set the LCD down on a soft, clean, lint-free surface.
      댓글 쓰기
    4. iPad 6 Wi-Fi LCD Replacement, Battery connector information: 31 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement, Battery connector information: 31 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement, Battery connector information: 31 단계, 이미지 3개 중 3개
      • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
      • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
      댓글 쓰기
    5. iPad 6 Wi-Fi LCD Replacement: 32 단계, 이미지 3개 중 1개 iPad 6 Wi-Fi LCD Replacement: 32 단계, 이미지 3개 중 2개 iPad 6 Wi-Fi LCD Replacement: 32 단계, 이미지 3개 중 3개
      • Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board.
      • To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
      • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
      • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
      • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at a 15 degree angle.
      • Leave the battery blocker in place as you work.
      댓글 쓰기
    6. iPad 6 Wi-Fi LCD Replacement: 33 단계, 이미지 1개 중 1개
      • Remove the three 1.4 mm Phillips #000 screws from the display cable bracket.
      댓글 쓰기
    7. iPad 6 Wi-Fi LCD Replacement: 34 단계, 이미지 2개 중 1개 iPad 6 Wi-Fi LCD Replacement: 34 단계, 이미지 2개 중 2개
      • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
      • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
      댓글 쓰기
    8. iPad 6 Wi-Fi LCD Replacement: 35 단계, 이미지 1개 중 1개
      • Remove the LCD.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 28명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
477,759 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 36,998개를 작성함
12가이드 댓글
No comments…. No one is brave enough to attempt this :)
Tal Glazer - 답글 공유
I tried to replace the LCD with the iPad AIR 1 LCD and is NOT compatible. It fits and the connector is the same but shows just like tv static noise.
nazareno valentini - 답글 공유
I have same issue, but with LCD iPad 5, some idea to make it compatible.
Luis Prieto - 답글 공유
I replaced the front screen and now the number 9 on the passcode keypad isn’t working. I don’t get it.
Richard Lombardo - 답글 공유
I’m having the same issue! Different numbers, but same issue. Just certain sections of the screen won’t respond to touch.
Adriane Zaic - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 76
지난 30일: 256
전체 시간: 41,261
