주요 콘텐츠로 건너뛰기
iPad Pro 11" 2nd Gen Screen Replacement
필요한 것
  1. iPad Pro 11" 2nd Gen Screen Replacement, Prepare your iPad for disassembly: 1 단계, 이미지 1개 중 1개
    • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Unplug any cables and fully shut down your iPad.
  2. iPad Pro 11" 2nd Gen Screen Replacement, Screen removal information: 2 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Screen removal information: 2 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Screen removal information: 2 단계, 이미지 3개 중 3개
    • While your iPad looks uniform from the outside, there are delicate components under portions of the screen. To avoid damage, follow instructions exactly as written and note the following areas as you open your iPad:
    • Camera module, ambient light sensors, proximity senor, and front microphone
    • Display cables
    • Screen magnets
    • LCD edges
  3. iPad Pro 11" 2nd Gen Screen Replacement, Heat the right edge: 3 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the screen and/or internal battery, so proceed with care.
  4. iPad Pro 11" 2nd Gen Screen Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backward to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  5. iPad Pro 11" 2nd Gen Screen Replacement: 5 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement: 5 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPad Pro 11" 2nd Gen Screen Replacement: 6 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  7. iPad Pro 11" 2nd Gen Screen Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Insert an opening pick: 7 단계, 이미지 3개 중 3개
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken display.
    • Apply a suction handle to the right edge of the display, about 5 cm from the bottom edge.
    • Pull up on the suction handle with firm, constant pressure to create a gap just small enough to insert an opening pick.
    • Only create a gap small enough to insert an opening pick. Overbending the screen will damage it.
    • Insert the tip of an opening pick into the gap.
    • Don't insert the opening pick more than 5 mm or you'll damage the LCD.
  8. iPad Pro 11" 2nd Gen Screen Replacement, Separate the right edge adhesive: 8 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Separate the right edge adhesive: 8 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Separate the right edge adhesive: 8 단계, 이미지 3개 중 3개
    • Insert a new opening pick in the gap you just created.
    • Slide the pick along the right edge to separate the adhesive.
    • When sliding near the volume buttons, don't insert the pick more than 2 mm or you'll damage the screen magnets.
    • Leave the pick in the top right corner to prevent the adhesive from re-sealing.
  9. iPad Pro 11" 2nd Gen Screen Replacement, Heat the top edge: 9 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  10. iPad Pro 11" 2nd Gen Screen Replacement, Top edge information: 10 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Top edge information: 10 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Top edge information: 10 단계, 이미지 3개 중 3개
    • The top edge of the iPad contains the camera module, two ambient light sensors, the proximity sensor, and front microphone. These components are fragile and easily damaged if an opening pick is inserted too far. Only separate the adhesive in the marked locations to avoid damage.
    • The two ambient light sensors can be hard to see and can be located using a flashlight or by placing the iPad under a bright light.
    • Don't insert an opening pick more than 2 mm near the top left and right edges or you'll damage the ambient light sensors.
    • Don't insert an opening pick more than 1 mm near the middle of the top edge or you'll damage the camera module, proximity sensor, and front microphone.
  11. iPad Pro 11" 2nd Gen Screen Replacement, Separate the top edge adhesive: 11 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Separate the top edge adhesive: 11 단계, 이미지 2개 중 2개
    • Slide the pick along the top right edge, stopping when you reach the right ambient light sensor.
    • Don't insert the opening pick more than 5 mm.
    • Leave the pick to the right of the sensor to prevent the adhesive from re-sealing.
  12. iPad Pro 11" 2nd Gen Screen Replacement: 12 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement: 12 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement: 12 단계, 이미지 3개 중 3개
    • Insert a new opening pick to the right of the ambient light sensor.
    • Slide the pick along the middle section of the top, stopping when you reach the left ambient light sensor.
    • Don't insert the pick more than 1 mm or you'll damage the proximity sensor and front microphone.
    • Leave the pick in to prevent the adhesive from re-sealing.
  13. iPad Pro 11" 2nd Gen Screen Replacement: 13 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement: 13 단계, 이미지 2개 중 2개
    • Insert a new opening pick to the left of the ambient light sensor.
    • Slide the pick along the top left edge, stopping when you reach the left ambient light sensor.
    • Once the top edge adhesive has been separated, you can remove the two picks near the ambient light sensors.
  14. iPad Pro 11" 2nd Gen Screen Replacement, Heat the bottom edge: 14 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  15. iPad Pro 11" 2nd Gen Screen Replacement, Separate the bottom edge adhesive: 15 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Separate the bottom edge adhesive: 15 단계, 이미지 2개 중 2개
    • Insert a new opening pick in the bottom right corner below the existing pick.
    • Don't insert the opening pick more than 2 mm when sliding on the right edge.
    • Slide the pick around the bottom right corner to separate the adhesive.
  16. iPad Pro 11" 2nd Gen Screen Replacement: 16 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Slide the opening pick along the bottom edge, stopping at the USB-C port.
    • Don't insert the opening pick more than 5 mm when separating the bottom edge adhesive.
    • Leave the pick in to prevent the bottom edge adhesive from re-sealing.
  17. iPad Pro 11" 2nd Gen Screen Replacement: 17 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement: 17 단계, 이미지 2개 중 2개
    • Insert a new opening pick to the left of the USB-C port.
    • Separate the remaining bottom edgeadhesive.
    • Leave the pick in the bottom left corner to prevent the bottom edge adhesive from re-sealing.
  18. iPad Pro 11" 2nd Gen Screen Replacement, Heat the left edge: 18 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  19. iPad Pro 11" 2nd Gen Screen Replacement, Left edge information: 19 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Left edge information: 19 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Left edge information: 19 단계, 이미지 3개 중 3개
    • The left edge of the iPad contains several display cables. These cables are extremely fragile and easily damaged if an opening pick is inserted too far or at the wrong angle. Follow the instructions exactly as written to avoid damage.
    • The display cables are located within small indents of the frame and require an opening pick to be inserted at a 45° angle.
    • There are flat sections of the frame which require an opening pick to be inserted horizontally.
  20. iPad Pro 11" 2nd Gen Screen Replacement, Separate the left edge adhesive: 20 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Separate the left edge adhesive: 20 단계, 이미지 2개 중 2개
    • Insert an opening pick at a 45˚ angle just above the bottom left corner.
    • Don't insert the pick more than 5 mm or you'll damage the display cables.
    • Carefully slide the pick along the left edge, stopping when you reach the flat section of the frame.
  21. iPad Pro 11" 2nd Gen Screen Replacement: 21 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement: 21 단계, 이미지 2개 중 2개
    • Lower the opening pick so it is horizontal to the display.
    • Don't insert the pick more than 5 mm.
    • Continue separating the left edge adhesive until you reach the next indented section of the frame.
  22. iPad Pro 11" 2nd Gen Screen Replacement, Separate the remaining adhesive: 22 단계, 이미지 1개 중 1개
    • Separate the remaining adhesive, making sure to follow the instructions exactly as written.
    • Slide the pick at a 45˚ downward angle and don't insert the pick more than 5 mm.
    • Slide the pick horizontally and don't insert the pick more than 5 mm.
  23. iPad Pro 11" 2nd Gen Screen Replacement, Separate the screen from the frame: 23 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Separate the screen from the frame: 23 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Separate the screen from the frame: 23 단계, 이미지 3개 중 3개
    • Grab two opposing corners of the screen and gently separate the rest of the adhesive.
    • Don't fully remove the screen as it is held in place by several ribbon cables underneath.
    • Shift the screen towards the bottom right corner of the frame until the ambient light sensor ribbon cable near the top edge is uncovered.
  24. iPad Pro 11" 2nd Gen Screen Replacement, Unscrew the ambient light sensor cable bracket: 24 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Unscrew the ambient light sensor cable bracket: 24 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $36.95
    • Use a Phillips screwdriver to remove the two screws securing the ambient light sensor cable bracket to the logic board:
    • One 1.3 mm screw
    • One 2.0 mm screw
    • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
  25. iPad Pro 11" 2nd Gen Screen Replacement, Remove the ambient light sensor cable bracket: 25 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers or your fingers to remove the bracket.
  26. iPad Pro 11" 2nd Gen Screen Replacement, Disconnect the ambient light sensor cable: 26 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Disconnect the ambient light sensor cable: 26 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connectors.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  27. iPad Pro 11" 2nd Gen Screen Replacement, Reposition the screen: 27 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Reposition the screen: 27 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Reposition the screen: 27 단계, 이미지 3개 중 3개
    • Don't try to remove the screen yet, as it's still attached by delicate ribbon cables.
    • Grip the right edge of the screen and fold it open like a book.
    • Lay the screen down over the left edge of the iPad.
  28. iPad Pro 11" 2nd Gen Screen Replacement, Unfasten the lower cable shield: 28 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Unfasten the lower cable shield: 28 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the three 1.2 mm screws securing the lower cable shield to the logic board.
  29. iPad Pro 11" 2nd Gen Screen Replacement, Remove the lower cable shield: 29 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Remove the lower cable shield: 29 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Remove the lower cable shield: 29 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the lower cable shield.
  30. iPad Pro 11" 2nd Gen Screen Replacement, Disconnect the display cables: 30 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Disconnect the display cables: 30 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Disconnect the display cables: 30 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger to pry up and disconnect the top two display cables.
  31. iPad Pro 11" 2nd Gen Screen Replacement, Disconnect the remaining display cables: 31 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Disconnect the remaining display cables: 31 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Disconnect the remaining display cables: 31 단계, 이미지 3개 중 3개
    • Disconnect the two remaining display cables.
  32. iPad Pro 11" 2nd Gen Screen Replacement, Remove the screen: 32 단계, 이미지 1개 중 1개
    • Grip the right edge of the screen and lift it away.
    • During reassembly, before installing a screen, remove any remaining adhesive from the frame, and clean the glued areas with high-strength (>90%) isopropyl alcohol and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • If you plan to reinstall your existing screen, remove any remaining adhesive from the back and clean the adhered areas with isopropyl alcohol.
    • Follow this guide to install pre-cut adhesive strips on your iPad before sealing it up.
  33. iPad Pro 11" 2nd Gen Screen Replacement, LiDAR sensor assembly information: 33 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, LiDAR sensor assembly information: 33 단계, 이미지 2개 중 2개
    • The LiDAR sensor assembly is paired to the Face ID hardware. You'll need to transfer it to your replacement screen to keep Face ID functionality. The following steps show how to remove the sensor assembly and install it on your replacement screen.
    • The LiDAR sensor assembly is composed of four total sensors:
    • Two ambient light sensors
    • One proximity sensor
    • One microphone
    • You'll need to separate each sensor from the screen before removing the entire assembly.
  34. iPad Pro 11" 2nd Gen Screen Replacement, Heat the top sensor assembly: 34 단계, 이미지 1개 중 1개
  35. iPad Pro 11" 2nd Gen Screen Replacement, Separate the ambient light sensors: 35 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Separate the ambient light sensors: 35 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    $3.99
    • Insert one arm of your angled tweezers between the ambient light sensor and the screen.
    • You can also use a precision knife, but be careful not to damage the ribbon cable.
    • Pry up to separate the sensor from the screen.
    • This might take significant force.
    • Repeat this procedure for the other ambient light sensor.
  36. iPad Pro 11" 2nd Gen Screen Replacement, Separate the proximity sensor: 36 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Separate the proximity sensor: 36 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Separate the proximity sensor: 36 단계, 이미지 3개 중 3개
    • Insert one arm of your angled tweezers between the proximity sensor cable and the screen.
    • Slide the tweezers toward the screen while prying to separate the sensor from the screen.
    • This might take significant force and multiple iOpener heating cycles.
  37. iPad Pro 11" 2nd Gen Screen Replacement, Peel away the tape: 37 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Peel away the tape: 37 단계, 이미지 2개 중 2개
    • Peel off any tape covering the microphone.
    • Set the tape aside. You'll use it during reassembly.
  38. iPad Pro 11" 2nd Gen Screen Replacement, Separate the microphone: 38 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Separate the microphone: 38 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Separate the microphone: 38 단계, 이미지 3개 중 3개
    • Slide an opening tool under the microphone to separate its adhesive.
    • Pry up to separate the microphone from the screen.
  39. iPad Pro 11" 2nd Gen Screen Replacement, Remove the LiDAR sensor assembly: 39 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Remove the LiDAR sensor assembly: 39 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Remove the LiDAR sensor assembly: 39 단계, 이미지 3개 중 3개
    • Slide an opening pick under the LiDAR sensor assembly cable to separate it from the screen.
  40. iPad Pro 11" 2nd Gen Screen Replacement: 40 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement: 40 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement: 40 단계, 이미지 3개 중 3개
    • Continue sliding your opening pick under the LiDAR sensor assembly until it's completely separated from the screen.
    • Remove the LiDAR sensor assembly.
  41. iPad Pro 11" 2nd Gen Screen Replacement: 41 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    • During reassembly, you'll have to perform the following:
    • Align the LiDAR sensor assembly on your replacement screen.
    • Use Tesa tape, or similar double-sided tape, to secure the cables to the screen.
    • Use E6000 adhesive, or similar adhesive, to secure the sensors to their cutouts on the screen.
    • Only apply adhesive to the edges of the sensors. Placing adhesive on the front will break them.
  42. iPad Pro 11" 2nd Gen Screen Replacement, Display cable information: 42 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Display cable information: 42 단계, 이미지 2개 중 2개
    • If your replacement screen didn't come with the two removable display cables, follow the next six steps to remove and transfer these cables.
    • The display cable connectors are located under a bracket near the bottom right corner of the screen.
  43. iPad Pro 11" 2nd Gen Screen Replacement, Separate the non-removable display cable: 43 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Separate the non-removable display cable: 43 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Separate the non-removable display cable: 43 단계, 이미지 3개 중 3개
    • Slide an opening pick under the non-removable display cable to loosen it from the bracket.
  44. iPad Pro 11" 2nd Gen Screen Replacement, Unfasten the display cable bracket: 44 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Unfasten the display cable bracket: 44 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the two 1.2 mm screws securing the display cable bracket.
  45. iPad Pro 11" 2nd Gen Screen Replacement, Remove the display cable bracket: 45 단계, 이미지 2개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Remove the display cable bracket: 45 단계, 이미지 2개 중 2개
    • Remove the display cable bracket.
  46. iPad Pro 11" 2nd Gen Screen Replacement, Disconnect and remove the display cables: 46 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement, Disconnect and remove the display cables: 46 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement, Disconnect and remove the display cables: 46 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up and disconnect the narrow display cable.
    • Remove the narrow display cable. Set it aside for reassembly.
  47. iPad Pro 11" 2nd Gen Screen Replacement: 47 단계, 이미지 3개 중 1개 iPad Pro 11" 2nd Gen Screen Replacement: 47 단계, 이미지 3개 중 2개 iPad Pro 11" 2nd Gen Screen Replacement: 47 단계, 이미지 3개 중 3개
    • Disconnect and remove the wide display cable. Set it aside for reassembly.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 11" 2nd Gen answers community for help.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Chayton Ritter
회원 가입일: 08/21/20
24,883 평판
안내서 105개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,795개를 작성함
2가이드 댓글
Works like a dream! Thank you so much for these precise instructions! The LiDAR, camera, and Face ID are all working again like new! A repairman refused to fix my iPad, even for €400, and the Apple Store told me face-to-face that the 2020 iPad Pro is ‘garbage-vintage’ and I should just buy a new one. Thank you, iFixit.com community, and all the best! Avanti, amici!
Aleksander Gabryś - 답글
I think this guide leaves me a little short changed. I find it unlikely that it is possible to remove the LIDAR assembly according to this guide without damaging it beyond re-use. Also the remounting of the LIDAR assembly could improve with some more guidance.
e Pilot - 답글
댓글 쓰기
조회 통계:
지난 24시간: 43
지난 7일: 374
지난 30일: 1,433
전체 시간: 40,436
