이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
소개
이 안내서를 사용하여 iPhone 13 후면 카메라를 분리하고 교체하세요. 모든 카메라 모듈은 일체형으로 교체됩니다.
필요한 것
분해를 시작하기 전에 iPhone 전원을 꺼주세요.
iPhone 하단 가장자리에 위치한 6.8mm-길이 pentalobe/펜타로브 P2 나사 두 개를 분리하세요.
피크릐 끝에서 3mm를 측정하고 마커로 피크에 표시하세요.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
iPhone 스크린 전체가 덮이도록 투명 포장 테이프를 겹쳐서 붙입니다.
흡입컵이 없는 경우 다음의 몇 단계들을 진행하는 동안, 덕트 테이프와 같은 강력한 테이프 조각을 접어서 손잡이를 만들어 스크린을 들어올립니다.
이 단계에 사용된 도구:Clampy - Anti-Clamp$24.95
파란색 손잡이를 뒤로 당겨 안티-클램프의 팔을 잠금 해제합니다.
팔을 iPhone의 왼쪽 또는 오른쪽 가장자리로 밀어넣습니다.
흡입컵을 iPhone의 하단 가장자리 근처에 놓으세요—하나는 앞에, 다른 하나는 뒤에.
컵을 눌러서 원하는 위치에 부착합니다.
스크린과 프레임 사이에 작은 틈이 생기도록 안정적이고 일정한 압력으로 흡입컵을 위로 당깁니다.
여는 픽을 스크린의 플라스틱 베젤 아래에 생긴 틈으로 끼우세요.
The adhesive on the 13 model is certainly, "very strong." Keep this in mind when performing the repair. I had never opened up an iPhone as recent as the iPhone 13 and this adhesive that Apple uses for the water tight seal is strong. I had not been patient enough when opening my iPhone 13 that I had actually broken the screen. I was swapping the battery, but now I have to actually buy a new display assembly.
iPhone 오른쪽 가장자리(전원 버튼이 있는 가장자리)를 헤어 드라이어를 사용하여 90초 또는 스크린이 만지기 어려울 정도로 뜨거워질 때까지 가열합니다.
여는 픽으로 iPhone 하단 오른쪽 모서리를 돌아 접착제를 분리하세요.
오른쪽 상단 모서리에 도달할 때까지 iPhone 오른쪽 가장자리를 계속 밀어 올리세요.
계속 진행하기 전에 오른쪽 상단 모서리에 픽을 그대로 두세요.
헤어 드라이어를 사용하여 iPhone의 왼쪽 가장자리를 90초 동안 또는 스크린이 만지기 어려울 정도로 약간 뜨거워질 때까지 가열하세요.
흡입 핸들을 분리하지 않았다면 지금 분리하세요.
오른쪽 가장자리가 사용자를 향하도록 iPhone을 돌리세요.
책의 뒷 표지처럼 디스플레이 왼편을 위로 펼쳐서 iPhone을 열어주세요.
휴대폰에 작업하는 동안 디스플레이를 다른 물건에 기대어 세워 놓으세요.
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Phillips/십자 스크루드라이버를 사용하여 배터리와 디스플레이 커넥터 커버를 고정하는 1.3mm 나사 세 개를 풀어주세요.
Spudger/스퍼저 또는 깨끗한 손톱을 사용하여 배터리 커넥터를 로직 보드의 커넥터 소켓에서 들어올리세요.
수리 중에 실수로 소켓에 닿아 휴대폰에 전원이 공급되지 않도록 커넥터를 로직 보드에서 약간 멀리 구부려 주세요.
전면 센서 커넥터 커버를 고정하는 나사 세 개를 풀어주세요:
1.7mm 십자 나사 한 개
1.3mm 십자 나사 한 개
1.8mm Y000 나사 한 개
스크린을 분리하세요.
what do I do if i cant get the screw out?
카메라 어셈블리에 연결된 하단 왼편 케이블 밑으로 spudger/스퍼저의 끝을 끼우고 살짝 들어 올려서 후면 카메라 어셈블리를 추출하세요.
Spudger/스퍼저 끝을 사용하여 카메라 어셈블리 상단 가장자리를 손가락으로 잡을 수 있을 만큼 충분히 들어 올리세요.
새 교체 부품을 원래 부품과 비교하세요—설치하기 전에 원래 부품에서 남은 부품을 옮기거나 새 부품에서 접착 뒷면을 제거해야 할 수도 있습니다.
기기를 재조립하려면, 이 지침들을 역순으로 따르세요.
전자 폐기물을 R2 또는 e-Stewards 인증 재활용 업체로 가져가세요.
수리가 계획대로 진행되지 않았습니까? 자사의 기본 문제 해결 페이지를 읽거나 iPhone 13 답변 커뮤니티에서 도움을 받으세요.
다른 8명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
88%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 2개
Habrá alguna guía para reemplazar el flash del iPhone 13 Pro? Gracias
thanks! helped a lot!
