소개
Use this guide to replace the rear-facing camera assembly in your iPhone 14 Pro Max.
This guide was created using the A2894 (international) model. If you're fixing a different iPhone 14 Pro Max model, there may be some visual discrepancies, but the procedure should be the same.
You’ll need replacement adhesive to reattach the screen when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
필요한 것
Power off your iPhone before beginning disassembly.
Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
Apply a suction handle to the bottom edge of the screen, while avoiding the very edge of the glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
Insert an opening pick into the gap under the screen's plastic bezel.
Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
Continue sliding up the right edge of the iPhone until you reach the top right corner.
Leave the pick in the top right corner before continuing.
Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and half way across the top edge stopping right before the earpiece speaker cut-out.
Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
Insert a second opening pick in the bottom left corner of the iPhone.
Twist both picks simultaneously until the left edge clips release.
Rotate your iPhone so the right edge faces you.
Open your iPhone by swinging the screen up from the right side, like the front cover of a book.
Lean the screen against something to keep it propped up while you're working on the phone.
Use a Y000 screwdriver to remove the eight screws securing the battery connector cover:
Six 1.3 mm-long screws
One 1.6 mm-long screw
One 1.9 mm-long screw
Grasp the connector cover with a pair of tweezers and slide it downwards to clear the flex cables.
Remove the connector cover.
Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Use the pointed end of a spudger to disconnect the first display cable by prying the connector straight up from its socket.
Use a Y000 screwdriver to remove the five screws securing the rear-facing camera assembly cover:
Four 1.5 mm-long Y000 screws
One 1.2 mm-long Y000 screw
Use a Phillips screwdriver to remove one 1.7 mm-long screw.
Grab the rear-facing camera assembly cover with a pair of tweezers.
Move the camera assembly cover toward the volume buttons to free its small metal edge from the frame.
Remove the rear-facing camera assembly cover.
Use a spudger to disconnect the ultra wide and telephoto lens cable by prying the connector straight up from its socket.
Use a spudger to disconnect the wide lens cable by prying the connector straight up from its socket.
Insert the pointed end of a spudger underneath the bottom edge of the rear-facing camera assembly.
Tilt the back of the spudger downwards to pry up the rear-facing camera assembly.
Use a pair of tweezers or your fingers to remove the rear-facing camera assembly.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 2개
Excellent guide, thank you very much! It was very easy to follow
Can someone verify whether there is any feature loss replacing the cameras?
