주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 7 Power Button Replacement
필요한 것
  1. iPhone 7 Power Button Replacement, Pentalobe Screws: 1 단계, 이미지 1개 중 1개
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    댓글 쓰기
  2. iPhone 7 Power Button Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    댓글 쓰기
  3. iPhone 7 Power Button Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    댓글 쓰기
  4. iPhone 7 Power Button Replacement: 4 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement: 4 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement: 4 단계, 이미지 3개 중 3개
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    댓글 쓰기
  5. iPhone 7 Power Button Replacement: 5 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 5 단계, 이미지 2개 중 2개
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    댓글 쓰기
  6. iPhone 7 Power Button Replacement, Heat the display: 6 단계, 이미지 1개 중 1개
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
    댓글 쓰기
  7. iPhone 7 Power Button Replacement, Separate the display: 7 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement, Separate the display: 7 단계, 이미지 2개 중 2개
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    댓글 쓰기
  8. iPhone 7 Power Button Replacement: 8 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement: 8 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement: 8 단계, 이미지 3개 중 3개
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    댓글 쓰기
  9. iPhone 7 Power Button Replacement: 9 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement: 9 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement: 9 단계, 이미지 3개 중 3개
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    댓글 쓰기
  10. iPhone 7 Power Button Replacement, Screen information: 10 단계, 이미지 1개 중 1개
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    댓글 쓰기
  11. iPhone 7 Power Button Replacement: 11 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement: 11 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement: 11 단계, 이미지 3개 중 3개
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    댓글 쓰기
  12. iPhone 7 Power Button Replacement: 12 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 12 단계, 이미지 2개 중 2개
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
    댓글 쓰기
  13. iPhone 7 Power Button Replacement: 13 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement: 13 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement: 13 단계, 이미지 3개 중 3개
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    댓글 쓰기
  14. iPhone 7 Power Button Replacement: 14 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 14 단계, 이미지 2개 중 2개
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    댓글 쓰기
  15. iPhone 7 Power Button Replacement: 15 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement: 15 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement: 15 단계, 이미지 3개 중 3개
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    댓글 쓰기
  16. iPhone 7 Power Button Replacement, Battery Disconnection: 16 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Tri-point Y000 Screwdriver
    $5.99
    댓글 쓰기
  17. iPhone 7 Power Button Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the lower connector bracket.
    댓글 쓰기
  18. iPhone 7 Power Button Replacement: 18 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement: 18 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement: 18 단계, 이미지 3개 중 3개
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
    댓글 쓰기
  19. iPhone 7 Power Button Replacement, Display Assembly: 19 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement, Display Assembly: 19 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement, Display Assembly: 19 단계, 이미지 3개 중 3개
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
    댓글 쓰기
  20. iPhone 7 Power Button Replacement: 20 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement: 20 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement: 20 단계, 이미지 3개 중 3개
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
    댓글 쓰기
  21. iPhone 7 Power Button Replacement: 21 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 21 단계, 이미지 2개 중 2개
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
    댓글 쓰기
  22. iPhone 7 Power Button Replacement: 22 단계, 이미지 1개 중 1개
    댓글 쓰기
  23. iPhone 7 Power Button Replacement, SIM Card: 23 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement, SIM Card: 23 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement, SIM Card: 23 단계, 이미지 3개 중 3개
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
    • Remove the SIM card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    댓글 쓰기
  24. iPhone 7 Power Button Replacement, Logic Board Connectors: 24 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement, Logic Board Connectors: 24 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the rear-facing camera connector.
    댓글 쓰기
  25. iPhone 7 Power Button Replacement: 25 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 25 단계, 이미지 2개 중 2개
    • Remove the following Phillips screws securing the rear camera bracket to the rear case:
    • One 1.3 mm screw
    • One 2.5 mm screw
    댓글 쓰기
  26. iPhone 7 Power Button Replacement: 26 단계, 이미지 1개 중 1개
    • Remove the bracket.
    댓글 쓰기
  27. iPhone 7 Power Button Replacement: 27 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 27 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
    댓글 쓰기
  28. iPhone 7 Power Button Replacement: 28 단계, 이미지 1개 중 1개
    • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
    댓글 쓰기
  29. iPhone 7 Power Button Replacement: 29 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 29 단계, 이미지 2개 중 2개
    • Remove the upper cable bracket.
    댓글 쓰기
  30. iPhone 7 Power Button Replacement: 30 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 30 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the upper cable connector.
    댓글 쓰기
  31. iPhone 7 Power Button Replacement: 31 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 31 단계, 이미지 2개 중 2개
    • Remove the four Phillips screws securing the Wi-Fi antenna:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    댓글 쓰기
  32. iPhone 7 Power Button Replacement: 32 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 32 단계, 이미지 2개 중 2개
    • Remove the top left antenna.
    댓글 쓰기
  33. iPhone 7 Power Button Replacement: 33 단계, 이미지 1개 중 1개
    • Remove the following Phillips screws:
    • One 1.3 mm screw
    • One 2.2 mm screw
    댓글 쓰기
  34. iPhone 7 Power Button Replacement: 34 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 34 단계, 이미지 2개 중 2개
    댓글 쓰기
  35. iPhone 7 Power Button Replacement: 35 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the 2.2 mm standoff screw from the grounding bracket.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    댓글 쓰기
  36. iPhone 7 Power Button Replacement: 36 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 36 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
    댓글 쓰기
  37. iPhone 7 Power Button Replacement, Logic Board: 37 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement, Logic Board: 37 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement, Logic Board: 37 단계, 이미지 3개 중 3개
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
    댓글 쓰기
  38. iPhone 7 Power Button Replacement: 38 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement: 38 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement: 38 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to gently derout the antenna cables from the metal bracket on the logic board.
    댓글 쓰기
  39. iPhone 7 Power Button Replacement: 39 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 39 단계, 이미지 2개 중 2개
    • Use the point of a spudger to disconnect the lower cable connector.
    댓글 쓰기
  40. iPhone 7 Power Button Replacement: 40 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $5.49
    • Remove the following screws:
    • One 1.4 mm Phillips screw
    • Three 2.2 mm standoff screws
    • Standoff screws are best removed using a standoff driver.
    댓글 쓰기
  41. iPhone 7 Power Button Replacement: 41 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 41 단계, 이미지 2개 중 2개
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
    댓글 쓰기
  42. iPhone 7 Power Button Replacement: 42 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 42 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
    • Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
    댓글 쓰기
  43. iPhone 7 Power Button Replacement: 43 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement: 43 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement: 43 단계, 이미지 3개 중 3개
    • Lift the battery connector end of the logic board and pull it up and out of the rear case.
    • Be careful not to snag the logic board on any cables.
    댓글 쓰기
  44. iPhone 7 Power Button Replacement, Power and Volume Control Cable: 44 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement, Power and Volume Control Cable: 44 단계, 이미지 2개 중 2개
    • Two 1.9 mm screws securing the power button.
    • Three 2.3 mm screws securing the volume buttons.
    댓글 쓰기
  45. iPhone 7 Power Button Replacement: 45 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 45 단계, 이미지 2개 중 2개
    • Remove the following 1.3 mm Phillips screws:
    • One screw beside the rear-facing camera
    • One screw on the rear case
    댓글 쓰기
  46. iPhone 7 Power Button Replacement: 46 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 46 단계, 이미지 2개 중 2개
    • From the outside of the phone, push the hold switch into the rear case with the point of a spudger.
    • This action will free the hold switch and gasket from the rear case.
    댓글 쓰기
  47. iPhone 7 Power Button Replacement: 47 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 47 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the rear-facing camera.
    댓글 쓰기
  48. iPhone 7 Power Button Replacement: 48 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 48 단계, 이미지 2개 중 2개
    • Moving from power button side of the phone, use an opening pick to separate the adhesive holding the antenna flex cable to the rear case.
    댓글 쓰기
  49. iPhone 7 Power Button Replacement: 49 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 49 단계, 이미지 2개 중 2개
    • Slide the point of an opening pick underneath the antenna flex cable towards the top of the phone, separating the remaining adhesive.
    댓글 쓰기
  50. iPhone 7 Power Button Replacement: 50 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 50 단계, 이미지 2개 중 2개
    • Use tweezers to move the antenna flex cable away from the edge of the phone, freeing the screw bracket from the rear case.
    • Remove the antenna flex cable.
    댓글 쓰기
  51. iPhone 7 Power Button Replacement: 51 단계, 이미지 1개 중 1개
    • Remove the 2.3 mm standoff screw securing the flash bracket to the rear case.
    • Standoff screws are best removed using an [링크된 제품이 누락 또는 비활성화 됨: IF145-343] and driver handle.
    댓글 쓰기
  52. iPhone 7 Power Button Replacement: 52 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 52 단계, 이미지 2개 중 2개
    • Remove the flash bracket.
    댓글 쓰기
  53. iPhone 7 Power Button Replacement: 53 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 53 단계, 이미지 2개 중 2개
    • Use the point of a spudger to gently unseat the flash module.
    댓글 쓰기
  54. iPhone 7 Power Button Replacement: 54 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 54 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    • Use the blade of a Halberd spudger to separate the adhesive holding the microphone to the rear case.
    댓글 쓰기
  55. iPhone 7 Power Button Replacement: 55 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 55 단계, 이미지 2개 중 2개
    • Gently fold the power button module from the edge of the rear case.
    댓글 쓰기
  56. iPhone 7 Power Button Replacement: 56 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement: 56 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement: 56 단계, 이미지 3개 중 3개
    • Slide the blade of a halberd spudger under the power button end of the button cable to separate it from the adhesive on the rear case.
    • Continue to separate the adhesive by moving the blade towards the top of the phone.
    댓글 쓰기
  57. iPhone 7 Power Button Replacement: 57 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement: 57 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement: 57 단계, 이미지 3개 중 3개
    • Continue to move the blade of the halberd spudger underneath the power and volume control cable.
    • Move slowly to make sure that the cable is not damaged during removal.
    댓글 쓰기
  58. iPhone 7 Power Button Replacement: 58 단계, 이미지 3개 중 1개 iPhone 7 Power Button Replacement: 58 단계, 이미지 3개 중 2개 iPhone 7 Power Button Replacement: 58 단계, 이미지 3개 중 3개
    • Slide the halberd spudger under the volume control portion of the button cable.
    • Gently slide the blade underneath the cable towards the bottom of the phone, separating the remaining adhesive.
    댓글 쓰기
  59. iPhone 7 Power Button Replacement: 59 단계, 이미지 1개 중 1개
    • Remove the power and volume control cable.
    댓글 쓰기
  60. iPhone 7 Power Button Replacement, Power Button: 60 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement, Power Button: 60 단계, 이미지 2개 중 2개
    • Pull the clip towards the bottom of the phone and lift up to free it from the bracket.
    댓글 쓰기
  61. iPhone 7 Power Button Replacement: 61 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 61 단계, 이미지 2개 중 2개
    • Remove the clip from the rear case.
    댓글 쓰기
  62. iPhone 7 Power Button Replacement: 62 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 62 단계, 이미지 2개 중 2개
    • Push the lower end of the power button bracket up off of peg securing it.
    댓글 쓰기
  63. iPhone 7 Power Button Replacement: 63 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 63 단계, 이미지 2개 중 2개
    • Pull the bracket from the rear case.
    댓글 쓰기
  64. iPhone 7 Power Button Replacement: 64 단계, 이미지 2개 중 1개 iPhone 7 Power Button Replacement: 64 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to push the power button cover out of the rear case.
    • Remove the power button cover.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 24명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Scott Havard
회원 가입일: 06/27/16
51,304 평판
안내서 31개를 작성함
3가이드 댓글
Alright so quick question…….
the clip shown in step 57 the one that resembles a staple,is this necessary?
Im doing a housing swap for myself and I cannot get these back on going on an hour now my hands are huge so im wondering if everything will be okay if I don’t replace these.(normally if it were another person’s device I would never take a shortcut,Never have and Never will in fact I despise this,but it’s my phone so it’s cool).
thanks
Vegeta Barrett - 답글 공유
I can't see a response. Are the clips necessary?
Martha Brewer - 답글 공유
It is probably to keep it in place, so I think it’s not necessary but recommended
Ward Morren - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 22
지난 30일: 121
전체 시간: 64,695
