도구
동영상 개요
분해를 시작하기 전에 iPhone 전원을 꺼주세요.
iPhone 하단 가장자리에 위치한 6.9mm-길이 pentalobe/펜타로브 나사 두 개를 빼주세요.
기기를 다시 조립하려면 위의 단계를 역순으로 수행하십시오.
스크린 전체를 덮을 때까지 iPhone 디스플레이 위에 포장 테이프 스트립을 겹쳐 놓아 주십시오.
유리 파편으로 인해 다음 몇 단계에서 흡입 컵이 붙지않는 경우 강한 테이프를 (예: 강력 접착테이프) 접어서 손잡이를 만들어서 디스플레이를 들어 올려주십시오.
로직 보드 커넥터 브래킷을 고정하는 Y000 나사 다섯 개를 풀어주세요:
1.1mm 나사 세 개
3.1mm 나사 한 개
3.7mm 나사 한 개
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the 1.2 mm Y000 screw on the back of the display assembly, near the infrared camera port.
Beneath the screw you just removed lies a small metal grounding clip. If it didn't already come out along with the screw, remove it now.
Remove two more Y000 screws securing the speaker/sensor assembly:
One 1.6 mm screw
One 1.3 mm screw
Using a spudger, gently pry under the top edge of the speaker assembly, and flip it over—down and away from the top edge of the display.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for about a minute, in order to soften the adhesive securing the sensors.
Carefully slide the flat edge of your spudger underneath the flex cable below the microphone.
Twist gently to separate the microphone, while being careful not to strain or damage the flex cable.
If needed, use the point of the spudger to finish separating the microphone from its notch in the front panel.
Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module.
Gently wiggle and lift to separate the module from its notch in the front panel.
Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display.
If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below.
If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier.
Remove the earpiece speaker and front sensor assembly.
Proximity sensor
Flood illuminator
The module must be positioned so that these components are not obstructed by any adhesive.
다른 447명이 해당 안내서를 완성하였습니다.
댓글 79개
does a new display not come with faceid sensor? so you have to remove this and instal it again with the new glass?
yeah, also face id will not work if you don’t replace the flex. Just be careful
jump1n -
FaceID is diabled if the hardware detects a new FaceID module. Using the original parts avoids this issue so that the FaceID feature is’t disabled. This could prevent a FaceID module from being replaced with a doctored or unlicensed part which may fail to provide the same level of security than the Apple supplied part.
Sorry, if I replace my iPhone X Lcd, will the Face ID stop working?
