주요 콘텐츠로 건너뛰기
Here at the Moebius Foundation, we are always looking to advance humanity’s technological level, no matter the cost. When advanced alien races refuse to share their technology with us, we simply see it as an occupational challenge.
We have been trying to tap into the Protoss psionic energy matrix without success for years. The floating pylons they use to distribute the energy are immovable, and field scans yield nothing.
That all changes today. With great effort, field agents were able to procure a movable pylon! This must be a prototype version of the field-deployed ones. With its secrets, we may be able to construct our own wireless power system!
Let us proceed with the teardown before some unlikely hero inevitably kicks down our door and obliterates the lab.
This is an iFixit after-hours project. Any views expressed in this guide are those of the authors and do not necessarily reflect the official policy of iFixit.
필요한 것
도구
해당 분해도는 수리 안내서가 아닙니다. Protoss Pylon 수리는 자사의 서비스 설명서를 사용하세요.
  1. Protoss Pylon Teardown, Protoss Pylon Teardown: 1 단계, 이미지 1개 중 1개
    • Here's what we theoretically know about these pylons:
    • Uses Khaydarin crystals to channel energy
    • Takes 100 minerals and 30 seconds to warp in
    • Floats in the air and glows
    • Provides supplies for 8 units
  2. Protoss Pylon Teardown: 2 단계, 이미지 2개 중 1개 Protoss Pylon Teardown: 2 단계, 이미지 2개 중 2개
    • Scientific analysis of our "prototype" specimen yields the following data:
    • 2 unregulated USB ports capable of sourcing 2A total (or whatever max current it's supplied with)
    • The crystal can be activated to glow blue with a switch
    • Prototype: must be powered by a wired 5V 2.1A DC power supply
  3. Protoss Pylon Teardown: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Manta Driver Kit - 112 Bit Driver Kit
    $69.95
    • Luckily, we just got a shipment of high quality tools! And, they're so nice looking!
    • It's slightly unsettling that even the Protoss are using Phillips screws. It must be a universal standard.
    • The only thing worse than esoteric screw types? Low quality ones. These screws are made of soft metal and are easily stripped. This must be a side-effect of their warp-in technology.
    • Since most skirmishes last less than an hour, it looks like this field pylon wasn't built to be durable.
  4. Protoss Pylon Teardown: 4 단계, 이미지 2개 중 1개 Protoss Pylon Teardown: 4 단계, 이미지 2개 중 2개
    • The clever Protoss thought they could hide their technological secrets behind a seemingly impossible to open enclosure. They obviously have not met the masters of the art.
    • We apply pressure with an opening pick at just the right place, and off pops the stabilization leg.
  5. Protoss Pylon Teardown: 5 단계, 이미지 3개 중 1개 Protoss Pylon Teardown: 5 단계, 이미지 3개 중 2개 Protoss Pylon Teardown: 5 단계, 이미지 3개 중 3개
    • Wait, who removed the other stabilization leg? That will cau...
    • Phew! It looks like the sensitive monitoring equipment survived the explosion. After we scrape up the charred remains of the interns, we shall proceed as planned.
  6. Protoss Pylon Teardown: 6 단계, 이미지 2개 중 1개 Protoss Pylon Teardown: 6 단계, 이미지 2개 중 2개
    • And here we see the casualties of the warp-in technology:
    • Energy transfer conduits that are dangerously pinched
    • Low reliability conduit-to-socket connections
    • These are weak points which will most likely fail before anything else. When it happens, repair should be simple. Inte...er... someone should note this in our files.
  7. Protoss Pylon Teardown: 7 단계, 이미지 2개 중 1개 Protoss Pylon Teardown: 7 단계, 이미지 2개 중 2개
    • We finally get a glimpse of the Protoss' power channeling circuitry.
    • It is surprisingly sparse and low tech, consisting mostly of surface mount resistors and common electronic components...
  8. Protoss Pylon Teardown: 8 단계, 이미지 3개 중 1개 Protoss Pylon Teardown: 8 단계, 이미지 3개 중 2개 Protoss Pylon Teardown: 8 단계, 이미지 3개 중 3개
    • We've been bamboozled by the Protoss! This isn't a real pylon; it's just a toy! A decoy!
    • Contact our field agents and fire them! Literally, with a Firebat executioner squad.
    • Speaking of being fired, someone’s going to have to take the fall for this. Wait right here! I’m going to go check on…something in the hanger bay…
댓글 7개
I thought that humans would get that long-awaited technology ... it seems that we will have to continue using crank motors ... This afternoon I may release zerg eggs on some of their planets :)
Oscar - 답글
Ya’ll are nerds. Wonderful, wonderful nerds.
Sandy34 - 답글
My life for Aiur!
Reza Sadr - 답글
On the main circuit where the DC socket is under the socket i fount no metal to solder for. They ‘ve actually solder the connector pins to plastic. Cheap work for 40Eur. You need to sratch the blue part to find some contact spot.
magortomi - 답글
Fairly disappointed with this thing and the quality of the electronics but alas, it’s a toy made in china. Took me about 4 years to get around to it but I finally fixed the faulty power connector thanks to you guys. Thank you so much for this. I could not figure out where those clips were behind the larger sides.
Logan - 답글
Same here, thank you so much for this guide, the connector on my pylon became loose to the point where I have to apply downward force onto the power connector in order for it to light up. After about 5 years now I am finally able to open it up to try to repair it, thanks for the guide!
scwashere -
I have one led out. Has anyone else had that issue? If so, how did you fix it?
Hector Garcia - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 13
지난 30일: 32
전체 시간: 6,216
