동영상 개요
옛것을 버리고 새것을 받아들이세요—하드웨어를. 아주 친숙한 얼굴 뒤에 숨겨져 있는 새로운 정보는 다음과 같습니다:
M9 모션 코프로세서가 내장 Apple A9 프로세서
16GB 또는 64GB 저장 용량
4-인치, 1136x640 픽셀 (326ppi) Retina 디스플레이
4K 비디오 녹화를 지원하는 1.22µ 픽셀 12MP iSight 카메라 및 1.2 MP ƒ/2.4 FaceTime HD 카메라
802.11a/b/g/n/ac Wi‑Fi + Bluetooth 4.2 + NFC + 19-band LTE
사용자 인증 및 Apple Pay를 지원하는 Touch ID 센서
이 단계에 사용된 도구:iSclack$24.99
이제 우리가 좋아하지 않는 단계입니다. Pentalobes/펜타로브/별나사: Apple이 귀하의 기기 여는 것을 정말 원하지 않는다는 사실을 상기시키는 5-점 나사.
그래도,이 pentalobes/펜타로브/별나사는 완전히 귀엽고 어울리는 로즈 골드 색상이네요.
예쁜 분홍색 나사는 치워 놓고, 우리는 iSclack으로 뚜껑을 엽니다—그리고 성가시고 디스플레이 색상과 동일한 접착제는 보이지 않습니다. Apple의 S-시리즈 주력 상품과 비교할 때 이 여는 절차는 매우 간단합니다.
This guide would be a lot more useful and accessible if it didn't assume knowledge or pre-reading of past iPhone teardowns.
This isn't really meant to be a guide of any kind, it's more of a look-and-see/show-and-tell kind of thing. While some teardowns are perfectly fine for disassembly guide, that isn't really the goal.
I opened my iPhone to find its missing the metal cover that goes over the ribbon attaching the screen to the rest of the phone (the lego piece attachment by home button). Is it a big deal that my phone doesn’t have that piece? Or should I buy a replacement for for it?
Currently my phone wont turn on or charge..could that missing cover be the reason? Right now I’m thinking it has to do with logic board having already replaced charging port to eliminate that as a cause.
f but if you know how to fix it then please help me cause i just did as well
I literally did the same thing yesterday, trying to replace the battery RIP!!!
여기에 번역 삽입
여기에 번역 삽입
Hello, I saw Step 5 second picture,
If iPhone SE installed 5S screen assembly, and then power on, to open the camera app, switch to the selfie shots, and turn on the flash, 5S screen will detect light with pre-flash white balance, and then to 300% brightness light-emitting it? I was wondering whether 5S screen is working? thank you!
Just to confirm, The iphone se can has its screen replaced with an iphone 5s screen? Are they completely interchangeable?
I was told by the guy that replaced my screen that the aftermarket screens for 5S do not work properly on SE. I don't know if that was accurate, but he does a lot of them. It's possible that there's an issue with the other accessories attached to the screen.
FWIW, the clone screen he put on mine (which was supposedly intended for the SE, but I wouldn't rule out the possibility of these discount direct export companies putting the wrong product in the wrong box) ended up with me back there twice because the light/proximity sensor did not work. He ended up slapping on the front end of a traded-in SE just to get me happy and out of there. For the curious, the clone screen also had markedly worse colors (which were inconsistent within the screen itself), screen-door effect, build quality, and touch sensing (ghost presses). For some reason my touch ID sensor didn't seem to ever align properly in it either, and the low-light proximity sensor, for the five minutes it worked each time, was blue instead of red.
I’m a little late maybe, but the display unit of iPhone 5s and SE doesn’t work with each other.
1. The sensor/camera connector is not even of the same dimension. It just doesn’t plug in. (The picture above clearly showed that!)
2. The touch panel on the iPhone 5s won’t work with iPhone SE even if it can be plugged in.
3. The screen on the iPhone 5s somehow works with iPhone SE, but you’ll have a chunky background and horizontal shadows all over the screen as if there is some clock desync going on.
다음, 업그레이드된 후면 카메라를 정박지에서 뽑아냅니다.
5s 카메라(좌)와 비슷해 보이지만, SE 카메라(우)의 커넥터 핀 숫자는 훨씬 적습니다.
SE iSight 카메라는 해상도를 최대 12MP 향상 하지만 픽셀 피치는 5s 1.5µm에서 1.22µm로 감소합니다.
It actually looks like the number of pins are similar between the two camera connectors; I count 32 on the left connector (16 x 2) and 30 on the right (15 x 2).
Guys, is it possible to turn rear camera to 90 degrees to record widescreen video with holding phone vertical? Maybe with some cable extender or etc?
It is really annoying that you must always hold phone horizontally to make normal videos, still the camera manufacturers can't make camera which shoot widescreen on any side... or very obvious design flaw by Apple - why they even offer users to make vertical videos with vertical bars? No one needs them.
where can I purchase an iPhone SE camera?
Hey I’m curious how small the actual camera sensor is? It seems very small for its resolution. I know these days it’s all about the colors but wondering how much resolution a camera can have. 50MP isn’t enough for me! Let’s go higher!
The sensor size is the same as the 6s, i’ve seen “1/3″ (4.80 x 3.60 mm)” on the internets. I’m not sure about theoretical megapixel limits, but I think a common new camera system is using multiple, specialized, image sensors for better clarity and performance in varying lighting conditions. So “better” pixels over “more” pixels.
well, i kind of curious, is it doable to change iphone se camera with iphone 6s plus camera that has OIS feature?
우리는 더 많은 분해도를 여러분께 제공하기 위해 이 분해를 잠시 중단합니다!
우리 Creative Electron 친구들이 분해도를 X-레이 스타일로 제공하고 있습니다!
우리는 iPhone 5 3세대를 배치했습니다, 즐기세요.
실제로, 유일 명백한 변화는 추가한 이종-금속 Apple 로고입니다.
또 하나는 iPhone 5와 5s 사이에 추가한 Touch ID 케이블입니다 (이 불행한 배치는 SE에도 여전히 존재합니다).
Sans compter le fait que la carte mère a complètement été revue à chaque génération.
스피커 어셈블리 분리, 진동기 분리, SIM 카드 및 트레이 분리!
로즈 골드는 SE 독점 색상이므로 색상 조절은 업그레이드를 필요로 합니다.
참고 사항: 방수 씰! 실리콘 씰 거품이 로직 보드 커넥터 일부를 둘러싸고 있습니다—그러나, 이상하게도, 전체는 아닙니다.
Yea…found that one out first hand earlier today when my SE fell out of my breast pocket (I thought was buttoned) into the deap end of the pool. I snached quickly and it was not in water for more then 2 seconds and towel dried then into bag of rice for several hours. My phone now has vertical barring, fading icons, and problematic home button. Came to this site to check how to open up the phone and was able to fix all the problems but my rear facing camera is also attached to the back of the screen opposite side of the touch cable and I must have loosed the attachment point because the rear facing camera is not working. Going back in to see what is going on with that. And it was not stressed s enough that the touch cable is a x*%ch of a connector to put back…word of warning especially those with larger digiets.
성가신 후면 커넥터를 로직 보드에서 분리하면 영광스러운 실리콘 필드를 자유로이 훑어볼 수 있습니다!
H9KNNNBTUMUMR-NLH 표식 Apple A9 APL1022 SoC + SK Hynix 2GB LPDDR4 RAM
Qualcomm MDM9625M LTE 모뎀 (iPhone 6/6 Plus에서 보임)
Qualcomm WTR1625L RF 송수신기 (iPhone 6/6 Plus에서 보임)
Qualcomm QFE1100 엔벨롭 트랙킹 IC (6s/6s Plus 및 6/6 Plus에서 보임)
Skyworks SKY77611 Quad-band 전력 증폭 모듈
반대편에는 더 많은 실리콘이 존재합니다!
Toshiba THGBX5G7D2KLDXG 16GB NAND 플래시
339S00134 (아마도 신형 Universal Scientific Industrial 339S00043 Wi-Fi 모듈)
Apple/Dialog 338S00170 전력 관리 IC
NXP 66V10 NFC 컨트롤러 및 1610A3 충전 IC(iPhone 6s/6s Plus에서 보임)
Skyworks SKY77826 Ultra low-band 전력 증폭 송수 전환기 및 SKY77357 2G/EDGE 전력 증폭 모듈 (아마도 SKY77336 신형)
Apple/Cirrus Logic 338S00105 및 338S1285 오디오 ICs (iPhone 6s/6s Plus에서 보임)
Qualcomm WFR1620 수신-전용 송수신기 (iPhone 6/6 Plus에 보임)
계속되는 칩 식별...
Avago ACPM-8020 Mid-band 전력 증폭 송수 전환기 (iPhone 6 Plus에서 보임)
Qorvo (TriQuint) TQF6410 Low-band 전력 증폭 송수 전환기 (iPhone 6 Plus에서 보임)
TDK EPCOS D5255 Diversity Receive 모듈
Qualcomm PM8019 PMIC (iPhone 6/6 Plus에서 보임)
Qorvo (RF Micro Devices) RF5159 안테나 스위치 모듈 (iPhone 6/6 Plus에서 보임)
InvenSense EMS-A 6-축 자이로스코프 및 가속도계 콤보
Broadcom BCM5976 Touchscreen 컨트롤러 (iPhone 5에서 처음 보임)
우와, 이제—버튼 케이블은 마지막으로 분해했을 때보다 조금 더 복잡해진 것 같습니다.
전원 버튼 브래킷에는 간단한 클립 대신 어떤 접점 케이블이 있습니다, 아마도 접지용.
이제, 후면 케이스만 남았습니다—분해도를 마무리할 시간입니다.
Any clear idea where the NFC antenna is? is that it on the back, or the new "inlaid SS Apple logo?"
I've waited YEARS for the iPhone to finally adopt NFC and Qi charging like my trusty Nexus 4, they're halfway there...!
Im going to say that the extra bit on the power volume flex is the NFC antenna. That is the only reason for Apple to add that extra little bit. All of the other antennas look to be the same from the 5S so this would be the new antenna for NFC.
Alec -
The NFC antenna is the top bezel itself, the connector is the screw post on the top right of the logic board, which connects to the extra piece on the power button flex.
Tom Chai -
Thanks, guys!
Hi, has anyone heard if you can move a custom colored iphone 5s housing on an SE yet ?
If you mean a case/cover, the dimensions are the same. So cases for the 5 and 5s will fit the SE.
Was that your question? :}
No, i mean is the rear case replacement of the Se identical with the iPhone 5s ?
andrebhr -
From the x-ray shot in step 8 the screw placement and parts dimensions are extremely similar so it seems likely that a custom rear housing meant for a 5S would work. However, there are some other variables like screw size that are harder to judge from that image. It would be interesting to know for sure though.
Does anyone know where I can get a replacement bracket? I ripped the contact cable by mistake and am having trouble finding a replacement.
iPhone SE 수리 용이성: 10점 중 6점 (10점이 가장 쉬운 수리)
디스플레이 어셈블리는 휴대폰에서 제일 먼저 분리하는 부품이며 스크린 교체를 간단하게 합니다.
"사용자 교체 가능"하지 않다는 배터리는 사실상 접근이 매우 쉽습니다.
휴대폰을 열 때 사용자가 주의하지 않으면 Touch ID 케이블은 소켓에서 뜯길 수 있습니다.
iPhone SE 외관에는 여전히 Pentalobe/펜타로브/별나사를 사용하므로 특수 드라이버 없이는 풀기 어렵습니다.
the touch id cable is very annoying
다음 번역가들에게 특별히 감사 드립니다:
94%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 123개
From your original picture, it appears the on/off switch in on the top. Is this correct? (I HATE the switch on the side).
Yup! The power button is in the same top position as it was in the 5s (and older) models.
Thanks for the clarity! I really hate the side on/off button placement on the 6's. Stupid.
Gail -
It needs to be on the side for the 6 and on as they are a lot bigger and it is ergonomically impossible to place the power button on the top or you'd have to stretch your finger to reach it. By the way I agree with you.
es-webb -
Can you confirm that the display assemblies are exactly the same? Including the mid frame latches/clips? Would the display right out of an iPhone 5 not only function, but fit perfectly as well?
The display on an iPhone 5 is significantly different from the one found in the 5s, however we've tested and confirmed that the displays that ship with the 5s and SE are interchangeable with respect to fitment and function (and they weigh the same to the nearest .1 g).
Sorry, that was a typo! I meant 5s... so this confirms we should be able to use existing stock of iPhone 5s in the iPhone SE without issue?
The Stem -
Are you able to determine if the glass used on the SE is as durable as the 5S? Had my SE for 2 months now and it's badly marked. My 5S display lasted it's entire lifetime without a scratch.
I can confirm that the displays are in fact different. Using an iPhone 5S screen on an iPhone SE will work, but the screen will be flickering and also have vertical lines all over it (looks like when the touch controller is broken).
Marcus, they are in fact the same screen. If you have flickering then it could be due to disconnecting the battery without turning it off. If you have lines then you have FPC seating failure. I would double check your screen and quality.
Eddie -
A superb tear-down, as usual. Thank you :)
I wonder how much caffeine iFixit editors drink before writing up the copy, since the "unfunny-isms" seem to be in place, as usual - failed attempts to be "quirky and witty" fall flat on their faces. If you'd focus on the hardware, there's plenty of comedians in the world, and - sorry to say - you fail at any hope of putting them out of work.
Stick to the tech, kill the quips.
Different people have different senses of humor. While the quirkiness doesn't make me laugh outright, it doesn't bother me in the slightest.
If it really bothers you that much, I can only recommend you lighten up.
How about the prox/ face camera? Same as 5s? Or different? And volume flex? Looks like 5C
Prox looks to be the same, but iFixit didn't reveal that part to us.
Power volume flex is a bit different, I believe that it has the NFC antenna on the end of it.
Alec -
They are in fact the same and you will have no issues.
Eddie -
Can anyone confirm if the SE has the same NVME storage controller found in the 6s? That's pretty much the last thing that's holding me back from purchasing the SE as I am pleased with the rest of the components I've seen so far.
It may possibly, but I only know of this being used in the higher capacity models of the 6S? Maybe the 64 GB SE has it, but its not a guarantee.
Alec -
We'll do some further testing to verify, but yes, everything looks like it bolts right up.
any news about transplanting the logic board from an SE into a 5S? only difference I found on the Pics was the battery connector.
No they are different with a few of the standoffs being located differently.
Eddie -
You can install se logic board in 5s chassis, but you'll need to transplant se power button flex ,volume controller flex to 5s too.
No they are not.
Eddie -
yes they are interchangable
Keep up the humour, ignore that other guy, you guys are awesome.
No, it's just a lump of steel.
Tom Chai -
No, it just makes it possible to remove the logo from the frame, making way for mods for said logo. (though i doubt it was intentional for that to be used for mods)
I think I know the answer already... But it is possible to upgrade to a 6s fingerprint sensor/button? Are they interchangeable?
Whitling2k - 답글
That's not likely as there are a number of obstacles to overcome. First, the cable design is completely different. The 6s home button connects to the display assembly and the cable's routed through the top of the display. Secondly, the connector design is significantly different. And, if these weren't issues, you'd still need to calibrate the logic board to the new Touch ID sensor which, as of now, only Apple can do.
The iPhone SE shipped in china seems to have a different screen. The border of the display is yellow which looks not comfortable. One of the explanations is the color temperature mechanism. But the yellow border is not uniform distribution. So l doubt the quality of the low-priced iPhone. Can anyone help me out?
This happened to me in America too, many of the displays are bad. Even after I replaced it I can see a dark area near the top edge on white screens, but not as badly as the first one. Most people speculate that it is a flaw due to LED backlighting yields.
I would replace it if you can, it is a defect and some people have state it can get worse over time.
jase240 -
Has there been any testing of retina flash with use of iPhone 5s display part in iPhone SE?
Is the iPhone 5s FaceTime camera installed in iPhone SE capable of taking live photos?
lukeankrum - 답글
Any info on SE mic/speakerphone and audio/DAC components? I use my iPhone speakerphone for over 90% of my calls, so I'm curious how well it does in terms of speaker volume and clarity at both ends, also how well the DAC does for music playback through decent headphones. How do these components compare to other models? Thanks for your continued informative work!
Ummm, wait, same display as 5s? That mean yelowing/ pink issue in all 5 family display gonna happend in SE? thats not good
So can I place SE's motherboard into my 5S? I could receive updates even in 2020, if that is possible
Wouldn't work, as quite a few of the parts don't swap. Camera, dock connector, etc.
Todd -
Would the new bigger battery from this SE swap into a 5s? Sounds like an easy way to gain a few miliamps...
Todd -
"Despite the apparently interchangeable displays, the SE's battery connector differs from that of the 5s. So, no chance to supercharge your old 5s, unfortunately." No, you would need to swap motherboards in order to do that(
Like never before? You mean with removable battery and SD card slot?
I'm no apple fan boy and i know they are proprietary but pentalobe screws don't make it more difficult to repair. Pentalobe screwdrivers are pretty much in most kits. It's never stopped me replacing a screen. In fact everytime you buy a screen you get another screwdriver.
Some don't ship with kits. Just depends on where you buy.
Eddie -
Can you provide any info on how strong is the back camera lens cover glued to case? Can it be easily pushed in from the outside?
This happened on my old iPhone 5, when I accidentaly applied a little pressure on camera lens cover with my finger (like the adhesive would give up or something). And I am wondering if iPhone SE is also vulnerable to this (if it has the same design around the camera at all)? If anyone else has/had the similar issue, let me know, thanks.
I would be curious to see if these parts could fit into this back housing http://www.ebay.com/itm/Back-Rear-Housin...
would be an interesting project and if it works, you'd have an SE the way it should have looked.
Done it with my SE and it looks amazing. I got the mini ip7 rear housing from aliexpress instead tho.
Step 9
Do you think they could have put the 5mp front camera from the 6s in?
Is it possible to stick all the SE insides into a 5c. Looks like 5c runs like a Se
Unfortunately no.
Eddie -
is it possible to install motherboard iphone se to back cover iphone5s? is them are same?
i really want to know that, too.
No it is not the same and can not.
Eddie -
Hi i'm from indonesia. I want to ask you, can the case of iphone se replace on iphone 5s? So it's look like iphone se but the machine is still iphone 5s. Thanks
the cases for the iphone 5s and the SE will be the same.
Eddie -
I have a damaged SE body with broken screen and im planning on replacing the body and display, as far as you said I can replace the screen with a 5s. Can I buy a body from a 5s and migrate all the components of the SE to the 5s body? As far as i saw are most likely the same but you said no and then the last comment confused me
I can confirm that you can a use iPhone 5s housing with Iphone SE inturnals.
what is the screen on the se made out of
I keep seeing that the 5S and SE have the exact same display, front camera etc. However iFixit says that the full screen assembly that includes the front camera, ear speaker and everything is not compatible with the SE, just the screen digitizer is. Does anyone know why this is???
robhopkins - 답글
Different connectors, presumably.
I bought the full screen assembly for 5s trying to put it in my SE. had ease installing the part, however it does not work
alguien sabe si se puede pasar las piezas internas como batería,placa,jack de carga,cámara y pantalla de un iPhone 5s al cuerpo de un iPhone 5se
yo tambien estoy en eso
is i phone se and iphone 5 are compatible? just like the board?
Can i use a 5s housing for my iphone se motherboard?
pookiejj08 - 답글
Is is possible to place the internals of an SE in to a 5c case? From the images, it looks like it shouldn't be too difficult...
is it possible to put iPhone 7 rear front facing camera in iPhone SE?
Hi I have the iPhone SE and have been experiencing issues with network and have done everything suggested up to removing and replacing the SIM card and still saying searching. Would this be a disconnected antenna and is there a way to determine if this is what the problem is? I have all other services and capabilities working aside from the phone use
Is the speaker (speakerphone) in the SE same/lound as the one that is in the 5S. Thanks in advance.
Yes I have the both
Wait so a iPhone 5s camera can fit inside the iPhone se and function well I'm talkin about the rear
Can i put everything in my SE into an empty 5s/5 case? (se case banged up but phone works really good, screen is scratch-free)
Is it possible to use a 5S powerbutton/volume-flex in a SE?
I want to use iPhone 5s Touch IC in iPhone SE ? If I use the 5s Touch IC in iPhone SE ? Does anyone know ? Thanks..
Would it be possible to swap the Processor from an SE and put it into a 5s as a performance upgrade?
Sean Troop - 답글
Help… i recently swapped out the back housing and there is a flex cable that tore behind the power button. It isnt the power + volume flex cable… its a long skinny cable that gets screwed on into the case… what is that cable and where do i find a replacement?
Do you guys know if the iPhone SE body is interchangeable with the 5S? I’m wondering because i’m doing a repair, a full body one.
Hey, my brightness has been messed up since I replaced my screen three days ago. It only messed up this morning though. Is it fixable? What should I look for, if it is fixable ,when I go back in to check it out?
Hi Rainbow Fire, something might be blocking your ambient light sensor. If you want to open the phone and take a look at the upper sensor cable, you might find some film blocking the sensor, or that it’s not properly placed in the display. If you do opt to open your phone, be sure to use our sensor assembly guide and not this teardown!
Hi
I dropped my phone and took it to a shop to be repaired and they came back saying its unrepairable is that possible they said the board is badly damaged is it possible to change it.
yes it is replaceable, you just need to source out a new board.
Does the 5 and 5s or 5SE have the same internal layout? I mean the screw hole placement, cables location. I wanna change my iphone 5 back cover to the iphone 5s or se cover.
Don’t forget that Touch ID only works if you remove the home button (3 screws) from the damaged screen and install it on the working screen you’re replacing it with. And transfer the metal home button cover plate from the damaged screen to the working screen too, even though it looks identical to the working screen’s plate. If you don’t, the button won’t click properly.
Me atreví a desarmarlo y al montarlo La batería se gasta aun apagada y no hay señal con ninguna operadora a pesar que es iphone de claro y est liberado
reassemble iphone se
hi folks
do you know where the proximity detector is located and how does it work?
Thank you
Hi osvaldo, the proximity sensor is on the front camera and sensor cable behind the speaker on the back of the display. You can look at the iPhone 5s guide for more details. Here you can read how the sensor works (optical photoelectric sensor): https://en.wikipedia.org/wiki/Proximity_...
so no anti-static equipment is needed?
My phone got submerged in water and i took the logic board out and all the water indicators are red. There are no signs of corrosion. Has been cleaned with 91% isopropyl alcohol. But it seems some of the logic board is encased. I would think there is corrosion in there. How would I get to that. I’m just trying to get photos of my child from there.
Ps. Phone does not power on. Have tried other logic boards and phone powers on.
hola se puede cambiar la carcasa del se por el 5s?? tambien la pantalla??
parece que la carcasa o chasis si pero la pantalla segun veo dice que parpadea y tiene lineas verticales esto es asi??
iPhone se modrbodo
I've swapped out the screen on many broken SE's past for a quick and relatively easy fix for my (now vintage?) SE. Sadly, this procedure no longer fixes the digitizer- the screen and everything else works though- it just doesn't react to touch at all. What, besides the screen/digitizer assembly could be the culprit now? Would love to revive this snazzy old phone of mine! Thanks for any help!
I replaced battery on phone and now my screen doesn’t work. Screen works fine on separate SE but not the one I replaced battery. Is is possible I have disconnected something and missed reconnecting? Or is there a piece I may have messed up and need to replace? Screen is black on replaced battery phone but works completely perfect on other phone. Screen from good phone works on good phone but not replaced battery phone. Any help is appreciated.
Thanks
Hello, I have changed my battery today and unfortunately I also managed to damage this curly shaped ribbon - in photo 15 - it is still the part remaining in the upper back casing
https://photos.app.goo.gl/RvfyeNw3EgsjS6... this is a close of the bit I am talking about.
https://photos.app.goo.gl/qL27oBbgQDD5Gx... and this is a photo of my actual phone / part
Does anybody know what this might be, and more importantly, can it be replaced / repaired?
I suspect it might be to do with WIFI signal, as it dropping in and out now, and showing poor signal strength.
thanks for any advice,
Carl
