주요 콘텐츠로 건너뛰기
블루투스를 사용하는 스마트 피트니스 워치, 2016년 3월에 출시되었습니다. 모델 : FB502SBUL
Fitbit Blaze only works in charger
My Fitbit Blaze works fine in the charger but shuts off immediately if the charger is unplugged or the watch is taken out of the charger. Can’t even reset using the reset procedure from Fitbit as there is no power at all. Shows 100% when in the charger. Is the battery a realistic possibility? It can’t imagine it is but the alternative sucks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
If it works on the charger but not when on the battery only, then most likely the battery has failed and needs to be replaced.
Here’s a link to the ifixit Fitbit Blaze Battery Replacement guide, which shows how to replace the battery.
ifixit sell a battery for the watch. Here’s a link Fitbit Blaze Battery
There are also other suppliers that may suit you better. Just search online for LSSP321830 to get results.
Replace a 170 mAh battery compatible with the Fitbit Blaze smartwatch. 3.7 Volts (V). 이미지
제품
$19.99
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Chris Chandler 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 5,351
