주요 콘텐츠로 건너뛰기
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
20 질문 전체 보기
Broke digitizer flap on PSP 2000
I accidently flipped the digitizer flap the wrong way, and it fell off. What should I do? Can I tape the flap back on while the ribbon cable is in?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@brododragon You could try and see if it will work. The lock is what a. secures the cables and b. puts pressure on the top pins to connect to the cable. Without the lock, your connector may not make proper contact with the cable. Worst case scenario is to purchase a broken board from place like ebay etc. and then harvest the connector from that one. Of course, the will require some good soldering skills as well as having to have the proper tools.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Brody 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 10
전체 시간: 165
