주요 콘텐츠로 건너뛰기
iFixit은 쿠키를 사용하여 사이트 기능을 개선하고 트래픽을 분석하며 광고를 개인화합니다. 당사 사이트를 사용함으로써 귀하는 당사의 쿠키 사용 및 개인정보 취급방침에 동의하게 됩니다.
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 질문 전체 보기
I don t have display on my monitor
Hello i don t have display on my monitor and i tried to change RAM and it's not working. I tried whit HDMI and VGA it's still not working.I tried RAM and video card on another pc and RAM worked and video card didn't, after I got another older video card and I tried and I still have no image.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@cristiandaniel you did not tell us anything about the computer. at least let us know what make and model your motherboard is . Also, let us know if you tried the monitor on another computer to make sure that it is working. You already know that there is at least a partially fault with your video card "video card didn't". You mentioned that you tried HDMI and VGA as well, are those outputs from your video card or from your motherboard. If your monitor works on another computer or if you tried a known-working monitor on your computer, then the issue will be the video card.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Cristian Daniel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 35
