주요 콘텐츠로 건너뛰기
Released March 2010. Model number FA1-0062-06.
How can I tell if the problem is the fuse?
How can I tell if the problem is the fuse? Is there “a tell” that the problem is the motor or circuit board before searching for fuses? For the 1st micro second it moves an inch like it’s getting power.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
Use a multimeter and test it for continuity:
Vornado Duo Fuse Replacement
이 답변이 도움이 되었나요?
점수 0
댓글 달기
@djlaine17 you can't, until you test it with a multimeter. If you have not done this before, check something like [https://www.youtube.com/watch?v=Kxl-IjEl... |this video for the How-To.
This "micro second it moves an inch" leads me to believe that it is not your fuse. When the fuse is "blown" there is not power going through the circuit. None. That means you would not get ANY movement. The issue you are describing sounds like either a capacitor issue or a motor driver issue. Once you checked the fuse to verify, check the circuit board Vornado Duo Circuit Board Replacement for any obviously damaged looking component or burned traces etc. Post some pictures of what you find/see with your question. That way we can see what you see. Also, make sure that tell us the exact make and model of your fan
기존 질문에 이미지 추가하기
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
매우 쉬움
2 - 5 minutes
Vornado Duo Circuit Board 이미지
안내서
난이도:
조정
9 - 10 minutes
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Djlaine17 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 288
