주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel 3 Battery Replacement
필요한 것
    1. Google Pixel 3 Battery Replacement, Weaken the back cover's adhesive: 1 단계, 이미지 1개 중 1개
      댓글 쓰기
    2. Google Pixel 3 Battery Replacement, Create a gap in the seam: 2 단계, 이미지 3개 중 1개 Google Pixel 3 Battery Replacement, Create a gap in the seam: 2 단계, 이미지 3개 중 2개 Google Pixel 3 Battery Replacement, Create a gap in the seam: 2 단계, 이미지 3개 중 3개
      • Apply a suction cup to the heated bottom edge of the back cover.
      • Make sure you did not mistake the screen side for the back cover side.
      • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
      • Lift on the suction cup with strong, steady force to create a gap.
      • Depending on how aged your phone is, this may take significant force. If you are having trouble, apply more heat and try again.
      • Insert an opening pick into the gap.
      • Don't use metal tools to pry, or you'll mar or shatter the glass back cover. If the panel won't budge, apply more heat, either with a hair dryer or heat gun.
      댓글 쓰기
    3. Google Pixel 3 Battery Replacement, Fingerprint cable information: 3 단계, 이미지 1개 중 1개
      • When inserting an opening pick above the power button, be careful not to insert the pick too deeply, or you will damage the fingerprint sensor cable.
      댓글 쓰기
    4. Google Pixel 3 Battery Replacement, Cut through the adhesive: 4 단계, 이미지 3개 중 1개 Google Pixel 3 Battery Replacement, Cut through the adhesive: 4 단계, 이미지 3개 중 2개 Google Pixel 3 Battery Replacement, Cut through the adhesive: 4 단계, 이미지 3개 중 3개
      • Slice the adhesive along the bottom edge of the phone and around the right corner.
      • Leave a pick in the bottom edge to prevent the adhesive from re-sealing.
      댓글 쓰기
    5. Google Pixel 3 Battery Replacement: 5 단계, 이미지 3개 중 1개 Google Pixel 3 Battery Replacement: 5 단계, 이미지 3개 중 2개 Google Pixel 3 Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Heat the right edge with an iOpener and continue slicing the adhesive with an opening pick.
      • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
      댓글 쓰기
    6. Google Pixel 3 Battery Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 3 Battery Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 3 Battery Replacement: 6 단계, 이미지 3개 중 3개
      • Continue heating and slicing through the rest of the phone perimeter. Leave a pick in each edge to prevent the adhesive from resealing.
      • When slicing above the power button, do not insert the pick more than halfway in to avoid damaging the fingerprint sensor cable.
      댓글 쓰기
    7. Google Pixel 3 Battery Replacement, Lift the left edge of the back cover: 7 단계, 이미지 3개 중 1개 Google Pixel 3 Battery Replacement, Lift the left edge of the back cover: 7 단계, 이미지 3개 중 2개 Google Pixel 3 Battery Replacement, Lift the left edge of the back cover: 7 단계, 이미지 3개 중 3개
      • Once you have sliced around the perimeter of the phone, carefully lift the left edge of the back cover.
      • Do not attempt to remove the back cover. It is still attached to the phone by the fingerprint sensor cable.
      • Flip the back cover along its long axis and rest it so that the fingerprint sensor cable is not strained.
      댓글 쓰기
    8. Google Pixel 3 Battery Replacement, Remove the screws: 8 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Magnetic Project Mat
      $19.95
      • Remove the two 4.1 mm-long Phillips screws securing the fingerprint connector bracket.
      • During reassembly, be careful not to over-tighten these screws, or you may damage your display.
      댓글 쓰기
    9. Google Pixel 3 Battery Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 3개 중 1개 Google Pixel 3 Battery Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 3개 중 2개 Google Pixel 3 Battery Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 3개 중 3개
      • Use the point of a spudger to slide the fingerprint connector bracket out from under the NFC coil.
      • Remove the fingerprint connector bracket.
      댓글 쓰기
    10. Google Pixel 3 Battery Replacement, Disconnect the fingerprint connector: 10 단계, 이미지 2개 중 1개 Google Pixel 3 Battery Replacement, Disconnect the fingerprint connector: 10 단계, 이미지 2개 중 2개
      • Use the point of a spudger to pry up and disconnect the fingerprint connector from its socket.
      • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      댓글 쓰기
    11. Google Pixel 3 Battery Replacement, Remove the back cover: 11 단계, 이미지 3개 중 1개 Google Pixel 3 Battery Replacement, Remove the back cover: 11 단계, 이미지 3개 중 2개 Google Pixel 3 Battery Replacement, Remove the back cover: 11 단계, 이미지 3개 중 3개
      • Remove the back cover.
      • Before you install a replacement back cover, be sure to remove all adhesive residue from the phone frame. Use an opening tool to scrape and high concentration isopropyl alcohol to clean the surface.
      • If you are re-using the back cover, be sure to clean off any adhesive, and apply new back cover adhesive.
      • If you are installing a replacement back cover, be sure to compare it with the original part. Transfer any remaining parts (such as the flash diffuser) over to your replacement part.
      • Follow this guide to correctly apply new back cover adhesive.
      댓글 쓰기
    1. Google Pixel 3 Battery Replacement, Remove the screws: 12 단계, 이미지 1개 중 1개
      • Remove the five Phillips screws securing the wireless charging coil:
      • Two 1.9 mm screws
      • Two 4.2 mm screws
      • One 4.3 mm screw
      댓글 쓰기
    2. Google Pixel 3 Battery Replacement, Remove the charging coil: 13 단계, 이미지 1개 중 1개
      • Lift up and remove the wireless charging coil.
      댓글 쓰기
    3. Google Pixel 3 Battery Replacement, Disconnect the battery cable: 14 단계, 이미지 2개 중 1개 Google Pixel 3 Battery Replacement, Disconnect the battery cable: 14 단계, 이미지 2개 중 2개
      • Use the point of a spudger to pry up and disconnect the battery press connector from its socket near the right edge of the phone.
      댓글 쓰기
    1. Google Pixel 3 Battery Replacement, Peel the black tape away from the battery: 15 단계, 이미지 3개 중 1개 Google Pixel 3 Battery Replacement, Peel the black tape away from the battery: 15 단계, 이미지 3개 중 2개 Google Pixel 3 Battery Replacement, Peel the black tape away from the battery: 15 단계, 이미지 3개 중 3개
      • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
      • Slide the point of a spudger in the crevice underneath the black tape bridging across the battery and the motherboard.
      • Slide the spudger along the crevice to pry up the tape from the battery side.
      • Carefully peel the tape from the battery and fold it out of the way.
      • The tape acts as a cooling pad for the motherboard and the battery. It will still work if it's torn.
      댓글 쓰기
    2. Google Pixel 3 Battery Replacement, Disconnect the buttons connector: 16 단계, 이미지 3개 중 1개 Google Pixel 3 Battery Replacement, Disconnect the buttons connector: 16 단계, 이미지 3개 중 2개 Google Pixel 3 Battery Replacement, Disconnect the buttons connector: 16 단계, 이미지 3개 중 3개
      • Use the point of a spudger to pry up and disconnect the buttons connector from its motherboard socket near the left edge of the phone.
      • Push the connector and its flex cable out of the way of the battery.
      댓글 쓰기
    3. Google Pixel 3 Battery Replacement, Loosen the pull tab: 17 단계, 이미지 3개 중 1개 Google Pixel 3 Battery Replacement, Loosen the pull tab: 17 단계, 이미지 3개 중 2개 Google Pixel 3 Battery Replacement, Loosen the pull tab: 17 단계, 이미지 3개 중 3개
      • Insert the point of a spudger underneath the black battery pull tab on the left edge of the phone.
      • Slide the spudger upwards along the edge to loosen the pull tab from the battery.
      • The battery is held in place with three separate stretch adhesive strips, which are connected to a single black pull tab. You can try to pull all three strips out together, but it is easier to cut the black pull tab where it is notched and pull each strip out individually.
      댓글 쓰기
    4. Google Pixel 3 Battery Replacement, Remove the pull tab: 18 단계, 이미지 3개 중 1개 Google Pixel 3 Battery Replacement, Remove the pull tab: 18 단계, 이미지 3개 중 2개 Google Pixel 3 Battery Replacement, Remove the pull tab: 18 단계, 이미지 3개 중 3개
      • Pull on the black pull tab at a shallow angle with steady force. When the adhesive grows long, roll it around some tweezer tips and continue pulling.
      • If the adhesive strips break, use an opening pick to help pry up and loosen the battery.
      • A flex cable runs underneath the battery. Don't pry near the cable, or you may damage it.
      • You can also fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops of alcohol under the left edge of the battery. Give the alcohol a minute to weaken the battery adhesive.
      댓글 쓰기
    5. Google Pixel 3 Battery Replacement, Remove the battery: 19 단계, 이미지 2개 중 1개 Google Pixel 3 Battery Replacement, Remove the battery: 19 단계, 이미지 2개 중 2개
      • Remove the battery.
      • Carefully pull and remove the small foam buffer block from the left edge of the battery and transfer it to your replacement part. If it begins to tear, use the flat end of a spudger to gently pry it off the battery.
      • To install a replacement battery:
      • Lay some double-sided tape in the phone's battery well. If you're using Tesa tape to reattach components, follow this guide. If using stretch-release adhesive, follow this guide.
      • Temporarily re-connect the battery's connector to the motherboard socket. This ensures that the battery is properly positioned.
      • Peel away any tape liners to expose the adhesive.
      • Lay the battery on the adhesive and press firmly.
      • Disconnect the battery connector from its motherboard socket and resume re-assembly.
      댓글 쓰기
결론
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Check out our Google Pixel 3 Answers community for troubleshooting help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 172명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
344,201 평판
안내서 915개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 32,317개를 작성함
53가이드 댓글
Removing the adhesive from the rear glass can be a tedious process. I got my best results by taking fine point tweezers and pulling the adhesive back slowly, trying to get it to come up altogether as much as possible before using IPA to remove any residue.
Brody Mistrot - 답글 공유
How do you put the adhesive back (or put new adhesive on) when putting the phone back together?
Brian Ferraro - 답글 공유
@bfferraro, it depends on the type of adhesive.
If you are using a pre-cut adhesive sheet, follow this guide.
If you have a custom-cut adhesive, follow this guide.
Arthur Shi - 답글 공유
What thickness(es) of tape is/are required to complete the battery replacement process?
mpc - 답글 공유
Hi mpc,
The tape does not need to be thick at all. You can use standard double-sided tape, or the fancier stretch-release adhesive.
Arthur Shi - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 24
지난 7일: 127
지난 30일: 638
전체 시간: 203,455
