주요 콘텐츠로 건너뛰기
Xiaomi Redmi Note 8T Battery Replacement
필요한 것
  1. Xiaomi Redmi Note 8T Battery Replacement, Xiaomi Redmi Note 8T Rear Glass Removal: 1 단계, 이미지 1/1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Xiaomi Redmi Note 8T Battery Replacement: 2 단계, 이미지 1/3 Xiaomi Redmi Note 8T Battery Replacement: 2 단계, 이미지 2/3 Xiaomi Redmi Note 8T Battery Replacement: 2 단계, 이미지 3/3
    • Secure a suction handle to the bottom of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Xiaomi Redmi Note 8T Battery Replacement: 3 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement: 3 단계, 이미지 2/2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    • Don't remove the suction handle yet. You're going to use it later in the removal procedure as a rear glass stand.
  4. Xiaomi Redmi Note 8T Battery Replacement: 4 단계, 이미지 1/3 Xiaomi Redmi Note 8T Battery Replacement: 4 단계, 이미지 2/3 Xiaomi Redmi Note 8T Battery Replacement: 4 단계, 이미지 3/3
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Redmi Note 8T Battery Replacement: 5 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement: 5 단계, 이미지 2/2
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Redmi Note 8T Battery Replacement: 6 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement: 6 단계, 이미지 2/2
    • Do not insert the opening pick deeper than 5 mm to avoid damaging the fingerprint connector.
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
    • Do not remove the rear glass all the way yet, the fingerprint cable is still connected to the motherboard.
  7. Xiaomi Redmi Note 8T Battery Replacement: 7 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement: 7 단계, 이미지 2/2
    • Carefully fold the rear glass to the right side of the phone. Use the suction handle as a stand for the rear glass.
  8. Xiaomi Redmi Note 8T Battery Replacement: 8 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement: 8 단계, 이미지 2/2
    • Use a spudger to pry up and disconnect the fingerprint flex cable.
    • Remove the rear glass.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  9. 주의: 9-11 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Xiaomi Redmi Note 8T Battery Replacement, Xiaomi Redmi Note 8T Motherboard Cover Removal: 9 단계, 이미지 1/1
    • Remove the eleven Phillips #00 screws (3.9 mm length).
  10. Xiaomi Redmi Note 8T Battery Replacement: 10 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement: 10 단계, 이미지 2/2
    • Insert the tip of an opening pick underneath the bottom edge of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  11. Xiaomi Redmi Note 8T Battery Replacement: 11 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement: 11 단계, 이미지 2/2
    • Remove the motherboard cover including the black protective foil that covers the battery.
  12. 주의: 12 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
    Xiaomi Redmi Note 8T Battery Replacement, Xiaomi Redmi Note 8T Battery Disconnect: 12 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement, Xiaomi Redmi Note 8T Battery Disconnect: 12 단계, 이미지 2/2
    • Use a spudger to pry up and disconnect the battery flex cable.
  13. Xiaomi Redmi Note 8T Battery Replacement, Battery: 13 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement, Battery: 13 단계, 이미지 2/2
    • Use a spudger to pry up and disconnect the main flex cable.
  14. Xiaomi Redmi Note 8T Battery Replacement: 14 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement: 14 단계, 이미지 2/2
    • Use a spudger to pry up and disconnect the display flex cable.
  15. Xiaomi Redmi Note 8T Battery Replacement: 15 단계, 이미지 1/3 Xiaomi Redmi Note 8T Battery Replacement: 15 단계, 이미지 2/3 Xiaomi Redmi Note 8T Battery Replacement: 15 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to carefully peel the black ends of the two adhesive strips off the bottom edge of the battery.
  16. Xiaomi Redmi Note 8T Battery Replacement: 16 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement: 16 단계, 이미지 2/2
    • Use a pair of tweezers to pull out the adhesive tabs from underneath the battery.
    • The adhesive tabs underneath the battery can rip very easily. Make sure you pull out the tabs in a slow and steady motion and in a flat angle. To prevent the adhesive tabs from ripping, it's helpfull to twist the strip around the tweezers.
    • If you manage to pull out both of the adhesive strips without ripping you can jump to Step 21 in order to remove the battery. If one of your adhesive strips rips during the removal, continue with the following step.
  17. Xiaomi Redmi Note 8T Battery Replacement: 17 단계, 이미지 1/1
    • Apply a heated iOpener to the screen to loosen the adhesive beneath the battery. Apply the iOpener for at least two minutes.
  18. Xiaomi Redmi Note 8T Battery Replacement: 18 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement: 18 단계, 이미지 2/2
    • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert a spudger into the gap between the daughterboard cover and the battery at the bottom left corner of the battery.
    • Use the spudger to pry up the battery until you created a small gap underneath.
  19. Xiaomi Redmi Note 8T Battery Replacement: 19 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement: 19 단계, 이미지 2/2
    • Slide a plastic or playing card into the gap you created with the spudger.
  20. Xiaomi Redmi Note 8T Battery Replacement: 20 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement: 20 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Slide the plastic card underneath the battery and cut the adhesive with it. Work your way along the left edge of the battery until you've loosened all adhesive.
  21. Xiaomi Redmi Note 8T Battery Replacement: 21 단계, 이미지 1/2 Xiaomi Redmi Note 8T Battery Replacement: 21 단계, 이미지 2/2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Before adhering the battery, temporarily reconnect it to help align it correctly. Adhere the battery to the phone and then disconnect it and continue reassembling your phone.
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, '''calibrate your newly installed battery''': Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
다른 12명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
204,668 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,392개 작성하였습니다
댓글 2개
Ein Tipp zu abgerissenen Klebestreifen, was nach 4 Jahren zu 98% passieren wird!
Zahnsteines hilft ungemein
EnRico - 답글
Vielen Dank Spitze gut geführte Anleitung
Stefan Jürgen Hermann - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 96
30일 전: 412
전체 시간: 19,605
