주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 15 Pro Screen Replacement
필요한 것
  1. iPhone 15 Pro Screen Replacement, Prepare your iPhone for disassembly: 1 단계, 이미지 2개 중 1개 iPhone 15 Pro Screen Replacement, Prepare your iPhone for disassembly: 1 단계, 이미지 2개 중 2개
    • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Hold the power and either volume button and slide to power off your phone.
  2. iPhone 15 Pro Screen Replacement, Tape over any cracks: 2 단계, 이미지 2개 중 1개 iPhone 15 Pro Screen Replacement, Tape over any cracks: 2 단계, 이미지 2개 중 2개
    • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Pro Screen Replacement, Mark your opening picks: 3 단계, 이미지 3개 중 1개 iPhone 15 Pro Screen Replacement, Mark your opening picks: 3 단계, 이미지 3개 중 2개 iPhone 15 Pro Screen Replacement, Mark your opening picks: 3 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  4. iPhone 15 Pro Screen Replacement, Remove the pentalobe screws: 4 단계, 이미지 2개 중 1개 iPhone 15 Pro Screen Replacement, Remove the pentalobe screws: 4 단계, 이미지 2개 중 2개
    • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
  5. iPhone 15 Pro Screen Replacement, Heat the bottom edge: 5 단계, 이미지 1개 중 1개
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Pro Screen Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 1개 iPhone 15 Pro Screen Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 2개 iPhone 15 Pro Screen Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 3개
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Pro Screen Replacement, Screen information: 7 단계, 이미지 1개 중 1개
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  8. iPhone 15 Pro Screen Replacement, Separate the bottom edge adhesive: 8 단계, 이미지 3개 중 1개 iPhone 15 Pro Screen Replacement, Separate the bottom edge adhesive: 8 단계, 이미지 3개 중 2개 iPhone 15 Pro Screen Replacement, Separate the bottom edge adhesive: 8 단계, 이미지 3개 중 3개
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Pro Screen Replacement, Heat the right edge: 9 단계, 이미지 1개 중 1개
    • Heat the right edge of the screen until it's hot to the touch.
  10. iPhone 15 Pro Screen Replacement, Position the opening pick: 10 단계, 이미지 3개 중 1개 iPhone 15 Pro Screen Replacement, Position the opening pick: 10 단계, 이미지 3개 중 2개 iPhone 15 Pro Screen Replacement, Position the opening pick: 10 단계, 이미지 3개 중 3개
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
  11. iPhone 15 Pro Screen Replacement, Release the right clip: 11 단계, 이미지 3개 중 1개 iPhone 15 Pro Screen Replacement, Release the right clip: 11 단계, 이미지 3개 중 2개 iPhone 15 Pro Screen Replacement, Release the right clip: 11 단계, 이미지 3개 중 3개
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
  12. iPhone 15 Pro Screen Replacement, Separate the right edge adhesive: 12 단계, 이미지 3개 중 1개 iPhone 15 Pro Screen Replacement, Separate the right edge adhesive: 12 단계, 이미지 3개 중 2개 iPhone 15 Pro Screen Replacement, Separate the right edge adhesive: 12 단계, 이미지 3개 중 3개
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
  13. iPhone 15 Pro Screen Replacement, Heat the top edge: 13 단계, 이미지 1개 중 1개
    • Heat the top edge of the screen until it's hot to the touch.
  14. iPhone 15 Pro Screen Replacement, Separate the top edge adhesive: 14 단계, 이미지 3개 중 1개 iPhone 15 Pro Screen Replacement, Separate the top edge adhesive: 14 단계, 이미지 3개 중 2개 iPhone 15 Pro Screen Replacement, Separate the top edge adhesive: 14 단계, 이미지 3개 중 3개
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
  15. iPhone 15 Pro Screen Replacement, Heat the left edge: 15 단계, 이미지 1개 중 1개
    • Heat the left edge of the screen until it's hot to the touch.
  16. iPhone 15 Pro Screen Replacement, Separate the left edge adhesive: 16 단계, 이미지 3개 중 1개 iPhone 15 Pro Screen Replacement, Separate the left edge adhesive: 16 단계, 이미지 3개 중 2개 iPhone 15 Pro Screen Replacement, Separate the left edge adhesive: 16 단계, 이미지 3개 중 3개
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
  17. iPhone 15 Pro Screen Replacement, Prop up the screen: 17 단계, 이미지 3개 중 1개 iPhone 15 Pro Screen Replacement, Prop up the screen: 17 단계, 이미지 3개 중 2개 iPhone 15 Pro Screen Replacement, Prop up the screen: 17 단계, 이미지 3개 중 3개
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access its cables without straining them.
  18. iPhone 15 Pro Screen Replacement, Unfasten the logic board cover: 18 단계, 이미지 2개 중 1개 iPhone 15 Pro Screen Replacement, Unfasten the logic board cover: 18 단계, 이미지 2개 중 2개
    • Use a Y000 screwdriver to remove the six screws securing the logic board cover:
    • Four 1.6 mm‑long screws
    • Two 1.3 mm‑long screws
  19. iPhone 15 Pro Screen Replacement, Remove the logic board cover: 19 단계, 이미지 3개 중 1개 iPhone 15 Pro Screen Replacement, Remove the logic board cover: 19 단계, 이미지 3개 중 2개 iPhone 15 Pro Screen Replacement, Remove the logic board cover: 19 단계, 이미지 3개 중 3개
    • Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
    • During reassembly, make sure the top left corner of the cover goes under the ambient light sensor cable.
  20. iPhone 15 Pro Screen Replacement, Disconnect the battery: 20 단계, 이미지 3개 중 1개 iPhone 15 Pro Screen Replacement, Disconnect the battery: 20 단계, 이미지 3개 중 2개 iPhone 15 Pro Screen Replacement, Disconnect the battery: 20 단계, 이미지 3개 중 3개
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  21. iPhone 15 Pro Screen Replacement, Disconnect the screen: 21 단계, 이미지 2개 중 1개 iPhone 15 Pro Screen Replacement, Disconnect the screen: 21 단계, 이미지 2개 중 2개
    • Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
  22. iPhone 15 Pro Screen Replacement, Disconnect the ambient light sensor: 22 단계, 이미지 2개 중 1개 iPhone 15 Pro Screen Replacement, Disconnect the ambient light sensor: 22 단계, 이미지 2개 중 2개
    • Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
    • Lift the cable to disconnect it.
  23. iPhone 15 Pro Screen Replacement, Remove the screen: 23 단계, 이미지 2개 중 1개 iPhone 15 Pro Screen Replacement, Remove the screen: 23 단계, 이미지 2개 중 2개
    • Remove the screen.
    • During reassembly, follow this guide to apply new adhesive and install your screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
  24. iPhone 15 Pro Screen Replacement, Ambient light sensor information: 24 단계, 이미지 2개 중 1개 iPhone 15 Pro Screen Replacement, Ambient light sensor information: 24 단계, 이미지 2개 중 2개
    • Check if your new screen comes with an ambient light sensor installed.
    • If it doesn't, follow the remaining steps to remove and transfer the sensor from your original screen to your replacement.
  25. iPhone 15 Pro Screen Replacement, Remove the ambient light sensor cover screws: 25 단계, 이미지 2개 중 1개 iPhone 15 Pro Screen Replacement, Remove the ambient light sensor cover screws: 25 단계, 이미지 2개 중 2개
    • Use a Phillips #000 driver to remove the two screws securing the ambient light sensor cover.
  26. iPhone 15 Pro Screen Replacement, Remove the ambient light sensor cover: 26 단계, 이미지 1개 중 1개
    • Remove the ambient light sensor cover.
  27. iPhone 15 Pro Screen Replacement, Heat the ambient light sensor adhesive: 27 단계, 이미지 1개 중 1개
    • Be careful not to overheat the screen—the plastic components can melt if they get too hot.
    • Use a hair dryer or heat gun to heat the ambient light sensor until it's warm to the touch.
  28. iPhone 15 Pro Screen Replacement, Pry up the sensor: 28 단계, 이미지 2개 중 1개 iPhone 15 Pro Screen Replacement, Pry up the sensor: 28 단계, 이미지 2개 중 2개
    • Be very gentle handing the ambient light sensor, as its cable is extremely fragile.
    • use the flat end of a spudger to gently lift the ambient light sensor out of its enclosure.
  29. iPhone 15 Pro Screen Replacement, Reheat the ambient light sensor: 29 단계, 이미지 1개 중 1개
    • By this point, the sensor has likely cooled down.
    • Apply more heat until the entire glued down part of the sensor is warm to the touch.
  30. iPhone 15 Pro Screen Replacement: 30 단계, 이미지 3개 중 1개 iPhone 15 Pro Screen Replacement: 30 단계, 이미지 3개 중 2개 iPhone 15 Pro Screen Replacement: 30 단계, 이미지 3개 중 3개
    • Insert the tip of an opening pick under the bottom right corner of the sensor.
    • Slide the pick under the sensor and lift until you can grip it with your fingers.
  31. iPhone 15 Pro Screen Replacement, Remove the ambient light sensor: 31 단계, 이미지 1개 중 1개
    • Use your fingers to slowly peel up and remove the sensor.
결론
To reassemble your iPhone, follow this guide to apply new adhesive and install your screen.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
다른 31명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
163,700 평판
안내서 1,043개를 작성함
iFixit iFixit 회원
Staff
124 회원들
안내서 24,240개를 작성함
8가이드 댓글
Very helpful
Roger Dunham - 답글 공유
Pls also make the videos of your guides available on YouTube so it can be more understandable
Seyi Raji - 답글 공유
Where the hell do you buy the replacement display on the iFixIt website?
Anonymous - 답글 공유
You can buy it at selfservicerepair.com it is a lot cheaper there
nicholaswiding - 공유
This adhesive is way more annoying than it has any logical reason to be.
Seth Blagg - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 148
지난 7일: 1,023
지난 30일: 4,520
전체 시간: 80,399
