소개
Follow this guide to replace the Wi-Fi diversity antenna and flex cable in your iPhone 8. This may help resolve connectivity issues.
도구
부품
Power off your iPhone before beginning disassembly.
Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Insert an opening pick into the gap.
Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
Two 1.3 mm screws
Two 2.8 mm screws
Remove the bracket.
Use the point of a spudger to pry the lower display connector out of its socket.
Remove the three screws securing the bracket next to the Taptic Engine:
One 1.3 mm Y000 screw
One 2.7 mm Phillips screw
One 2.9 mm Phillips screw
To reassemble your device, reapply the display adhesive and follow these instructions in reverse order.
Repair didn’t go as planned? Check out our iPhone 8 Answers community for troubleshooting help.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Hello, The power of my iphone 8 plus other products is lower than the mains and wifi. When I dismantle the product in question, there is no change. Which product should change. The reason is that when I hold the top part of the phone the wifi and mains power is falling more and more.
