주요 콘텐츠로 건너뛰기
TI-84 Plus calculator support.
20 질문 전체 보기
Why does my TI-84 plus calculator say RAM cleared?
When turning on my calculator, the screen displays "RAM cleared" and "press alpha F1-F4 to locate shortcut menus." After pressing alpha F1-F4 there is no change in the display and none of the buttons appear to work or change the display. The only way to get the display off is to pull out the battery :( Any ideas on how to fix this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi @jackicca ,
When you say "pull out the battery" do you mean the 4 x AAA batteries?
Have you also tried removing/reinserting the small backup button battery (designed to retain the memory when the main batteries are changed) as well as the main batteries, to see if this resets the calculator and clears the problem?
Here is a link to the ifixit TI-84 Plus Silver Edition Backup Battery Replacement which shows where it is and how to do it.
Hopefully this is of some help
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Jackson Chen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 37
전체 시간: 26,193
