주요 콘텐츠로 건너뛰기
iPad 2 Wi-Fi EMC 2560 Battery Replacement
Sam Goldheart
Sam Goldheart8 다른 기여자
최종 수정일 August 22, 2024
45 분 - 3 시간
매우 어려움
Use this guide to replace a worn-out battery and give your iPad new life. If your battery is swollen, take appropriate precautions.
필요한 것
수리 키트
이 키트는 이 안내서를 완료하는데 필요한 모든 부품과 도구를 포함하고 있습니다.
  • iPad 2 Battery
    iPad 2 Battery
부품
도구
더보기...
  1. iPad 2 Wi-Fi EMC 2560 Battery Replacement, iOpener Heating: 1 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement, iOpener Heating: 1 단계, 이미지 2개 중 2개
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - 답글
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - 답글
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - 답글
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - 답글
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - 답글
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - 답글
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - 답글
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - 답글
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - 답글
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - 답글
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - 답글
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - 답글
    My experience. I was replacing the screen which had been cracked and a little shattered in some places. The iopener is pretty much useless, so was the suction cup. The suction cup would probably be more useful if I was doing something besides the screen. Also you probably want the clean the screen before using it so it can get good suction. I used a hair dryer on high for a couple of minutes at a time (someone on this tread suggested that). I used my exacto knife and a razor blade to get into the adhesive. First the exacto to get the initial cut, then the razor blade to go a little deeper. Could have probably just used the razor blade, but the exacto has a little more finesse. I got the razor blade in and a little under the glass then I used the picks to wedge in. I didn’t want to risk anything using the razor blade too much. Used tape to keep the shattered glass together.
    trebor65 - 답글
    My experience pt2
    Fortunately the shattering was mostly on the edges and most of it had adhesive on the back so it stuck together. Just take your time and work your way around following the guide to get the screen off. Have some goof off or goo be gone to clean the frame when putting the new glass on or putting the existing one back. (someone suggested that also, very good idea). Be careful of the LCD (you should know that). The cable on my LCD was pretty tight, so I propped it up while taking the cable cover off and when I put it back on I did the same thing. I just put a bottle on the battery and leaned the back of the LCD on that while attaching the cables and putting the screws back on the cover. Also be careful with the home button and the bracket on the back of it. I had enough old adhesive on left on the bracket that it stuck back to the new glass fine. So far only 12 hours in, so we will see how that holds up when the kids get at it.
    trebor65 - 답글
    Another alternative if you do not have the iopener is to use a bed time hotwater bottle. Do not over fill it though. Just put enough hot water in to support the phone while you work around the adhesive.
    I use both the hot water bottle and iopener together on Samsung's. It makes life easier
    gazza667 - 답글
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. This allowed me to separate the last bit of the back of my Samsung S8, which was already coming off due to a swollen battery (hence the reason for the repair).
    Dennis - 답글
    Hallo,habe den Akku erfolgreich getauscht.Doch seitdem gibt es bei Telefonaten eine Rückkopplung für den anrufenden.Bei mir ist alles normal.Woran liegt das?Mfg
    Manu R - 답글
    If you follow these instructions, you will crack your screen like I did. Heating the iOpener for 30 seconds, using it to melt glue, then waiting 10 minutes to reheat is useless. The iOpener can be used to maybe warm the glue on whatever side you aren’t working on. You need a hairdryer and/or a heat gun to melt the glue and separate the glass from the iPad.
    Anyone want to buy an old iPad with broken glass and a dead battery?
    mpulliam - 답글
    Not everybody has a microwave. You should provide a target temperature for the iOpener and instructions for a conventional oven, or pot of warm water, or whatever. Although I will probably use a heat gun …
    Esmond Pitt - 답글
    Three times heating opener and no luck. Tried pressing down gently on opener with a towel, and the opener broke. Wondering if I now replace table mats, fancy table cloth, etc. or will this stuff wash out.
    Not impressed so far. Maybe the hair dryer next.
    doug - 답글
    I support the comments about the iOpener. Everyone has a hair drier, FHS, so get a cheap IR thermometer (£18) and blow heat until the area is 60+ deg C. Still takes w while, and getting the screen off is v scary, but just add more heat if you feel resistance.
    The rest of the kit is good, esp the magnetic screwdrivers.
    Richard O'Brien - 답글
    No, everyone does not have a hairdryer. Some of us don’t even have hair. Thank goodness I already had an IR thermometer, though.
    nin10doh -
    #### WARNUNG WENN MINIMALSTER SPRUNG IM DISPLAY IST FUNKTIONERT DAS NICHT!!! ######
    Hatte einen winzigen, minimalen Sprung im Display. Ich dachte es könnte gehen, weil der Sprung “abgeschlossen” war. Er hat in einer Ecke ein winzige Glasteil rausgeschnitten. NEIN! Geht nicht. Habe alles mit viel Geduld dem iOpener und einem Föhn erhitzt. Es ist trotzdem sofort über das komplette Display zersprungen…
    T z - 답글
    I’ve started with iOpener but changed very quickly to a heatgun. That was more efficient.
    Mizzoo, s.r.o. - 답글
    I could not get the iOpener hot enough to melt the glue on my ipad 6. I heated for 45 seconds once and it was boiling and it still never worked. Thank goodness contributors mentioned using a hair dryer. Using an 1700w hair dryer on high did the trick to get the screen off. Still took some time and the case got pretty hot but be patient. It took twice as long and a lot more patience to get the battery out.
    Randal Haufler - 답글
    I have an Ipad with touch screen issue, if i replace this part it should be Ok?
    janderson martin - 답글
    WARNING - DO NOT MICROWAVE ON A METAL MICROWAVE RACK
    The metal microwave rack can heat up and melt through the iOpener cover letting the contents leak out.
    Not a big issue for me as I have a heat gun and used that instead.
    Run Up A Tree - 답글
    I opened my iPad with the iOpener. Be patient! It may take quite a bit longer to it the iOpener in the microwave than it says in the guide. My microwave can only do 800W and I had to put the iOpener in several times (maybe a total of 90-120 seconds). I recommend that you have the transparent side up an watch the bag carefully. As long a the bag doesn't bloat up and the liquid doesn't start bubbling you should be fine. But I recommend to take the iO out from time to time to check it. (More comments in Step 6.)
    marcelflueeler - 답글
    I gave upon the I opener and used a hairdryer. (Fixed an iPad 6)
    Tom Weber - 답글
    iPad mini gen5. I used the iOpener. My microwave is 1200w with carousel. 30 sec got the iOpener to 155ºF. For the 2nd heating, after 10 minutes sitting, the temp was still around 125º so I only cooked it for 15 sec. Not enough increase so +5 sec more which me to 165-170ºF. This should be considered ballpark info because who knows the real output of the various microwaves and the quality of the IR tool used to determine temp.
    To successfully open my iPad mini I applied the iOpener twice to the left edge and twice to bottom. & once to R edge. Using the suction cup was difficult for me (I'm in my 70's so my hands don't work too well anymore). I had trouble holding the guitar pick and slipping them in (at an downward angle). In the end, sliding my thumbnail along the edge opened it very slightly and allowed the pick to get into the gap. I marked the ends of all my picks with a sharpie pen for the recommended 2mm insertion to avoid going in too deep. To get the screen open it took me approx 1 hour.
    jharrison - 답글
    Can’t you just use a hair curler instead?
    Aspect22 - 답글
    A hairdryer or heat gun works, if heating is kept around 100 deg C (212 deg F - boiling point of water). But… heating this way is cumbersome. Using a hotplate, set to 100 deg C, measured carefully with a fairly inexpensive IR gun, is simpler and easier, if you can afford the hotplate (I used an old pancake griddle with a thermostat knob). It works great for phones, setting them face down for 2 minutes, then picking them up with insulated gloves - cheap, wool gloves work fine. This may require repeated reheating to continue the display removal, but its much simpler.
    Because its almost impossible to repeatedly lay an iPad/tablet on the hot plate, I propose an alternative.
    Initially lay the larger iPad/tablet, face down, for 2 min, to heat all of the adhesive surrounding the display. Lift and begin the picking process describe in your removal steps. Then lay an iOpener on the hotplate for 2 min (already set to the exact, desired temp) to bring it to working temp for the remaining operations.
    Dan Smith - 답글
    For iPads in particular, it makes sense to construct a simple, aluminum window frame, laid on a hotplate (see my comment above) that only touches the edges of the display, heating only the adhesive underneath. This prevents general heating of the entire device. Four strips of aluminum, placed together as a frame, would be the simplest and allow variations for all devices - envision it as a pinwheel of strips, radiating outward. Use it for any size device.
    Dan Smith - 답글
    BTW, always read all comments at each step. New, and possibly useful, suggestions appear on occasion that can be crucial.
    Dan Smith - 답글
    My iOpener got damaged at the first heating (30 s @ 800 W). The bag got a little melted hole where the liquid came out and a little melted area. I used a combination oven (normal heat and microwave) in microwave only mode. It has a metal grill where the iOpener was placed on. I suppose the metal grill concentrates the microwaves at some points and there the bag melted?
    K. Fe - 답글
  2. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - 답글
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - 답글
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - 답글
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - 답글
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - 답글
    Now that is a very good idea :) I was going to use a hairdryer
    Maz -
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - 답글
    I agree with this.
    Jarl Friis -
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - 답글
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - 답글
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - 답글
    Great idea with using the heat packs. I will try that next time. Thank you
    Collins -
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - 답글
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - 답글
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - 답글
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - 답글
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Miesch -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - 답글
    Thank you for posting some actual temperatures. I have a heat gun with a very fine self-temperature regulation setting capability.
    I will set it for 150-180 F, and use that to soften the adhesive.
    G Trieste -
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. A second heating about 15 minutes later in the micro and it came out at 190 degrees F. Plenty hot enough to soften the adhesive for removing the back on my S8. Based on the comments above I think people just need to use more patience.
    Dennis - 답글
    I used various time settings. It got very hot. It would soften the glue but not a whole lot. If my screen had been intact and I was replacing something that was not a digitizer, it may have worked. A broken screen makes the process significantly more difficult. I ended up breaking the home button cable. Good bye TouchID…
    cvela90 - 답글
    After reading previous comments I didn't even use the i-opener. Used the heatgun ( hairdryer ) which works great for me. Maybe I was lucky as this is my first attempt at replacing a cellphone battery. Motoz 3
    Collins - 답글
    It appeared 30 seconds were not enough, so I heated it more, by 5 seconds at a time until I got the right temperature about 70 degrees Celsius (measured with infrared pistol) to get the screen heated up to 60 C, the best for softening the glue. But the heat was quickly dissipating by the big aluminum back cover, so the best I got in 2 minutes of applying iOpener was around 45 C, which made the procedure difficult and having risk of breaking the screen. So I eventually abandoned iOpener and user a hot air gun with precise temperature setup. I set it to 90 C, which allowed me to open my iPad quickly and safely.
    Sergey Kofanov - 답글
    I, too, ended up using a hot air gun. I’ve done earlier versions of iPad before but the adhesive used on this IPad 5 A1822 was particularly difficult to remove.
    Also, while the suction cup worked great when the glass is in tact, any cracks in the glass make the suction cup useless.
    manningrl - 답글
    You need to remember here are different sizes of microwaves. I had the same issue.
    Heating on a smaller unit I used 45-60 seconds. That worked but was time comsuming
    William Draheim - 답글
    Yeah, the iOpener didn't work for me either.... ended up using a hair dryer and that worked. The iOpener was too warm to soften the glue in my case.
    Andrés Vettori - 답글
    I had a rotating plate microwave for my repair, and heating the iOpener 30-40 seconds worked plenty well for me.
    Ciarán - 답글
  3. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - 답글
    I did too, you get far more control and no expense on fancy equipment.
    Billinski -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    breadandbits - 답글
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - 답글
    I vote for the hair dryer. The other methods work too but if you aren’t having any luck, switch to the hair dryer. While holding the iPad in my hand, I found that I am aiming the dryer at my finger at the same time and it gauges how hot it is. I stop when my finger can’t take it - maybe five seconds up close. Repeat as needed like I did.
    Robin - 답글
    This thing melts when placed up side down in the microwave…
    Mark - 답글
    If the maximum temperature for this iOpener is lower than the gadget glue minimum temperature, this device does not make sense.
    I think the maximum temperature for this iOpener is below 100⁰C and most gadget glue minimum temperature is higher than 100⁰C. So the iOpener is useless for many opening steps in repair guides. But who knows because temperature range is not specified for this iOpener.
    Jarl Friis - 답글
  4. iPad 2 Wi-Fi EMC 2560 Battery Replacement, Alternate iOpener heating method: 4 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement, Alternate iOpener heating method: 4 단계, 이미지 2개 중 2개
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
    What do I do if I don’t have a iopener?
    alexdelarge103@gmail.com - 답글
    2 or 3 cups Rice in a sock, heat for about 2 minutes. But, I recommend the iopener.
    Robert Garcia - 답글
    When boiling in water you can put the iopener in a ziplock to keep it dry.
    Robert Garcia - 답글
    Even if you don't put in a ziplock bag, I found that the surface is mostly hydrophobic so drying it is very easy. I also didn't have tongs, but the bag is denser than water, so it sank and I attached clothes pins to the ends and was able to remove it with those.
    Jack Adrian Zappa - 답글
    2-3 minutes in near boiling water, then 2-3 minutes on my s10+ and it was super easy to cut the glue off.
    Kipras Bielinskas - 답글
    I have a question, if I have a pan, and I have water, and a mean to boil the water, won't it be easier and cheaper to just use that.
    Ollie Tan - 답글
    Have you tried it? Water limits your temperature to 100℃, whereas 'pan on the stove' can easily get up to twice that. If your pan is even slightly warped, you'll have a few hot spots of direct conduction with convection everywhere else, heating things unevenly. Assuming you get the device up to temperature, how will you get it out without scratching it or burning yourself? After you're finished, do you really want to prepare food in the pan you warmed up adhesives and trace manufacturing substances in?
    Boiling something form fitting to heat your device with is a lot more foolproof, and not being foolish is easier and cheaper. Direct pan heating can work, but you are leaving yourself open to a lot more problems than just taking the safe route.
    James Beegle -
    add a little basil and oregano on the pan peanuts cashews walnuts and bam it pops right off
    david pride - 답글
    It's more 3 minutes than 2 minutes in hot water, in 2 minutes it's not getting hot enough I think. I used the combo iOpener + hair dryer for about 2 minutes and I could then insert a first opening pick easily. The first opening pick is the trickiest step, then if you go slowly and with patience around the screen with other opening picks, it works well.
    vincent becker - 답글
  5. iPad 2 Wi-Fi EMC 2560 Battery Replacement, Front Panel: 5 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement, Front Panel: 5 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement, Front Panel: 5 단계, 이미지 3개 중 3개
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    Yes...wear safety glasses for sure when doing this!
    Josh West - 답글
    If you have ANY cracks FOR SURE do the tape. I would also make sure to wear safety glasses as it can fly all over even with the tape. And do it somewhere that you don't mind tiny glass shards going everywhere. I had one 3 inch crack in the glass in the lower right corner and it started spidering. The plastic pics don't work once well once they hit a broken point in the glass so you better have a lot of heat to loosen the adhesive, or you end up using an exacto knife to get around the cracked spots.
    jesseokerlund - 답글
    On a few occasions I had an unexpected pop as the glass shattered and little shards struck me in the face. I had taped the surface but pieces at the edge still managed to break free. My advice: definitely wear the safety glasses, and definitely tape the entire glass surface.
    robertmhussey - 답글
    Echo jesseokerlund's comments that you will have glass flying. I made the mistake of doing the repair at my kitchen table and had a lot of cleanup to do. The job would be much easier if there was no broken glass, and the hardest part is where the glass is broken right next to the bezel. I used the metal spudger to work those pieces free, but it takes some time.
    robertmhussey - 답글
    + 1 on the safety glass, I almost got hurt while doing this.
    alexisfogel - 답글
    I followed all the safety precautions mentioned: tape, safety glasses… The best advice I saw on this is to put the iPad in the sun for a few minutes. I placed mine on the windshield of my car in direct sunlight for about 5 minutes. I also used the iOpener to keep heat on the edges I wasn’t working on. I was able to easily remove the glass without any shards flying in about 30-40 minutes total. Great advice and safest way I’ve seen to remove broken glass.
    Robert Jenkins - 답글
  6. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Safety Glasses
    $3.19
    • Again, as you may find yourself working with broken glass during this procedure, we strongly recommend wearing safety glasses for protection from flying shards.
    • Lay the iOpener flat on the right edge of the iPad, smoothing it out so that there is good contact between the surface of the iPad and the iOpener.
    • Let the bag sit on the iPad for approximately 90 seconds before attempting to open the front panel.
    It is ver likely that the glass you are trying to replace is broken, and this is tempered glass therefore it will chatter in many small pieces while you are working on it. Take this safety advice very seriously and protect your eyes!!! The glass pieces fly everywhere. AGAIN: PROTECT YOUR EYES!!!! BE SAFE!!!
    McGiord - 답글
    This last statement cannot be underemphasized! I got two shards of very fine glass into my right eye, luckily got them out right away, before reaching for the safety goggles! Later on, I removed them again because working w/ the small parts was easier. Protect your eyes, people!
    Lou Bomski -
    Just use some scotch wide transparent tape and cover the broken screen BEFORE you start to taking it apart. It will hold all the shards together and nothing will fly around.
    Vatevaaa -
    I covered the screen in clear packing tape to control glass particles.
    I placed the ipad outside in direct afternoon sunlight for an hour and all of the adhesive was softened quite well.....the screen was off in just a few minutes !
    John - 답글
    This is a very good idea John, I wish I'd seen this comment before I spent hours picking tiny bits of glass off the glue!
    Tom Scott -
    Thumbs up for this tip. I left it out in the sun for 15 min only and it worked a treat. I used a razor blade. The plastic tools are next to useless.
    olafgoy -
    I had some issues after replacing this cable.
    Once I had it in and back together only the down volume was working, and shortly after the gyro gave out.
    I ended up going to where the new cable connects to the board, removing it, then replacing it as gently as possible. Not too firm.
    I also removed a foam spacer in that area because it was pushed out over the gyro board.
    Now I'm back to full functionality!
    clatekeen - 답글
    me 2 my volumen up doesn't work and the switch sound/silent any fix?
    Zadd -
    Badly broken screen, taped and warmed about 15 minutes on heating pad set on high. Perfect, gentle, overall warming! Mark the front with Sharpie, ie WiFi, cable, etc. Used thin metal iSes... type tool and guitar pics. BUY NEW Plastic bezel!!! So super cheap. Rewarm on heating pad as necessary. Compressed air helpful to blow away tiny glass bits. Wear glasses! Take breaks! This is easy if you warm carefully and are patient!
    Max - 답글
    I am in the process of replacing a shattered screen on an iPad 3 wifi, and I literally was removing glass piece by piece! I do recommend having a roll of wide clear sealing tape at hand. Then, when you see loose glass shards, pull off about 4 to 5 inches, and stick the tape to pick up the loose glass, and once in a while, fold the tape onto itself (sticky to sticky side), and set it aside. This helps keep it from getting everywhere. Also, spread news paper under your work. Some people don't really think of these things, but the fact is, hardened glass will find its way into your skin very easily. Extremely sharp!
    dbrown900 - 답글
    Have not attempted this repair on my wife's iPad 2, but is there a reason that you put the iOpener on top of the device rather than putting the device on top of the iOpener? After all, heat rises.
    Stephen Weber - 답글
    Can someone please explain which is the right side of the ipad?
    padeacon - 답글
    loll... that's a good one.
    Alex -
  7. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 7 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 7 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 7 단계, 이미지 3개 중 3개
    • There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
    • Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
    • It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
    there is the power flex cable near the top right side of the screen. It could be damaged is not careful.
    cli168 - 답글
    Yes, I severed this one on my first attempt. Might note that you want to start prying open below the sound controls. Additionally I found that a razor was helpful in getting the first pic into the device. Obviously you want to be careful as a razor could cause some serious damage, but I just used the tip of the metal to get some space to fit a pick.
    Nick Dresang - 답글
    Maybe I was doing it wrong, but the plastic opening tool I was using kept bending before it was prying anything apart. Therefore I suggest using either a metal spudger or a razor blade to make the very first opening but being VERY careful. My assistant/wife later scratched the LCD going overboard with the metal tools.
    Logan Kennedy - 답글
    There is a way of making the Wifi/Bluetooth Antenna replacement much easier. If you have a steady hand and a soldering iron simply desolder the connecting cable from the bottom of the antenna and solder it back onto the new antenna. This means there is no need to dismantle the iPad and the repair is much faster. Hope this helps :-)
    Richard - 답글
    The process was pretty straightforward, you do need to be careful in a few spots (like the wifi antenna in the lower right) but overall I found it to be of medium level of difficulty.
    It took me 2.5hrs to slowly dismantle and replace the broken screen.
    Here are some tips I learned while doing it:
    - instead of plastic spudger, better to use kit knife or razor blade. I found plastic to bend and malform quite easily.
    - watch out for lower right corner where wifi antenna sits, it's easy to damage it
    - if you have a cracked screen, use protective goggles - i used tape to secure broken glass pieces together, but that didn't quite work and lots of glass was flying as I was prying the screen off the ipad
    - opening tool you put in the microwave sold here is not worth it - didn't do that great for me. I mostly used a hair drier and was very successful melting adhesive
    - tools I'd only need again to do it again - guitar picks, kit knife, phillips screwdriver, hair drier :D
    Overall, I found it to be quite interesting project!
    michalmotykiewicz - 답글
    Seconding the problem about plastic components. They just aren't strong / precise enough to fight this glass. Save them for the really nasty bits like the wifi cable, and use an X-Acto or equivalent everywhere else.
    Golden Neckbeard -
    Wish I would have seen your comment before I went through it. Switched to a razor blade and that helped for sure. Thought about a hair dryer as well but stuck with the micro heating tool. Probably should have done the dryer. :-/
    Josh West -
    Had much more success using the metal spudger versus the plastic opening tool that came with the front panel kit.
    Paul Boyer - 답글
    I had success using Paddle Pop sticks instead of guitar picks. (not sure what they are called in the US). The guitar picks tended to deform and melt with the heat of my hot gun. The glue used to attach the screen is just amazingly strong! It takes a lot of patience to remove all the fragments. I have done about 6 screens now and it is a turdful job!
    Jack - 답글
    I think we call those popsicle sticks. They seem kind of thick for this, at least a lot thicker than a guitar pick.
    John -
    It is not glue, they use a very strong double sided 3M tape
    Odus182 -
    Pay attention to the Power Button cable located in the upper right corner !!!
    Nathan - 답글
    Successful battery change but I did sever the cord/ribbon to the power/sleep button. As my iPad had been opened before at a repair shop, I think they put adhesive over the cord as the small section was stuck underneath the LCD, barely visible. So be careful not to put adhesive above that exposed ribbon/cord to the power/sleep button or the next time you open it up, it's severed.
    Breadman - 답글
    On the iPad 2 I repaired, the opening started at 1 inch and ended at 3mm.
    Justin H - 답글
    Like others i found the plastic tool pretty useless. Exacto, razor blade, or small metal pick/pry tool works much better to get that first guitar pick inserted. Be careful not to damage the bezel too much. Unless to plan to replace it.
    B Kirkham - 답글
    If you have an iPAD that has been repaired before note that the adhesive strip might not have an opening by the volume control as shown. I replaced the glass and the new glass had a 2" gap to the left of the Home button only.
    winwoodc - 답글
    The glass is much thinner than you'd think and I broke mine trying to lever it off before the adhesive has softened enough. Be VERY gentle!
    winwoodc - 답글
    My plastic opening tool broke in no time flat. Perhaps I was pressing down too hard and not wiggling it enough. But for me I found that the metal spudger was the best tool for the job. I was able to wiggle it while slowly prying up the glass and once it was under the surface of the glass I was able to work it along the edge quite easily. I saw that some people used a razor blade but I would be afraid the blade would break. The metal spudger was just thin enough to do the job well.
    robertmhussey - 답글
    !!!!!!razor-blade & hair-dryer !!!!!!!
    sean blanche - 답글
    I have found that using these plastic picks, spudgers and edge tools are ineffective as tools for inserting or creating a gap and glue separation action.
    They are just too soft and too thick for this, causing cracks and not able to reach underneath without causing stresses.
    After heating the adhesive with a heat gun (and using cardboard to shield the lcd screen) I have been using a metal round headed scalpel to insert between the glass and bezel, and to very carefully use as an adhesive separation tool at a very oblique angle so as to miss any sensitive cables or components.
    Also, instead of this iTool heating pad and a microwave, they should create an electrically heated shaped pad, this would avoid the constant cooling and reheating and maintain the right temperature.
    G Trieste - 답글
    Addendum, I have a temperature controlled heat gun, and set it to 180F for this.
    G Trieste - 답글
    The iOpener works fine, I'm not sure what y'all are talking about. To be fair, you have to press the iOpener into the iPad in order for it to work, which isn't explained well in this tutorial. Wear heat-resistant gloves when you do this, the center portion of the iOpener gets VERY hot. I use a pair of gloves from ACE Hardware. While it takes a bit more effort with the picks, I was able to heat up one side of the iPad, then seperate the adhesive with the picks the rest of the way through.
    I do not recommend using the little blue tool they show above, the part you're supposed to wedge in is way too thick. I use the Jimmy and some opening picks.
    Third image is slightly misleading, you want to go about a centimeter below the volume button.
    Emrys Quick - 답글
    der iOpener war bei meiner Aktion auch nicht der Hit; ich habe ein STEINEL 2000W-Heissluftgebläse benutzt, mit dem das Absetzen und Wiedererwärmen nicht so umständlich und effektiver war. Den Einstieg an der hier beschriebenen Stelle schaffte ich nicht mit einem Plastik-Opener-Tool, sondern mit Jimmy, dem Geräteöffner aus Metall.
    mani - 답글
  8. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Make sure you place the tool in the proper spot—between the plastic display bezel and the front panel glass.
    This visual is helpful. It would be great also to have a diagram of the top of the ipad, marked with "top," "bottom," "left," "right," and then an arrow pointing to each of the problematic areas, such as wifi cable, digitizer cable, etc. It would be easier to see the whole schematic while working rather than scrolling through the instructions and trying to visualize each piece separately. Good to see where to be careful...
    Christa - 답글
    sean blanche - 답글
  9. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 9 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 9 단계, 이미지 2개 중 2개
    • Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool.
    My screen was too broken for this "heat, cut with picks, and leave in place" method to work anywhere but the top, where it was essentially undamaged.
    I wound up using a spudger through all the cracked sections to pry upwards just *inside* the perimeter of the adhesive, intentionally breaking the digitizer and the glass further, until I could remove the entire front panel except for the adhered portions - about half the perimeter in my case.
    I then used tools to pry up the glass from the *opposite* direction, that is the broken interior edge I had earlier created, thus not having to fight the bezel and also having a clear line of sight to any interior components I might be damaging.
    Of course, doing it this way made it much easier to drop tiny shards of glass all over the interior, but I found a little diligent cleaning much easier than trying to keep the glass intact while breaking the glue, as in this guide.
    Golden Neckbeard - 답글
    I found that using a scraper blade was the easiest way to get under the glass, both for broken and unbroken areas.
    Jeff Snider - 답글
  10. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 10 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches.
    It should be noted that the glass can be much more difficult to remove when it is cracked and shattered (as is usually the reason for replacement) . Depending on the location and severity of the cracks, the order and technique of removal requires modification.
    I have found that putting a layer of clear packing tape over the entire screen is helpful, wether it's cracked or not. It will prevent the spraying of glass shards, should the glass break while separating the adhesive; with a broken screen, it should eliminate the risk of cutting yourself during removal, as well as hold all the pieces together. Unfortunately, it also makes the iOpener slightly less effective, so peel it back when applying it. Suction cups can also be helpful during final removal of the glass.
    Having a hot air gun/pencil can be helpful in removing smaller pieces if broken glass that remain once the bulk of it is removed.
    Nick V - 답글
    Just trashed an I pad... Not an electronics person. Did an iphone 5 battery with no problems was following instructions and once I hit the next step I realized I had already screwed up the screen... Moving forward tring to unhook LCD pictures are not very clear on which direction to push or pull so broke that... Now writing a review on it... Take it to a pro if you aren't certain!
    rondiedonelson - 답글
    I found that the adhesive could be separated when the pick or spudger was in at a depth of between 1/4" (6.4 mm) and 3/8" (9.5 mm). You can always go back and work it in deeper if you are having trouble separating.
    robertmhussey - 답글
    Yoh but this is not so simple of your screen is shattered to the edges. Basically I had to lift, shatter more, and then pick off the splintered glass with tweezers bit by bit. Patience is a virtue here. I gave up on saving the adhesive and used it to help remove the splinters. I basically removed the edges of the iPad like that and then lift glass off. WEAR SAFETY GLASSES. I would be blind now if I didn’t. wifi antenna -Go slow make sure it’s hot +check what you are doing in the crack. Remove all splinters fromiPad when it’s open. Clean LCD with a microfibre cloth and inside of your new digitizer. When I first reassembled, the home button didn’t work. I reopened and made sure the two gold connectors align with the two spikes on the body. I placed the home button board face down onto the connector spikes with adhesive on the other side, then lowered the digitiser onto it so the board would stick to the digitiser. Notes: forget plastic spudger they’re only place holders, I used a blade knife and metal Spudgers
    Sarah Pegden - 답글
  11. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 11 단계, 이미지 1개 중 1개
    • While you work on releasing the adhesive on the right side of the iPad, reheat the iOpener, and replace it on the bottom edge of the iPad.
    I have found that its better to put more than one pick down the side of the screen to keep it open and prevent it from sticking back down.
    Roberto Enrieu - 답글
    I had a pick in and used the spudger to make some headway but after 10cm the screen cracked. Be very slow and reheat the glue often.
    Alex - 답글
  12. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 12 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 12 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 12 단계, 이미지 3개 중 3개
    • While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad.
    • Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go.
    • The adhesive is very strong, and some serious force may be required. Work carefully.
    • If you can see the tip of the opening pick underneath the front glass, pull the pick out just a little bit. While using the opening pick this deep won't damage anything, it may get adhesive residue all over the LCD.
  13. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 13 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 13 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 13 단계, 이미지 3개 중 3개
    • It may be necessary to move the heated iOpener back onto the right edge of the iPad as you release the adhesive. This depends on how long the iPad has been able to cool while you were working on it.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
    The volume power button cable is really close to the edge and is frequently loose and non adherent to the frame. If your pick is deep into the iPad, you are almost sure to cut the cable. Be very cautious around the top right corner of the iPad.
    silvain1038 - 답글
    I absolutely severed this cable when loosening the adhesive around the volume button area. There is really no way of knowing if this cable somewhat elevated from the frame and therefore susceptible to being cut, and it happens to be right where one starts to remove the face with the guitar picks. The cable is directly in from the down volume button, so be extra careful not to put the guitar pick in too far in this area. I recommend buying a power/volume button cable just in case. Replacing this cable is also not easy, but doable. Just try to avoid doing it.
    nickmalmquist - 답글
    Why not work in reverse to the top edge, and back around to the area where that cable may be unsecured? Haven't don't an iPad (yet, staring one in the face right now) but that would be my alternative so the screen is mostly loose and you could possibly see the cable looking from the now open left side of the glass?
    Matt Needham - 답글
  14. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 14 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 14 단계, 이미지 2개 중 2개
    • Before removing the first opening pick from the bottom corner of the iPad, insert a second pick under the right edge of the front glass to keep the adhesive from re-adhering.
    • Re-heat the iOpener, and move it to the top edge of the iPad.
  15. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 15 단계, 이미지 1개 중 1개
    • The next few steps require extreme caution.
    • The Wi-Fi antenna is attached to the bottom right edge of the rear case of the iPad via screws and a cable. Because of the orientation of the Wi-Fi antenna, it is imperative to proceed with caution otherwise irreversible damage to the Wi-Fi antenna may result.
    • You will have to release the adhesive securing the antenna to the front panel without damaging the delicate parts attaching the antenna to the bottom of the iPad. Follow the next steps carefully.
    I cut through my wifi cable partially, but it still works (surprisingly). I'd recommend staying well clear of this with the pick. When you go to lift the screen (future step, NOT NOW), use a really good light, start to lift the glass slightly at the corner and you will be able to see the cable. Then you can heat it more and watch the cable as you pull through the adhesive there making sure your not catching the cable.
    B Kirkham - 답글
    If you heat the sides and top, releasing the adhesive, you can peel the broken glass front panel up from the body and with a little force the bottom comes loose. This avoids working around and damaging the Wi-Fi Antennae.
    Michael Vovaris - 답글
    I know it is hard to tell from the photo, but the Wi-Fi antenna is kind of like a flap that opens on the right and is attached on the left. So if you use a pick to slide from right to left, the pick might slide under the flap and then sever how it is attached. When I had my pick just to the right of where the Wi-Fi antenna is, I was able to twist my pick a little (like you are tightening a screw) and pry the screen up where the antenna is located. Then I just moved my pick to the left of the antenna and could continue loosening the screen.
    Laurie Higgins - 답글
    Irreversible damage to the Wi-Fi antenna is nearly unavoidable, but this is not the end of the world since you can pick up a perfectly fine replacement on-line for a few bucks. Many digitizer screen replacement kits include a new WiFi antenna and new bezel since removing the screen without damage to these is also nearly impossible. If your iPad is old enough to need a new battery, and you plan on keeping it thru at least another battery's expected life span, then I would plan on replacing the digitizer screen, bezel, and WiFi antenna as part of the battery replacement. The battery is going to be the most expensive of the set, say around $15 (US), and adding the other three will only add about another $15 (check the prices in ebay, amazon, etc.). Removing the screen often results in damage to the on/off and volume control cable since it too runs along the upper right hand edge of the base right under the screen. If you cut thru this then add another $1 to replace it too.
    Jerry - 답글
    Based on my experience just (nearly) completing this job on an iPad 2, CDMA, is that the trickiest step is reconnecting the three CDMA antenna cables on the underside of the CDMA chip that is part of the logic board assembly. These are nearly microscopic button connectors (maybe 0.5 mm in diameter). I needed 8X magnification glasses, very bright light, tweezers, and incredible luck to get these reattached. They pop off no problem, but getting them positioned to apply pop-on force takes a LOT of patients! Maybe someone knows a trick to doing this? There’s a similar connector on the WiFi cable but the chip it attaches to can be removed from the logic board so you’re able to manage positioning them interdependently. The CDMA chip is attached (soldered?) to the logic board and the three button connectors are on the underside, and pretty close to one another, so getting all THREE attached and then the logic board in place is a miracle.
    Jerry - 답글
  16. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 16 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 16 단계, 이미지 2개 중 2개
    • Slide the opening pick around the bottom right corner of the iPad, releasing the adhesive there.
    • Do not slide the pick further than the bottom right corner. You may damage the Wi-Fi antenna by doing so.
    Be sure to have a replacement Bluetooth Wi-Fi antenna because it is very likely to get the cable broken at this step.
    McGiord - 답글
    Be extremely careful and patient at this step. Proceed slowly with only the tip ( 1/16th in. - 2mm max.) of the pick. There are two tinny screws that attach the bottom of the antenna to the iPad frame. This antenna part is easly severed if the pick goes too far.
    Happenned to me and had to replace the antenna.
    Marc Bouchard - 답글
  17. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 17 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 17 단계, 이미지 2개 중 2개
    • This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
    • Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
    • Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
    I nearly broke my wifi antenna because I didn't read this whole step clearly and didn't go backwards and release the antenna from the front panel. Admittedly, this is my own fault but I've edited the step to make this point more clear.
    Logan Kennedy - 답글
    My screen was way too shattered for me to be able to use the screen instructions as suggested, so I followed the general principal but ignored the order around, because that simply wouldn't have worked...and destroyed the antenna.
    Maybe step one should be "BE CAREFUL IN THIS CORNER OR YOU WILL BREAK THE ANTENNA!" A diagram highlighting where all the cables (antenna, digitiser, volume, toggle switch) lie with the screen still attached would be helpful too.
    HRB - 답글
    Or maybe you should have read the entire thing before starting if you were not planing on following it step by step
    Hawesg Garrett -
    I Broke my antenna like many others. It is glued to the glass and has 1mm thick foam backing that is also glued to the inner case. Then there is a tiny grounding connector screwed at the lower edge of the case. Once you can get things loosened up around this antenna, you will need to detach this antenna from the glass. Work at it with your picks or spudger until you get it free, if you do not get it to release from the glass you will break the grounding ribbon. I bought a cheap aftermarket antenna on amazon for $3. turns out it has a bad cable coming from it. I was able to unsolder the cable from the one I broke and solder it to the new antenna.
    chrisnewitt - 답글
    This BEGS for an Archer "Just The Tip" reference.
    Christian - 답글
    It wasn't obvious to me at first that I'd broken the antenna. A picture of the antenna that works compared with one that is broken would be useful. Fortunately I'd ordered the replacement part just in case, as suggested.
    I think using extra heat on this spot may make it easier to unstick without breaking the antenna?
    A diagram of what the antenna looks like, from the side, would make it clearer what to do with the pick. You are trying to detach the antenna from the glass, without ripping it off where it's screwed into the bottom of the ipad. Since you can't see what you are doing, and the antenna is quite fragile, that's tricky.
    I think once you've broken one you would know better how to do it. When you slide the pick to the right you need to be sure the pick is moving above the antenna and not snagging on it in any way, and you need to be sure the antenna is completely detached from the glass, so you don't tear it when you lift the glass up.
    Chris Jordan - 답글
    Can anybody give me a clue as to what the exact part is in step 57, As there are slightly different cables for the ipad 2, Mine is A1395, Thanks.
    Jasper - 답글
    Another lesson learned while removing the WiFi antenna. The photo shows the iPad laying face up on the table, but to see what you’re doing when detaching the antenna you ‘re better off with the iPad edge up so you can see how the antenna is attached. The antenna is very, very easily broken. To be honest, it’s a lot easier to replace a broken antenna than to try to pry it loose.
    nigel - 답글
    Please mind that the GSM model has on the upper side left and right from the front camera the 3G antennas. When I removed the broken glass I cut the right one off which I have to fix now.
    st mo - 답글
  18. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 18 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 18 단계, 이미지 2개 중 2개
    • Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
    • Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
    • The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
    Be extremely cautious on this step! I did it wrong and my antenna went to !@#$.
    Lars Lien Ankile - 답글
    Also once it is unattached from the front panel, if the antennas adhesive touches the glass again it can re-adhere to front panel and may rip apart after all. Keep a close eye on it or leave a pick or card in there to prevent it from re-sticking.
    Danny Hartley - 답글
    Ordering a replacement antenna to anticipate the one you will brake(I should say shred) is probably your smartest move to have a successful repair
    Sebastien CHAPUIS - 답글
  19. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 19 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 19 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 19 단계, 이미지 3개 중 3개
    • Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button.
    • If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working.
    • Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
  20. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 20 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 20 단계, 이미지 2개 중 2개
    • Continue releasing the adhesive all the way along the bottom edge of the iPad.
    • On iPad 4 models, insert the pick to a maximum depth of 1/2 inch (10 mm) in this area, to avoid damaging the home button ribbon cable.
    • Leave the opening pick wedged underneath the front glass near the home button.
    This should include details about the Home Button Ribbon Cable. Unlike an iPad 3 (which doesn't have this cable) the iPad 4 has a Home Button Ribbon Cable that runs along the left side of the Home Button and is adhered to the glass. If the guitar pick is inserted too far (more than 0.5") it is possible to damage or sever this cable.
    robjpete - 답글
    There is a reason this is an iPad 2 Wi-Fi EMC-2560 repair guide. This guide isn't for iPad 3 or 4...
    Christian -
    I think the guides carry common steps between them. I'm reading this string of comments on multiple ipad 3/4 repair guides.
    Anticept - 답글
    Can I suggest putting the warning in red at the top of the instruction rather than half-way through it? I work from these guides by scrolling through them as I go, and I'd already put the spudger through the ribbon cable before I read the warning!
    spl23 - 답글
  21. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 21 단계, 이미지 1개 중 1개
    • Reheat the iOpener in the microwave and set it on the left edge of the iPad to start warming the adhesive in that section.
    I believe this should say to place the iOpener on the top edge, since the instructions go there next.
    lizgoldnm - 답글
  22. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 22 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 22 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 22 단계, 이미지 3개 중 3개
    • Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket.
    • The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad.
    • If the adhesive has cooled too much, replace the iOpener along the top edge and continue working. If the iOpener has cooled too much, reheat it.
    • If the opening pick is getting stuck in the adhesive, "roll" the pick as shown in step 9.
    In my case I damaged the right GSM antenna which was somehow sticked to the front panel... Be really careful as I really didn't felt that I was damaging anything...
    MattLise Gaillzik - 답글
    +1 on the right 3g antenna - it is adhered to the glass and I cut right through it with the opening pick. The replacement included adhesive to re-stick it to the glass, so this is a definite feature of this antenna. This is a thin film similar to the wifi antenna, so maybe going around it at a shallow depth from the corner to the camera and then returning to the corner slightly deeper would allow you to separate the antenna from the glass without damaging it.
    doog - 답글
    Be very careful when going around the front camera, I cracked my screen by prying up too much and causing too much stress!
    Rowdydtk - 답글
    The GSM component is glued to the screen with different adhesive (more like glue). I managed to not damage this but it was really tricky. The guitar pick is too thick and weak to release this from the screen. Id recommend you wait until you lift the glass (future step, NOT NOW). Then, with a good light you'll see the white plastic adhered to the glass. A thin metal pick or exacto is needed to patiently cut & pry your way through the adhesive. Careful of the camera as your pulling in that direction.
    B Kirkham - 답글
  23. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 23 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 23 단계, 이미지 2개 중 2개
    • Continue releasing the adhesive along the top edge of the iPad, and slide the opening pick around the top left corner.
    • If the adhesive is warm enough, remove the iOpener from the iPad for convenience. However, if the adhesive is still quite sticky, re-heat the iOpener and lay it on the left edge while you work.
  24. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 24 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 24 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 24 단계, 이미지 3개 중 3개
    • Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer.
    • The digitizer cable is located approximately 2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
    The second photo does not show the iPad 4's Home Button Ribbon Cable.
    robjpete - 답글
    Because this is for an iPad 2
    Odus182 -
    @odus182 It says clear as day that this is an iPad 4 guide!
    Mike Enos -
    This is the hardest part the digitizer cable runs the length of this side and u have to be very carefull with the pick . Only go in an 1/8 inch I severed it by going the half (recommended) luckily I had a new screen standing by . I used I opener for heating and it was slow but ok.
    wperrin623 - 답글
    How do i fix my digitiser if it's broken? Do i need to buy a new iPad screen with digitiser?
    Jenny Le - 답글
    just ruined my digitiser..any ideas how to fix it?
    dleimonis -
    There is an error in the red text in this step. It says ‘The digitizer cable is located approximately 2" from the bottom of the iPad’. The next sentence says .. ‘Stop sliding the pick when you get ~2.25" from the bottom of the iPad.. This will slice and ruin that cable. The last sentence should read ‘Stop sliding the pick when you get ~1.75" from the bottom of the iPad.’ so you stop cutting glue before you get to the digitizer cable.
    @Jenny & @dleimonis - you can buy the digitizer and new cable by itself if you do not need an LCD also. They are separate parts.
    Jon Lucenius - 답글
  25. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 25 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 25 단계, 이미지 2개 중 2개
    • Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner.
    • The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
    If your screen is broken or shattered there are no worries with the digitizer cable, It is all on the new screen.
    Danny Hartley - 답글
    Exactly. I purposely severed mine as it was a complete screen replacement and made the LCD removal easier.
    jesseokerlund - 답글
  26. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 26 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 26 단계, 이미지 2개 중 2개
    • Using one of the opening picks, pry up the bottom right corner of the iPad and grab it with your fingers.
    • Some of the adhesive along the perimeter of the iPad may have stuck back down again. If this is the case, slide a pick underneath the edge of the iPad where the front glass is still stuck and "cut" the adhesive.
    Should be right-hand corner
    longg - 답글
    Be very careful when pushing the guitar pick around the corner of the power/volume buttons. The ribbon cable for these buttons may be stuck to the adhesive and break when lifting the screen or when sliding the pick along this area. I have done 4 iPad 2 repairs and at least one of the delicate components do not make it. I would recommend ordering a wi-fi/bluetooth antenna, bezel with strips, and a power/volume cable. It is nice to have a "just-in-case" part or two, they are very inexpensive. I noticed that the I tended to break one of these delicate components when the screen was shattered in the area of those components.
    thetechandtutor - 답글
    nickmalmquist - 답글
    At this point it is a good idea to get the packing tape back out and wrap it around 2 or 3 of your fingers making a circle with the sticky on the outside. Make it loose enough you can place your fingers on the table surface to the side and pull your fingers out. When you remove all the tiny parts/screws in the next steps put them on top of the tape so you know exactly where they are when you need them
    windizy - 답글
  27. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 27 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 27 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
    • Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
    • During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
    Check to the right of the Home button to see if the wifi/bluetooth antenna is still stuck to the glass side or has released. If it is still stuck to the glass use the guitar pick to carefully scrape it off. If your goal is to replace the antenna, then you needn't be so careful.
    jerry81 - 답글
    Be very careful not to touch the LCD. It's a pain to remove smudges. One thing that might help when you need to hold it while reattaching it during reassembly: attach a small suction cup to the metal side. That way you can avoid touching the sides where your hand might slip to the LCD side.
    patjmccarthy - 답글
    Do you need to use some adhesive strips to remount the plastic bezel? The bezel I ordered didn't come with any and the ones you can order only seem to have strips for mounting the glass and not the bezel.
    James - 답글
    You'd better. The original bezel is glued. You can find 3mm fine/double-sided (black) tape on Amazon. I use it when I replace the bezel because they fit perfectly under the bezel. I use for all sorts of repairs on iPhones, Samsungs, etc. Such as this [one|http://www.amazon.com/gp/product/B005GIS...]
    Rany -
    In order to prevent touching the LCD screen with your finger(s), I use the thin plastic food wrapper to cover it. It will temporary stick to the LCD screen and provide excellent protection from fingerprints.
    Th Th - 답글
    Very good suggestion. It worked like a charm.
    Laurie Higgins -
    you can use latex gloves to keep smudges and finger prints from the screen. I'm getting ready to repair mine, thanks for all the comments and tips. Btw, I wonder if a vacuum cleaner would work for removing small pieces of glass.
    De Dios sept.10 2014
    dediosjon - 답글
    where is the connecotr for home button at the ipad 3....i have nothin where i can plug in the flex cable comin from the button
    Georg Heinze - 답글
    Go slowly as you lift up the glass and be sure that you are not tearing a ribbon cable. When I lifted the glass the digitizer cable was torn and unusable. Perhaps I had cut it with the pick/spudger but it tore completely off when I lifted the glass. Good thing I had purchased the full front panel assembly with the digitizer (IF116-018-3).
    robertmhussey - 답글
    When reassembling I used canned air to blow off dust on the LCD before closing it up.
    robertmhussey - 답글
    You can use a clean soft brush like a make-up brush or small paint brush to brush off the LCD.
    Laurie Higgins - 답글
    I like how the pictures show an intact screen being removed (although the one in step 4 has a couple of cracks in). I don’t know if anyone would have the luxury of being able to remove a screen in one piece, the ipads I've fixed have been completely smashed pretty much all the way around the outside of the lcd underneath. I used this guide to know where to watch for cables etc - very helpful. I end up using a window scraper/razor to scrape off the glass shards/adhesive around the edge. Glass shards/dust all over the lcd is easy enough to get off but cleaning the lcd after that is a real pain. Does anyone have any suggestions how to clean the lcd properly?
    jmzaj - 답글
    When reassembling the glass, align the camera first. On the back of the glass there are two pins on the metal camera frame.
    Align them to the camera first, in order to avoid to get a ‘bulge’ visible on the glass or on the back of the iPad.
    Luca Forti - 답글
    +1 to Luca’s comment. This deserves a RED NOTE for reassembly. I probably just destroyed my new wifi antenna due to not having a reassembly call out for alignment of the screen. Had to pry things back apart and wifi antenna looks like it may have bit the dust. So this is a VERY important bit to know for a first timer.
    Benjamin Pappas - 답글
    When reinstalling the front panel check the home button’s ribbon cable doesn’t get trapped. If it gets folded back on itself, the cable will break and you’ll have a reassembled iPad with a non-functioning home button.
    nigel - 답글
  28. iPad 2 Wi-Fi EMC 2560 Battery Replacement, LCD: 28 단계, 이미지 1개 중 1개
    • Remove the four 2.0 mm Phillips screws securing the LCD to the rear case.
    It would be good to see how reassembling.
    Gabriel Ganga - 답글
    Yes, or at least show where the adhesive parts go
    Luke Barone - 답글
    I'll second the request to see how to reassemble!
    Maggie - 답글
    use the same way in reverse mode!!
    XOEYZ I170I59E - 답글
  29. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 29 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 29 단계, 이미지 2개 중 2개
    • The front panel ribbon cables are connected beneath the LCD. To access them, you'll need to temporarily flip the LCD over and out of the way.
    • Be very careful when moving the LCD, and do not attempt to remove it from the iPad—its display data cable will remain connected while it is rotated over.
    • Lift the LCD from its long edge closest to the volume buttons and gently flip it out of the rear case—like turning the page in a book.
    • Set the LCD face down on the front panel.
  30. iPad 2 Wi-Fi EMC 2560 Battery Replacement, Front Panel Assembly: 30 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement, Front Panel Assembly: 30 단계, 이미지 2개 중 2개
    • Use the edge of a plastic opening tool to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • The retaining flaps are highlighted in red in the second picture.
    You should disconnect the battery before disconnecting any cables.
    Gregg Stanley - 답글
  31. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 31 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 31 단계, 이미지 2개 중 2개
    • Use the edge of a plastic opening tool to peel the digitizer cable off the shields on the logic board.
    • Carefully pull the digitizer cable off the adhesive securing it to the side of the rear case.
    It is a really good idea to apply a bit of heat to this ribbon cable prior to removal. Ribbon cables that are held in place with adhesive can tear easily. Taking a moment to warm it up will help make the removal much easier.
    Joshua - 답글
  32. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 32 단계, 이미지 1개 중 1개
    • Pull the digitizer ribbon cable straight out of its two sockets on the logic board.
    After I replaced the digitizer only half the screen is working. Any reason for this problem ?
    Pedro Trindade - 답글
    When reassembling, don’t remove the adhesive strip until you’re sure the new cable is inserted correctly and locked in place. Place the LCD panel inside the case, and the screen inside the bezel, turn on the iPad. If you can drag an icon across the screen, from top to bottom, left to right, your screen is correctly installed and you can proceed removing the adhesive.
    Candice McDowell - 답글
    After I replaced the digitizer the volume button the side of my ipad will go down but not back up and it’s not powering off. Any ideas why this is happening?
    Jonathan Davidson - 답글
  33. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 33 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 33 단계, 이미지 2개 중 2개
    • In order to remove the front panel assembly, the ribbon cable needs to slide out between the case and the LCD. You'll need to move the LCD to make some room.
    • Be very careful when moving the LCD, and do not attempt to remove it from the iPad—its cable will remain connected while it is rotated over.
    • Lift the LCD from its long edge farthest from the digitizer cable and gently flip it toward the rear case—like closing a book.
    • While holding the LCD up, gently slide the front panel away from the iPad. Be careful not to snag the digitizer cable on the rear case or LCD.
    • Set the LCD back into the body for safekeeping.
    (Step 14 should be deleted.)
    John Cain - 답글
    why it should be deleted?
    i think it's necessary to remove the digitizer cable before we lift up the logicboard
    Can Han -
    It should go without saying, but anytime you are handling the LCD, try to only touch the edges. Otherwise you'll be scrubbing fingerprints for 15 minutes. Not that I'm speaking from personal experience or anything.
    Ed Chapman - 답글
    random question...........1 problem i've ran into in the past is the digitizer cable is so long on aftermarket screens the adhesive isn't strong enough to hold the glass down around the digitizer area where it is folded.
    would it help to have a 2nd person tilt glass straight up off table and tuck some extra cable under the lcd or will this cause a problem with the lcd itself?
    Jason S - 답글
  34. iPad 2 Wi-Fi EMC 2560 Battery Replacement, LCD Assembly: 34 단계, 이미지 1개 중 1개
    • In order to work on the iPad's innards, we need to flip the LCD back out of the case.
    • Set the LCD face down on a clean surface. You may want to rest it on a soft cloth to prevent scratches.
  35. iPad 2 Wi-Fi EMC 2560 Battery Replacement, Logic Board: 35 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement, Logic Board: 35 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement, Logic Board: 35 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to lift the display data cable lock upwards.
    • Pull the display data cable out of its socket.
    • Be careful not pull the connector upward as you disconnect it from its socket.
  36. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 36 단계, 이미지 1개 중 1개
    • Remove the LCD assembly from the rear panel assembly.
  37. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 37 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 37 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 37 단계, 이미지 3개 중 3개
    • If present, remove the piece of tape on the dock connector cable with a plastic opening tool.
    • Use the edge of a plastic opening tool to carefully pry the dock connector cable's connector up from its socket on the logic board.
    • Peel the dock connector ribbon cable off the rear panel.
  38. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 38 단계, 이미지 1개 중 1개
    • Pry the speaker cable connector straight up from its socket on the logic board.
    • Be careful to pry only the connector, not the socket on the logic board, or you may destroy the socket.
  39. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 39 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 39 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 39 단계, 이미지 3개 중 3개
    • Remove the following screws:
    • Two 2.1 mm Phillips screws securing one of two metal brackets to the rear case.
    • One 2.6 mm Phillips screw securing the logic board to the rear case.
    • Remove the metal bracket from the rear case.
    i ordered the IPAD 2 BATTERY KIT (IF110-014-3 )  assuming ill have everything i need but went over this guide i am not sure if i have the screw driver bits 2.1mm and 2.6mm to use on this step. am i correct?
    GeloXtian Abapo - 답글
    This means the length oft the screws. The screwhead is Phillips.
    VauWeh - 답글
  40. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 40 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 40 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • If present, use tweezers to remove the piece of tape covering the end of the headphone jack/control board cable.
  41. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 41 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 41 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to flip up the retaining flap on the headphone jack/control board cable ZIF socket.
    • Be sure you are prying upward on the hinged retaining flap, not the socket itself.
  42. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 42 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 42 단계, 이미지 2개 중 2개
    • Slide the tip of a spudger underneath the headphone jack/control board ribbon cable to disconnect it.
  43. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 43 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 43 단계, 이미지 2개 중 2개
    • Remove the two 2.1 mm Phillips screws securing the second metal bracket to the rear case near the digitizer cable socket.
  44. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 44 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 44 단계, 이미지 2개 중 2개
    • Use the edge of a plastic opening tool to gently pry the logic board up from the adhesive securing it to the rear case.
  45. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 45 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 45 단계, 이미지 2개 중 2개
    • Lift the logic board out from the rear case and flip it over toward the battery.
    • Do not try to completely remove it just yet. There is still an antenna cable attached to it.
  46. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 46 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 46 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 46 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to pry the Wi-Fi antenna connector up from its socket on the logic board.
    • Remove the logic board from the case.
  47. iPad 2 Wi-Fi EMC 2560 Battery Replacement, Battery: 47 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement, Battery: 47 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement, Battery: 47 단계, 이미지 3개 중 3개
    • Reheat the iOpener in the microwave for one minute.
    • Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than one minute.
    • Place the heated iOpener on the back of the iPad just right of center (the side opposite the rear facing camera). Let it sit there for 90 seconds to soften the battery adhesive.
    • Move the iOpener to the center of the back of the iPad and let the iOpener sit for another 90 seconds.
    • If the iOpener cools significantly between sittings, reheat it for another minute.
    • Move the iOpener to the left edge (the side with the rear facing camera) of the back of the iPad and let the iOpener sit for another 90 seconds.
  48. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 48 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 48 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad, to separate the adhesive securing the battery in place. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
    • Flip the iPad back over and insert a plastic card between the bottom battery cell and the rear case.
    • If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften.
    It is much easier to use dental floss to cut the batteries lose. This way you don't risk to bend the batteries.
    Magnus Sundberg - 답글
  49. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 49 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 49 단계, 이미지 2개 중 2개
    • Starting with the battery cell closest to the dock connector, run a plastic opening tool underneath the edge of the battery closest to the logic board void to make enough room to insert a plastic card.
  50. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 50 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 50 단계, 이미지 2개 중 2개
    • Insert the card at the case side corner and slide inward to separate more adhesive.
  51. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 51 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 51 단계, 이미지 2개 중 2개
    • Work the card around the corner and insert along the case-side of the cell.
    • Insert the card at as shallow an angle as you can manage to avoid bending the battery.
  52. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 52 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 52 단계, 이미지 2개 중 2개
    • Insert the card at the bottom corner (closest to the headphone jack) to free this side of the battery cell.
  53. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 53 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 53 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 53 단계, 이미지 3개 중 3개
    • Slide the card along the side of the cell to detach any remaining adhesive.
  54. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 54 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 54 단계, 이미지 2개 중 2개
    • Gently pry the end of the battery cell away from the case.
  55. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 55 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 55 단계, 이미지 2개 중 2개
    • Gently pry the corner of the battery off of the case to begin freeing the final side of the dock side cell.
  56. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 56 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 56 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 56 단계, 이미지 3개 중 3개
    • Gently pry up the remaining corner of the cell. Avoid bending the cable connecting the battery cells.
    • Leave this card in place to prevent the adhesive from resetting while you loosen the other battery cells.
  57. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 57 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 57 단계, 이미지 2개 중 2개
    • On the battery cell nearest the headphone jack, run a second plastic card underneath the edge adjacent to the logic board void.
  58. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 58 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 58 단계, 이미지 2개 중 2개
    • Slide the card in to free the corner of the cell from adhesive.
  59. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 59 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 59 단계, 이미지 2개 중 2개
    • Pry gently to free the corner of the cell from the case.
  60. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 60 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 60 단계, 이미지 2개 중 2개
    • Slide the card under the opposite corner to detach yet more adhesive.
  61. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 61 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 61 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 61 단계, 이미지 3개 중 3개
    • Give a final swipe to get the last of that stubborn adhesive.
  62. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 62 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 62 단계, 이미지 2개 중 2개
    • A final pry, and the card can be left in place to keep the battery propped away from the adhesive.
  63. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 63 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 63 단계, 이미지 2개 중 2개
    • Time to tackle that center battery cell. By now, the adhesive may have cooled a bit; another application of the iOpener might be helpful at this point.
    • Slide the card under the center cell near the cable.
    • Insert the card near the far end of the battery.
  64. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 64 단계, 이미지 3개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 64 단계, 이미지 3개 중 2개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 64 단계, 이미지 3개 중 3개
    • Gently pry the bottom of the cell up from the case.
    • Pry the dock side corner of the cell up from the adhesive.
    • Pry again near the cable to loosen the cell further.
  65. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 65 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 65 단계, 이미지 2개 중 2개
    • Slide a corner of the card under the top of the cell (the side adjacent to the logic board void).
    • Use the screw post as a pivot point to detach the last of the adhesive under the battery conector board.
  66. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 66 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 66 단계, 이미지 2개 중 2개
    • Insert the cards at the junctures between batteries.
    • Pry upwards to free the battery connector board from the screw post and the battery assembly from the case.
    • Do not excessively bend the battery connector board. Be especially careful when prying up around the screw post on the aluminum rear case.
  67. iPad 2 Wi-Fi EMC 2560 Battery Replacement: 67 단계, 이미지 2개 중 1개 iPad 2 Wi-Fi EMC 2560 Battery Replacement: 67 단계, 이미지 2개 중 2개
    • Lift and gently remove the battery assembly from the case.
    • You may need to reach in between the battery and the rear case with a plastic card to cut any remaining adhesive.
    Part 1: The 66 steps were well done, but they describe only about the first 1/3 of the effort. The “conclusion” states: “To reassemble your device, follow these directions in reverse and use our iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive strips guide to reattach the front panel.”
    Useless #1 - “…use our iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive strips guide…” I tried (I have a 2560) but the guide was for an entirely different set of strips than the ones iFixit is selling in June 2019.
    Useless #2 - There was no reference to ANY guide on how to remove adhesive. I searched hard. There was some stuff from users on the forum, but NO GUIDE on this CRITICAL aspect of iPad repair. Figured out a process myself (FIRST peel off the tape from the glass, then wet remaining adhesiveIPA saturated Q-tips, use sharp edged opening tool to scrape up the thick stuff while it’s still wet, and then use IPA-wetted 1” square cotton flannel rifle bore patches for the final cleanup).
    (more to come)
    scottmillett - 답글
    Part 2: Useless #3 - “Follow directions in reverse.” Nope - the vast majority of the 66 steps involve how to cut through the adhesive strips. You can’t reverse that. The (fairly few) reversible steps involve removing screws/brackets and disconnecting cables. Even there, here are two critical oversights on reassembly:
    - (A) INSTALLING THE BATTERY: The new battery positioning is very sensitive. Use the plastic sheet you peeled off the glue strips under the battery, with maybe 1/2” of adhesive poking past it on the connector side. Set the battery connector on its post, then align the two similar opposite-side battery edges as close to perfectly parallel as possible to the housing before pushing down their connector-side edges, then align the third battery section to the first two and push down on the connector edge to lock in its orientation. Then slide the plastic out and smoothly push down on the rest of the adhesive strips, working form the connector edge to the housing edge.
    (more to come)
    scottmillett - 답글
    Part 3: - (B) FINAL ASSEMBLY OF LED PLATE AND GLASS/DIGITIZER — You have to be VERY careful in the installation sequence of the front glass/digitizer and LED plate. Before this step, (a) install the Bezel (I used the spudger’s point to push it down and sideways into the outer lip, then the flat of the spudger to adhere the flat 1/8”/3 mm base of the bezel), then (b) install the adhesive strips to the perfectly clean back side edges of the glass/digitizer, leaving only the blue peel-off protectors in place. Note: On the strip around the front-facing camera, the thin center part goes INSIDE the cameras, not along the outside edge! Painful lesson learned - do as I say, not as I did!)
    (more to come)
    scottmillett - 답글
    Part 4: - Then: Connect the LED plate first, lay it open like a book, then CAREFULLY slide the glass/digitizer under it from the bottom, so that its flex cable slides into position. In this and ALL following steps, take GREAT CARE to (a) not to touch the digitizer or LED surfaces with your fingers (or anything else contaminated) and (B) Not to let either surface’s edge stuff to scratch the other surface. I used an old, well (and freshly-) washed hand towel for protection. (Again, Painful lesson learned - do as I say, not as I did!)
    - Gently lower the LED plate into place and LOOSELY install the two far screws, away from the pivot edge, and prop the sharp opener tool under the lower corner of the “hinge) of the LED plate, to raise it about 3/8”/ 8 mm above the rear housing’s edge.
    scottmillett - 답글
    Part 5: - Lift up the glass/digitizer to vertical (for the ENTIRE rest of this step) and using the tip of the spudger, carefully work the loop of the digitizer’s flex cable UNDER THE LED PLATE so that only 1/8”/ 3 mm) is hanging out of the gap, then remove the opener tool, drop the LED plate down onto its four contact points, and finish installing and tighten all four screws.
    - Now, here’s the tricky part. You have to hold up the LED plate vertical with one hand, while you remove the blue peel-off protectors from the glass/digitizer with your other two hands. My failure while doing this was to unknowingly brush/touch my hand or arm across the digitizer surface, leaving a large smear that I didn’t see until the assembly was complete. Sigh.
    - Keeping the glass/digitizer vertical, use canned air to blow off any dust particles from the LED and digitizer surfaces.
    (more to come)
    scottmillett - 답글
    Part 6 (final): Exclusive of the adhesive removal, the whole disassembly/reassembly effort (first try on an iPad) took me about 3 hours. The adhesive removal took another 3 hours before hitting on the , but only about 1-1/2 hours after I developed the technique above.
    scottmillett - 답글
결론
다른 28명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
471,444 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,413개를 작성함
댓글 2개
Nicked (Cut) the Touchscreen cable, Wi-Fi Cable, (Power/ Lock/ Camera) Cable - taking the screen off. All I was trying to do is replace the battery. It was so cheep, I should have purchased items 2 & 3, new screen seam, as spares when attempting the repair to avoid multiple shipping delays. As far as my unbroken screen which I destroyed, I used a razor blade but went in more than 4mm, watch out for that. A difficult time consuming repair. Saying that, without ifixit.com, I would have been paddling up a creek, so special thanks to them for making the repair even possible.
jamieyazoo - 답글
I replaced the battery but now it won’t hold a charge. While plugged in it just blinks the apple logo, and then when I unplug it, it turn off. I have tried to charge it over night as well.
Rena - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 45
전체 시간: 25,728
