주요 콘텐츠로 건너뛰기
iPhone 14 Rear Glass Replacement
Tobias Isakeit
Tobias Isakeit11 다른 기여자
최종 수정일 February 25, 2025
30 - 45 분
조정
추천 가이드
Use this guide to replace a broken rear glass on your iPhone 14. The rear glass includes the charging coil and rear-facing microphone mounted on it.
This guide was created using the A2882 (international) model. If you're fixing a different iPhone 14 model, there may be some visual discrepancies, but the procedure should be the same.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Note: On iOS 18 and newer, you can pair new, genuine rear glass parts using Apple's Repair Assistant.
You’ll need replacement adhesive to reattach the screen when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
필요한 것
부품
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. iPhone 14 Rear Glass Replacement, Remove the pentalobe screws: 1 단계, 이미지 2개 중 1개 iPhone 14 Rear Glass Replacement, Remove the pentalobe screws: 1 단계, 이미지 2개 중 2개
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
  2. iPhone 14 Rear Glass Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 1개 iPhone 14 Rear Glass Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 2개 iPhone 14 Rear Glass Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 14 Rear Glass Replacement, Tape over any cracks: 3 단계, 이미지 2개 중 1개 iPhone 14 Rear Glass Replacement, Tape over any cracks: 3 단계, 이미지 2개 중 2개
    • If your iPhone has a cracked rear glass, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
    • If all else fails, you can superglue the suction cup to the rear glass.
  4. iPhone 14 Rear Glass Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 1개 iPhone 14 Rear Glass Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 2개 iPhone 14 Rear Glass Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Follow this guide to secure your screen with the included tape.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 14 Rear Glass Replacement: 5 단계, 이미지 3개 중 1개 iPhone 14 Rear Glass Replacement: 5 단계, 이미지 3개 중 2개 iPhone 14 Rear Glass Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 14 Rear Glass Replacement: 6 단계, 이미지 2개 중 1개 iPhone 14 Rear Glass Replacement: 6 단계, 이미지 2개 중 2개
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The glass should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the rear glass when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  7. iPhone 14 Rear Glass Replacement, Heat the bottom edge: 7 단계, 이미지 1개 중 1개
    • If you're using a suction handle, follow the next two steps to loosen the rear glass.
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 14 Rear Glass Replacement, Insert an opening pick: 8 단계, 이미지 3개 중 1개 iPhone 14 Rear Glass Replacement, Insert an opening pick: 8 단계, 이미지 3개 중 2개 iPhone 14 Rear Glass Replacement, Insert an opening pick: 8 단계, 이미지 3개 중 3개
    • Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
    • Insert an opening pick into the gap.
    • The adhesive holding the rear glass in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the rear glass up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
  9. iPhone 14 Rear Glass Replacement, Heat the left edge: 9 단계, 이미지 1개 중 1개
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
  10. iPhone 14 Rear Glass Replacement, Slice the left edge adhesive: 10 단계, 이미지 3개 중 1개 iPhone 14 Rear Glass Replacement, Slice the left edge adhesive: 10 단계, 이미지 3개 중 2개 iPhone 14 Rear Glass Replacement, Slice the left edge adhesive: 10 단계, 이미지 3개 중 3개
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  11. iPhone 14 Rear Glass Replacement, Rear glass information: 11 단계, 이미지 1개 중 1개
    • There's a delicate cable along the right edge, next to the volume up button. Don't insert your pick here, as you may damage the cable.
  12. iPhone 14 Rear Glass Replacement, Heat the right edge: 12 단계, 이미지 1개 중 1개
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the rear glass is slightly too hot to touch.
  13. iPhone 14 Rear Glass Replacement, Slice the right edge adhesive: 13 단계, 이미지 3개 중 1개 iPhone 14 Rear Glass Replacement, Slice the right edge adhesive: 13 단계, 이미지 3개 중 2개 iPhone 14 Rear Glass Replacement, Slice the right edge adhesive: 13 단계, 이미지 3개 중 3개
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the charging coil cable.
  14. iPhone 14 Rear Glass Replacement, Heat the top edge: 14 단계, 이미지 1개 중 1개
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
  15. iPhone 14 Rear Glass Replacement, Slice the top edge adhesive: 15 단계, 이미지 3개 중 1개 iPhone 14 Rear Glass Replacement, Slice the top edge adhesive: 15 단계, 이미지 3개 중 2개 iPhone 14 Rear Glass Replacement, Slice the top edge adhesive: 15 단계, 이미지 3개 중 3개
    • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
  16. iPhone 14 Rear Glass Replacement: 16 단계, 이미지 3개 중 1개 iPhone 14 Rear Glass Replacement: 16 단계, 이미지 3개 중 2개 iPhone 14 Rear Glass Replacement: 16 단계, 이미지 3개 중 3개
    • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
    • Don't insert the pick more than 3 mm, as you may damage or smear the camera array.
    • Don't try to fully separate the rear glass yet, as a fragile ribbon cable still connects it to the iPhone's logic board.
  17. iPhone 14 Rear Glass Replacement, Open the iPhone: 17 단계, 이미지 3개 중 1개 iPhone 14 Rear Glass Replacement, Open the iPhone: 17 단계, 이미지 3개 중 2개 iPhone 14 Rear Glass Replacement, Open the iPhone: 17 단계, 이미지 3개 중 3개
    • Remove your suction handle from the rear glass.
    • Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
    • Be careful not to strain the short charging coil flex cable.
    • Lean the rear glass against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
    • During reassembly, lay the rear glass in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the rear glass and make sure they aren't bent.
  18. iPhone 14 Rear Glass Replacement, Unfasten the battery connector cover screws: 18 단계, 이미지 2개 중 1개 iPhone 14 Rear Glass Replacement, Unfasten the battery connector cover screws: 18 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  19. iPhone 14 Rear Glass Replacement, Remove the battery connector cover: 19 단계, 이미지 3개 중 1개 iPhone 14 Rear Glass Replacement, Remove the battery connector cover: 19 단계, 이미지 3개 중 2개 iPhone 14 Rear Glass Replacement, Remove the battery connector cover: 19 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Grasp the battery connector cover with a pair of tweezers and slide it upwards (towards the A15 print) to unlatch the top hook.
    • Remove the battery connector cover.
  20. iPhone 14 Rear Glass Replacement, Disconnect the battery: 20 단계, 이미지 2개 중 1개 iPhone 14 Rear Glass Replacement, Disconnect the battery: 20 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  21. iPhone 14 Rear Glass Replacement, Unfasten the charging coil connector cover screw: 21 단계, 이미지 2개 중 1개 iPhone 14 Rear Glass Replacement, Unfasten the charging coil connector cover screw: 21 단계, 이미지 2개 중 2개
    • Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
  22. iPhone 14 Rear Glass Replacement, Remove the charging coil connector bracket: 22 단계, 이미지 2개 중 1개 iPhone 14 Rear Glass Replacement, Remove the charging coil connector bracket: 22 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to remove the charging coil connector cover.
  23. iPhone 14 Rear Glass Replacement, Disconnect the charging coil: 23 단계, 이미지 2개 중 1개 iPhone 14 Rear Glass Replacement, Disconnect the charging coil: 23 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
  24. iPhone 14 Rear Glass Replacement, Remove the rear glass assembly: 24 단계, 이미지 2개 중 1개 iPhone 14 Rear Glass Replacement, Remove the rear glass assembly: 24 단계, 이미지 2개 중 2개
    • Remove the rear glass assembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the rear glass adhesives.
결론
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for troubleshooting help.
다른 22명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
123,787 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,131개를 작성함
댓글 16개
Does Ifixit currently offer this part?
Mark Schulze - 답글
Dear Mark Schulze, unfortunately not.
Manuel Haeussermann -
After completing this repair, my camera doesn't save flash photos anymore, even though the flash fires and it saves normal photos. Flash photos still save with the original back glass. Anyone else run into this issue?
Rich - 답글
Hi Rich, the issue could be caused by a damaged IC (see marked in this image)
Tobias Isakeit -
You need to transfer the charging coil and any parts adhered to the back glass as they are paired.
Sean - Lua Tech -
댓글 쓰기
조회 통계:
지난 24시간: 164
지난 7일: 1,121
지난 30일: 4,635
전체 시간: 172,803
