주요 콘텐츠로 건너뛰기
Apple Watch Series 5 Battery Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch3 다른 기여자
최종 수정일 May 31, 2024
50 분 - 2 시간
조정
추천 가이드
Use this guide to replace a worn-out or dead battery in your Apple Watch Series 5.
This guide shows the procedure on the cellular/LTE version of the watch, but the GPS-only version is similar.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your watch. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
During the display opening procedure of the Apple Watch you might damage the force touch gasket. If you separate the gasket layers or cut the cable, you'll also need to replace the Force Touch gasket itself.
You’ll need replacement adhesive to reattach components when reassembling the device.
필요한 것
부품
도구
더보기...
  1. Apple Watch Series 5 Battery Replacement, Display Opening: 1 단계, 이미지 2개 중 1개 Apple Watch Series 5 Battery Replacement, Display Opening: 1 단계, 이미지 2개 중 2개
  2. Apple Watch Series 5 Battery Replacement, Safety Requirements: 2 단계, 이미지 3개 중 1개 Apple Watch Series 5 Battery Replacement, Safety Requirements: 2 단계, 이미지 3개 중 2개 Apple Watch Series 5 Battery Replacement, Safety Requirements: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Safety Glasses
    $3.19
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Attach or remove the watch band as needed to provide more control as you make repairs.
  3. Apple Watch Series 5 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
    • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive softens.
  4. Apple Watch Series 5 Battery Replacement: 4 단계, 이미지 3개 중 1개 Apple Watch Series 5 Battery Replacement: 4 단계, 이미지 3개 중 2개 Apple Watch Series 5 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
    • Do not insert the knife more than 1/16th of an inch (~2 mm) to avoid damaging the force touch sensor.
  5. Apple Watch Series 5 Battery Replacement: 5 단계, 이미지 2개 중 1개 Apple Watch Series 5 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
    • Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
    • Don't try to fully open or detach the display yet.
  6. Apple Watch Series 5 Battery Replacement: 6 단계, 이미지 3개 중 1개 Apple Watch Series 5 Battery Replacement: 6 단계, 이미지 3개 중 2개 Apple Watch Series 5 Battery Replacement: 6 단계, 이미지 3개 중 3개
    • It's likely that the force touch sensor will stick to the display frame instead to the watch's body. In this case, insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
    • To preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
    • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
    • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm) to avoid damaging other components.
  7. Apple Watch Series 5 Battery Replacement: 7 단계, 이미지 2개 중 1개 Apple Watch Series 5 Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Avoid tensioning the display cables when folding the screen to the back.
    • Carefully lift the display open like a book.
  8. Apple Watch Series 5 Battery Replacement, Battery: 8 단계, 이미지 2개 중 1개 Apple Watch Series 5 Battery Replacement, Battery: 8 단계, 이미지 2개 중 2개
    • Lift the screen until there's enough space to access the battery.
    • Insert an opening pick between the battery and the Taptic Engine.
    • A regular opening pick works fine with the 44 mm version of the Apple Watch Series 5. However if you own the 40 mm version and don't have enough space you can customize your opening pick with scissors.
  9. Apple Watch Series 5 Battery Replacement, Pry up the Battery: 9 단계, 이미지 3개 중 1개 Apple Watch Series 5 Battery Replacement, Pry up the Battery: 9 단계, 이미지 3개 중 2개 Apple Watch Series 5 Battery Replacement, Pry up the Battery: 9 단계, 이미지 3개 중 3개
    • Slide the opening pick along the edge of the battery to loosen the adhesive.
    • The battery adhesive is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive. Apply the iOpener for at least two minutes.
    • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the mainboard.
    • Avoid damaging the display cables, and especially the force touch cable, which covers the battery in one corner during the prying procedure.
    • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
    • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
  10. Apple Watch Series 5 Battery Replacement: 10 단계, 이미지 1개 중 1개
    • Carefully lift the battery to a 75-degree angle.
    • Remove the 1.1 mm-long Y000 screw.
  11. Apple Watch Series 5 Battery Replacement, Remove The Metal Plate: 11 단계, 이미지 2개 중 1개 Apple Watch Series 5 Battery Replacement, Remove The Metal Plate: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the metal plate covering the battery connector.
  12. Apple Watch Series 5 Battery Replacement, Disconnect the battery: 12 단계, 이미지 2개 중 1개 Apple Watch Series 5 Battery Replacement, Disconnect the battery: 12 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
  13. Apple Watch Series 5 Battery Replacement, Remove the Battery: 13 단계, 이미지 2개 중 1개 Apple Watch Series 5 Battery Replacement, Remove the Battery: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you are reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly. Alternatively, remove the old adhesive with high isopropyl alcohol and a lint free cloth and use a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
    • Follow the resealing guide to reseal your watch after reassembly.
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
다른 39명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
회원 가입일: 11/23/16
228,990 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,418개를 작성함
댓글 8개
Since WatchOS 7 removed 3D Touch functionality on all Force Touch enabled watches, will damaging or disconnecting the Force Touch gasket affect the functionality of the watch or will the software brick it?
AStupidMidge - 답글
Any tips for applying the adhesive strip without removing the screen? Is removing the screen recommended to seat it properly?
David Mifsud - 답글
Does the resealing adhesive strip go in between the screen and force touch gasket, or the force touch gasket and the case?
David Mifsud - 답글
Hi David,
here is a general resealing guide that might help you. Depending on your force touch replacement part you‘ll need one two or no adhesive strips.
If your force touch was never removed you need to place new adhesive on top of it the adhere the screen. If your force touch has adhesive on the bottom side it is the same. Adhere the force touch into the watch frame and place adhesive on top of it to adhere the screen. If there is adhesive on the top of the force touch you need to place the adhesive strip beneath.
If your force touch didn‘t come with any adhesive preinstalled you need adhesive tape below to secure it to the watch frame and on top to secure the screen.
Dominik Schnabelrauch -
Hi @schnabel , thank you for you reply. I am in the middle of replacing the battery. I managed to save the force touch sensor from getting damaged, but I need to be re-adhere it to both surfaces. Can I use 2 of these adhesive strips on either side?
Apple Watch (44 mm Series 4/5) Screen Adhesive
David Mifsud -
댓글 쓰기
조회 통계:
지난 24시간: 92
지난 7일: 629
지난 30일: 2,372
전체 시간: 110,239
